Locked your Samsung Galaxy Fold mobile and now unable to remember its password? Here we discussed the best ways on how to unlock Samsung Fold forgot password easily.
These days Samsung Galaxy phones are very popular among people. Since its release, it has created a buzz among people, especially youngsters. Samsung Fold has various amazing features and many security features that can make your phone more efficient.
Unlock Galaxy Fold
There are various times when people set a password, PIN, or pattern lock for their Samsung Galaxy Fold device, but forgot it after some time. If you have also come across such a situation, then here we will discuss how to unlock Samsung Fold forgot password. Read the article till the end, to get to know more about it.
No, you can’t unlock Samsung Galaxy Fold without using password. You need to enter the authorized passcode to unlock your Samsung mobile phone. When trustworthy sites or devices are found, the device can be configured to automatically unlock and stay unlocked. But what if you forgot the password for it? In this situation, you need to take advantage of other tools like Samsung unlocker. And in the following sections, we will talk about how to unlock Samsung Fold forgot password in several proven ways.
If you have forgotten the password to unlock your Galaxy Fold phone and don’t know how to unlock Samsung Fold. Then, here we have discussed some of the ways that you can use to unlock your mobile phone.
If you want to unlock Galaxy Fold mobile without using its passcode, then the most prominent way to do so is using its default passcode.
Here is the guide on how to unlock Samsung Galaxy Z Fold 5/4/3:
Step 1. Press the ‘Power’ Key from the side of the galaxy mobile or swipe the screen.
Step 2. Now, on the screen enter the default PIN of Galaxy Fold mobile phone and then enter ‘0000’ or ‘1234’.
Your phone will now automatically get unlocked and you can now change the passcode of your Galaxy Fold smartphone.
How to unlock Samsung Z Fold 3/4/5 without password? You can also use a professional Android unlocker like DroidKit. DroidKit is a one-stop Android toolkit that can help you to remove any screen locks on Android devices, like numeric passcode, fingerprint, Face ID, pattern, pin, etc. All you need to do is click the buttons, no skills are needed. All Android devices are supported, including Samsung Fold, LG, Huawei, Motorola, etc.
Other than, DroidKit can also recover lost data, like photos, WhatsApp chats, messages, and other media files. It also provides a system repair tool, FRP bypass solution, system cleaner, etc.
Now you can follow the steps below to see how to unlock Samsung Fold forgot password.
Step 1. Download and Install DroidKit on your computer and run it. Use a USB cable to connect your Galaxy Fold phone to your computer. From the home screen, tap on Screen Unlocker.
Choose Screen Unlocker
Step 2. Click on Start button. And a configuration file will be created for your device by DroidKit. As soon as you are ready, select Remove Now to proceed.
Click Remove Now Button
Step 3. Your phone’s brand will be recognized by DroidKit. To enter recovery mode on your device and wipe the cache partition, follow the on-screen instructions. The process of removing the lock screen will also begin right away.
Finish Settings on Samsung
Step 4. After some time has passed, you will come across the ‘Screen Lock Removal Completed’ screen as seen below.
Lock Screen Removal Completed
Smart Lock helps to keep your phone unlock until its in contact of your body, at a trusted place or is connected to a trusted device.
Follow the below given steps to know how to unlock a Samsung flip phone if you forgot the password.
Unlock Galaxy Fold via Smart Lock
Step 1. Check to see if ‘OK Google’ has been activated and configured for Google Now or Google Assistant.
Step 2. Go to the app drawer and launch the Google app.
Step 3. When you tap the icon located in the top left corner, the settings menu will appear.
Step 4. After selecting Voice, select ‘OK Google’ recognition.
Step 5. Now click on ‘From and Screen’.
Step 6. Hit ‘Always On’.
Reset is typically used when you have no access to your phone at all. That indicates that either your fingerprint does not match or you have forgotten your lock screen pattern or password. You must thus try a reset as a result of this.
Follow these instructions to know how to reset Z Fold without password:
Step 1. Ensure that the Samsung Galaxy Fold 5G’s battery is at least 50% charged.
Step 2. Switch your phone off.
Step 3. The phone screen will not light up until you press and hold the ‘power button’ and the ‘volume up button’ together for a few seconds.
Step 4. When the factory data reset information appears, choose Yes.
Choose Yes to Hard Reset
Here, we have discussed the best ways how to unlock Samsung Fold forgot password. You can use any one of them as these are one of the easiest ways to do so. We recommend you use DroidKit, as it can 1-click unlock Android phones and retrieve deleted data from them. If you find this article helpful, then do share it with your friends. Let us know in the comment box which way has helped you to unlock your Samsung Galaxy Fold.
