Don’t find out the way to unlock Google Pixel. Check out the four methods in this article to reset google pixel. Unlock the screen of Google Pixel with DroidKit.
When you accidentally forget your Google Pixel screen password, or someone else has locked your device after wrongly entering the screen password, this time you must be very distressed how to unlock Google Pixel. Don’t worry, we have introduced you to 4 ways to unlock the screen in this article, including ways that do not require wiping your device’s data.
The first method to reset the password on Pixel or Pixel is for those who have already registered. Registration on Android Device Manager is necessary before. Follow the given instructions to get your phone reset. Don’t miss any of these steps!
You need to turn on the “Lock” feature in Android Device Manager to reset the password. If you’ve forgotten your Pixel or Pixel XL password. You just reset it by using the “Lock” option in Android Device Manager.
For this, Check out the following steps!
Sign Into Google Account and Click on Lock Option
If you don’t have access to ADM, then don’t worry. Try the following steps.
If you can’t unlock your Google Pixel in the above way, then you need a more powerful Android screen unlocker to help you. With DroidKit, you can:
Choose Screen Unlocker
Connect your Locked Phone
Click Remove Now Button
Put Your Android Phone into Recovery Mode
Finally, it’s time to unlock the screen lock of pixel by DroidKit. Follow the below instructions!
Lock Screen Removal Completed
Google Find My Device is a feature used to locate a phone. You can use a password, pattern, or PIN to lock your phone and then unlock it. Do you forget your pixel password and are now in worry? Then try out an instant way of Google Find My Device to unlock it. Given below steps will help you!
Use Google Find My Device
Choose Lock Option from Google Find My
Alt Text: Lock button on Google find my Device
Set a Password for your Google Locked Phone
If the tips mentioned above can’t allow your Google Pixel to Unlock. Then try out the reset process by following steps:
Fastboot Mode
1. First, you can try to reset your Google Pixel password using Android Device Manager
2. If method 1 fails, it is recommended that you directly use the Pixel unlocking software (DroidKit) to unlock the Google Pixel. No professional knowledge is required and the device can be unlocked quickly.
3. Unlocking Pixel through Google Find My Device and resetting Google Pixel through recovery mode take a certain amount of time and require professional knowledge.
Well, for most Google Pixel phones, the default pin is 0000.
If you set face lock, pattern, fingerprint lock, smart lock, etc. before you forget the pin code, then you can unlock Google Pixel without losing data. But if unfortunately, you didn’t set these up in advance, then you can only use a third-party Android unlocking tool, such as DroidKit to help you to unlock Google Pixel.
Well, you must be very happy when you finally unlock Pixel. But unfortunately, most of the above-mentioned unlock methods will erase the device data. So, is there any chance that you can recover the erased data? Don’t worry, you can not only restore from settings, Google backup, but also use DroidKit to help you find more data.
1. Turn off the device.
2. Press and hold the Volume Down and Power buttons until the bootloader screen appears.
3. Use the Volume buttons to navigate to “Recovery Mode” and press the Power button to select it.
4. When the Android logo appears, press and hold the Power button, then press the Volume Up button once, and release both buttons.
5. Use the Volume buttons to navigate to “Wipe data/factory reset” and press the Power button to select it.
6. Confirm by selecting “Factory data reset”.
Finally, your Google Pixel is unlocked by following the above-mentioned tips. DroidKit not only makes it easy to remove screen locks, but also helps you recover lost data after you have tried other methods of erasing it. If you get rid of your issue, comment below and share your experience. We love to hear from your side. Don’t forget to share this with your friends facing this issue!
