This article provides simple and effective methods to remove Mi account and bypass the FRP lock. With easy-to-follow step-by-step guides, you can resolve these frustrating issues. Whether you’ve forgotten your Mi account details or locked screen password, this guide is for you!
When you forget a phone screen password, just free download DroidKit to 1-click bypass the lock screen without a password, pattern lock, pin code, fingerprint, etc. No skills are needed. Supports all Android devices such as Samsung, LG, Xiaomi, Huawei, etc.
Have you locked yourself out of your Xiaomi phone? Are you facing the “This device is locked” Xiaomi error? If yes, then you are not alone! Many Xiaomi users faced this situation after a factory reset. No doubt, Xiaomi incorporated this feature for security purposes, but sometimes people find it annoying. Most of us don’t remember passwords associated with our Android phones.
However, there are various methods that can help you remove Mi account and ultimately unlock your Xiaomi device. In this article, we will explore these methods with their step-by-step guide for better understanding and application. Let’s get started to address ‘this device is locked mi account bypass’ issue!
The “This Device is Locked” error on Xiaomi smartphones is a security feature that safeguards your data and device from unauthorized access. It typically appears after resetting your device unexpectedly, updating it, or installing custom ROMs. This feature ensures that only the rightful owner can access the smartphone by verifying ownership.
Xiaomi phones are not generally locked by default. They are sold as unlocked devices so that people can use them with any compatible carrier or SIM card. However, like other smartphones, they can get locked due to several reasons.
Illustration of locked Xiaomi phone
Some of the common reasons are as follows:
Now, you must be wondering if you can unlock a locked Xiaomi phone. Let’s see!
Yes, you can certainly unlock your locked Xiaomi phone. The method you should use depends upon the type of lock you are dealing with. One common scenario is forgetting the screen lock PIN, pattern, or password. In this case, there are a couple of options you can try.
“This device is locked” error.
First, try entering the wrong password multiple times until you see an option to unlock the phone using your Google account. However, If you don’t have a Google account linked or don’t remember its details, you can go for a factory reset. Remember that a factory reset erases all data on the device, including apps, settings, and personal files.
The newer versions of Xiaomi Android phones have FRP locked enabled. It means you have to enter your Mi account details after a factory reset to access the phone. However, you can continue reading the article if you don’t remember the details because we have the solutions.
The “This Device is locked” error on your Xiaomi phone indicates that your device is associated with a Mi account. Therefore, you need to enter the associated credentials to unlock it. However, there are various ways to remove Mi account and fix this error. The three effective and easy ways are given below:
Ideally, you can simply enter the Mi account login details to unlock the device. But if you forgot the password, you can try recovering the password. Follow the below instructions to do that:
Step 1. Open the web browser on your phone or laptop and visit account.xiaomi.com.
Step 2. Choose the “Forgot password?” option right under the sign-in box.
Select Forgot password option
Step 3. Enter the required information (Phone number, Email, or Xiaomi Accound ID) to proceed.
Step 4. Click next and verify your information by following the on-screen instructions.
Step 5. Once your identity is verified, you will see the next page where you can reset your Mi account password.
Step 6. Create a new strong password and click the “Submit” to proceed.
However, for any reason, if you cannot perform this method, you can try the next one.
Suppose you cannot unlock your Xiaomi device by trying the previous method. Then contacting Xiaomi customer support is also considerable, although it will take some time.
Here’s how you can request support:
Contact customer support.
If you have tried this method and didn’t get any response, go for the next method.
If you’re unable to unlock your Xiaomi phone, you can try performing a hard reset, also known as a factory reset. However, It’s important to note that a hard reset erases all data on your device. Here’s how you can do it:
Press the Volume up + Power button simultaneously.
Enter into the recovery mode.
In the latest Xiaomi phones, the FRP lock gets enabled after a factory reset. You can try the next method if you face the “This device is locked” on your Xiaomi phone.
If you no longer have access to the phone number or email linked to your Mi account, you can try binding a new phone number to your account to reset your password. Here are the steps to activate your device:
Step 1. Visit https://id.mi.com or on your locked device, tap on Forgot password.
Step 2. Enter the phone number or Email, then click “Restore security info“.
Restore Security Info
Step 3. Click “Get started” to start Reset recovery phone to bypass “This device is locked” error on Xiaomi/Redmi.
Get Started
If you are a smartphone user locked out of his phone, we can understand your frustration level. Forgetting the lock screen password is very common nowadays. Therefore, DroidKit – Android Phone Toolkit is here to rescue us from annoying situation like ‘unlock Xiaomi locked phone’ problem.
DroidKit can be the most reliable and efficient way to unlock Android phones. Whether your screen is locked with a password, pattern, or fingerprint, it easily removes them in minutes. And it has helped millions of users bypass its locked screen without any skill difficulties. In addition, DroidKit, as a one-stop tool for managing Android phones, has many other powerful features. You can check its features below:
Free get DroidKit on your computer>>and learn how to unlock Xiaomi phone password with the simple steps below
Step 1. Download and install the DroidKit on your computer > Select “Screen Unlocker” mode.
Choose Screen Unlocker
Step 2. Connect your Xiaomi phone with a USB cable > Tap on Start to unlock. DroidKit will start preparing the configuration file of your phone. After completion, click the Remove Now button.
Click Remove Now Button
Step 3. Now put your phone in recovery mode to wipe the cache partition. Select your device type and follow the instructions on the screen.
Finish Settings on Samsung
Step 4. Then, DroidKit will start the unlocking process automatically. Wait a minute, you will see Screen Lock Removal Completed page below.
Lock Screen Removal Completed
FRP lock will be enabled after a factory reset if you signed into your Google account on your Android phone earlier. However, you can bypass this lock by using DroidKit – Android Phone Toolkit. This powerful tool can help to bypass FRP lock on Xiaomi/Redmi/Samsung safely and securely. You don’t have to be a techbee to use DroidKit. It has a very easy-to-use interface, making it simple and accessible to users of all skill levels. DroidKit has the highest success rate in the market for removing FRP locks. It has helped a large number of users to bypass FRP lock since its release.
Step 1. Download and Install DroidKit on your PC > Choose FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect your Samsung phone to the PC with a USB cable > Tap on “Start” > Choose your phone brand (Xiaomi) > It will prepare the configuration file for your device. And then, please tap on Start to Bypass.
Tap on Start to Bypass
Step 3. Now put your device into recovery mode. Follow the on-screen instructions according to your device’s system type and click “Next” to proceed.
Follow the Steps on Xiaomi
Step 4. Then follow the instructions on the screen to wipe the cache partition. After that, the device will reboot, which means the FRP Lock is removed successfully.
FRP Bypass Complete
Facing the “This device is locked” Xiaomi error is really a trick thing, but luckily, we’ve explored how to remove Mi account to get rid of the “This device is locked” error for you. What’s more, forgetting the lock screen password also can be a frustrating experience for Android users. It sometimes leaves them helpless, especially if they don’t know much about technology. But fortunately, various ways can help you solve this problem. This article provided a complete step-by-step guide to unlocking a locked Xiaomi phone.
If you want a complete solution for your Android-related problems, DroidKit is the answer! It is the easiest solution to bypass the Android lock screen and FRP Lock in just a few clicks. So, download DroidKit today and stop relying on tech experts>>
