Losing or forgetting the pattern to unlock your LG phone isn’t a big deal anymore once you have the right pattern unlock guide at your disposal. This post is structured to reveal the different techniques to bypass or unlock LG phone patterns if forgotten.
Though pattern lock plays a crucial role in the protection of users’ privacy, it sometimes poses a challenge to a mobile device owner, especially in the case of lost or forgotten pattern lock. It can also pose a problem to second-hand mobile users when you purchase a device with pattern lock from an unknown person.
When either of the aforementioned scenarios happens, you need to opt to unlock the device. There are many ways to do this, but this article will focus on the best 5 ways. Read on, as we explore how to unlock LG phone patterns if forgotten.
If you are looking to unlock your LG mobile device without a computer system, kindly select any of the techniques shared below:
With the Emergency call button on your LG phone, you can easily bypass your screen lock when you forget the pattern used in unlocking it. The Emergency Call button in conjunction with the camera feature and settings menu helps you trick your LG phone to remove pattern locks.
Here’s how to use this technique:
Tap Emergency Call
The backup PIN is a security code you must register on your LG phone when you select pattern lock as your preferred security protection feature. It serves as an alternative to unlocking your LG phone whenever you lose or forget the pattern to bypass the screen lock on your device.
Using this method is pretty easy, and it doesn’t require a computer system. Here’s the quick guide you need to follow for you to successfully unlock your LG phone pattern using the backup PIN approach:
Choose Backup PIN
Factory reset is a restoration technique often used to return a mobile device or computer system back to the default settings, just like it was newly bought. This technique is one of the best troubleshooting solutions often used to revive a device each time it malfunctions. It fixes a plethora of issues such as Android phone frozen screen, unresponsive keys, and more.
You can also use it to unlock your LG phone in case you forgot the pattern used in bypassing the screen lock. Factory reset helps you remove screen lock from your LG phone easily and quickly without paying a dime. However, this technique usually results in data loss, as your entire system needs to be wiped.
If you don’t mind losing your data, here is the step-by-step guide to unlocking your LG phone via factory reset:
Step 1: Firstly, you need to enter recovery mode on your LG phone. For you to do that:
Step 2: With the help of the Volume Up or Volume Down button, you can scroll through the options on your screen. Kindly scroll and select the wipe data/factory reset icon from the options appearing on your LG phone screen.
Wipe Data and Factory Reset your Device
Step 3: Next, a window with the consequences of resetting your phone will come up. Click on the corresponding button to Agree, and proceed with the factory reset. Once done, hit the Reboot system now button to restart the LG phone.
Limitations: You are liable to lose all the data on your LG phone. And devices with malware or virus attack might go off completely, and never come up again.
Our first solution isn’t the most appropriate to unlock your LG phone when you forget the corresponding pattern you used in bypassing screen lock, and that’s because of the limitations attached. If you are looking for a technique to remove pattern lock from your LG phone without encountering issues like data loss, OS crash, and more, then a third party Android unlock suite like DroidKit is what you need.
Step 1. Download and launch DroidKit on your PC. Click on Screen Unlocker.
Choose Screen Unlocker
Step 2. Connect your LG phone to the computer with a USB cable and click on the Start button.
Connect your Locked Phone
Step 3. Now, the tool will start preparing the configuration file for your LG phone. When it’s done, you can tap on Remove Now.
Click Remove Now Button
Step 4. Select your device brand to remove lock screen. Here you should choose LG.
Step 5. Follow the on-screen instructions to put your device into recovery mode. After that, DroidKit will start the removing process immediately. Just wait for a few minutes and the LG phone will be unlocked.
Lock Screen Is Removed Successfully
With Android Device Manager, you can easily regain access to your pattern-locked LG phone right from the comfort of your home. Though the Android Device Manager is programmed to help you track the whereabouts of an Android device, you can also use it to ring, wipe or even change the lock on your device remotely.
This DIY screen unlock approach is pretty simple to implement, however, it’s crucial you recollect the Google details linked to the device. Once you have these credentials ready, follow the steps below to remove the pattern lock of your LG phone:
Step 1: Use this link to visit the Android Device Manager page, then enter your Google Account details in the fields provided. Ensure the details tally with what you have on your LG phone. Once done, hit the blue Sign In button.
Step 2: Next, locate the device icon at the top left corner of your screen, and select the LG phone. Once done, select the Lock from the options displayed underneath your device, so as to change the security lock on your device.
Step 3: Now, a window will automatically show on your display screen. Kindly provide the new passwords you wish to use, and hit the Lock button to save changes. Afterward, kindly enter the newly created password on your LG phone and it will automatically unlock.
Unlock Samsung with Android Device Manager
Here is another popular technique to unlock the pattern on your LG phone. With the aid of your Google Account, you can quickly remove the pattern lock on your LG phone conveniently. Here’s how to use this technique:
Bypass Lock Screen on LG Phone Using Google Account
It only suits for only Android 5.0 and later versions. And you must remember the corresponding details to your Google Account.
Here’s another cost-free solution to remove or unlock forgotten patterns on your LG phone. Android Debug Bridge, also known as ADB is a programming tool often used by developers to connect and communicate with an Android phone. This tool is established to facilitate a variety of operations, such as app installation, app debugging, and more.
Android Debug Bridge also comes in handy when you need to fix lost or forgotten security protection issues on your Android phone. It lets you unlock forgotten patterns on your LG phone by simply entering a few command lines.
Here’s how this is done:
ADB shell
cd/data/data/com.android.providers.settings/databases
sqlite3 settings.db
update system set value=0 where name=’lock_pattern_autolock’;
update system set value=0 where name=’lockscreen.lockedoutpermanently’;
.quit
ADB shell rm/data/system/gesture. the key
Quick Note: You must have activated USB debugging on your LG phone to use this technique. Failure to do this might cause the device not to unlock.
While factory reset can help you remove pattern lock on your LG phone, you might encounter some challenges if your device is second-hand, and running on the latest Android version which has FRP lock on it. The reason is that FRP lock requires you to enter the details to the Google Account linked to the device.
Smart Lock is an amazing feature introduced on my Android devices running on Android 5.0 and later versions. The goal of this feature is to remove screen locks whenever an Android phone is around a trusted device such as Bluetooth or within the possession of the owner.
However, mind you, this feature works only when you have your GPS enabled. If you meet this condition, apply the procedure given here to activate Smart Lock so it can always unlock your device temporarily:
Limitations
The Find My Device is an excellent feature integrated into an Android phone to help locate its whereabouts in case it goes missing. The feature also plays a crucial role in bypassing screen lock, as it allows you to wipe your device remotely.
Find My Device is similar to the Factory Reset technique since you are wiping your device. However, you must have the corresponding details to the Google Account on your LG phone. Also, you must have activated Find My Device on your phone for this technique to come in handy.
Once all of these are in place, follow the steps below to bypass the pattern lock on your LG phone:
Limitations
Q1. What is the master unlock code for LG phones?
Although there are reports about master unlock codes for Android devices, none have been truly effective. If you need to unlock your device without running into errors or complications, then DroidKit is the best option.
Q2. How to change your LG phone pattern?
Do you feel your screen lock pattern is less secure? Follow the steps below to change your LG phone pattern:
Unlocking your LG phone pattern isn’t a big deal when you have the right tutorial guide. We’ve shared the best 5 ways to unlock your LG phone in case you forget the pattern lock. Choose one of the techniques and follow the steps underneath.
However, mind you, our preferred technique is the one involving DroidKit. The software offers a simple and safe way to remove the pattern lock from your LG phone without compromising it. We implore you to invest in it today to get the best result.
