It’s a very maddening moment when you forget the password to unlock your LG phone screen and thus can’t unlock your phone to check messages or reply to emails! But don’t worry, this article details 5 ways to unlock LG phone for you. Read this post and get some effective ways to unlock your LG phone!
DroidKit allows you to unlock any phone password, it supports 20,000+ models of phones & tablets. You can unlock the device no matter if you forgot your pin, pattern, face recognition, etc.
When you accidentally forget the password of your LG phone and therefore can’t unlock your phone. You want to know how to unlock your LG phone quickly and safely! Then, you have come to the right place!
We have prepared a few simple and practical ways for you to bypass the LG lock screen. Also, some of these methods are applicable to other Android phones. Let’s start with the easiest way to unlock the LG lock screen!
If you accidentally forget your phone screen password, you can’t view your phone files or send or receive chat messages, which is always a devastating thing. At this time, you may need a proper tool to help you. The top one I would recommend to you is DroidKit – Android Phone Toolkit.
The reason I recommend this tool as the top one for you is that it has the following features:
To know more about DroidKit, download it now:
Now, please follow the steps below to know how to bypass LG lock screen without code-free using this tool.
Step 1. Install DroidKit on your computer. Connect your device to your computer with a USB cable. Then, select the “Screen Unlocker” mode.
Choose Screen Unlocker
Step 2. Then click the “Start” button. Follow the guide, and choose the “Device Connected” button.
Choose Device Connected Button
Step 3. Now, it will start preparing the configuration file for your LG phone. When it’s done, please select the “Remove Now” button.
Select the “Remove Now” Button
Step 4. Next, choose (device brand) LG. Then, follow the on-screen instructions to put your device into recovery mode.
Put Device in Recovery Mode
Step 5. After that, DroidKit will start the removal process immediately. Just wait for a few minutes and the LG phone will be unlocked.
The Lock Screen Is Removed Successfully
When the removal process is completed, your device will be started. Then, you can freely access your Android device without entering any password.
The next way to unlock your LG phone is by using Google login. This method is to help you reset your password through Google’s “Forgot Pattern”. But this method has one limitation, it only works if your phone is running on Android 4.4 or lower. Here, the specific steps are as follows:
Step 1. Start with entering an incorrect password and continue to enter the wrong password for 5 or more times.
Step 2. After you have tried to enter an incorrect password several times, you will see the “Forgot pattern”. Choose the “Forgot pattern”.
Step 3. Enter the Google account username and password that you have used to set up the device.
Step 4. Then, the device will be unlocked and you can reset your screen lock.
Another way you can solve the problem of how to unlock your LG phone without a password is to use Android Device Manager. This is one of the most powerful ways to access your LG device as long as your LG phone is connected to your Google account. The steps are very simple and are shown below:
Step 1. Go to the Android device manager website on a separate computer or phone.
Step 2. Use the Google account details which are linked to your LG phone to log in and select the device.
Step 3. Select your LG mobile model and click on “Lock” from the three highlighted options: “Ring, Lock, and Erase”.
Select the “Lock” option
Step 4. A popup window will appear and indicate you enter a new password. Enter a temporary password and click again on “Lock” to continue.
Enter a Temporary Password and Click “Lock” button
Use this newly created password to unlock your LG phone. You can even change this password later by going to your phone settings. This is another effective solution that answers the question of how to unlock your LG phone without a password.
The next method is a bit more complicated and requires some expertise. One thing to note is that this way only works if the USB debugging was earlier enabled on your LG phone. Just follow the steps below to bypass the LG lock screen. All you need is a USB cable, a PC, and a network connection.
Step 1. Download Android SDK and install ADB on your computer.
Step 2. Connect your LG phone to a PC with a USB cable.
Step 3. Open the command prompt window in your ADB installation directory. Type the code “adb shell rm /data/system/gesture.key” and then “Enter”.
Bypass LG Lock Screen via ADB
Step 4. After restarting your LG phone, if you still get a lock screen, simply enter a random password to bypass it.
Another method that you can use to unlock an LG phone without a code is by factory resetting it to the original factory settings. This way your phone would get wiped off with all the settings including the screen lock and will reboot as a new phone. So please remember to back up your phone first. Here are the steps involved:
Click on “Reboot System Now”
Once the boot process is complete, the lock screen is removed and you can access your LG phone again.
LG users may also need to replace their SIM cards for free, in addition to their screen being locked. Then you can refer to the following steps.
You may not have the passcode to access your LG phone due to many reasons, which may get you into trouble. However, by reading the solutions provided above, we believe that you have mastered one or two effective ways to bypass the LG lock screen. All these methods can help effectively and they are all professional methods, especially DroidKit, which is built on 8 cutting-edge technologies to ensure you get the smartest, easiest, and most secure solution. So, download DroidKit now and solve your problem with one click!
