Is there a universal unlock PIN for android? How to unlock Android when you forget Android PIN/pattern/password? In this article, you will find all the answers in this article and will also learn some proven methods to unlock Android screen lock.
If you forget the PIN/pattern/password lock on your Android device, how to unlock it? Don’t worry. Just free download DroidKit to 1-click unlock Android screen. All the screen locks are supported, like PIN, pattern, numeric passcode, Touch/Face ID, etc. And it supports all Android phones and tablets, like Samsung, Huawei, LG, etc.
Smartphones have become a necessity in today’s technologically advanced world. Because of their widespread use, we frequently use a PIN, pattern, or password to protect our devices. People occasionally forget their device passwords, making phone use difficult. It is said that a universal unlock code for Android can be used to unlock your Android device in this situation. So, is it true? And what it is?
In this article, we will answer all your questions about the universal unlock PIN for Android. And we will also introduce some easy methods to unlock Android screen with a step-by-step guide. Before starting the ways to unlock the PIN, you first need to know if there is a universal PIN code to unlock!
You May Like: Below are some other tips about Android unlocking.
When forget the Android PIN code, some users are looking for a universal unlock PIN for Android without losing data. However, there is no universal unlock PIN for Android to unlock the device. Any allegations that such a code is available are entirely false.
Users should be aware of such statements to avoid falling for scammers. The objective of device security would be beaten if there was a universal unlock PIN for Android or universal unlock code for Android. It’s making it simple for anybody to access the device and its data.
It is vital to remember that device security is essential for personal and professional use. As both situations may involve storing sensitive data on the device. As a result, manufacturers dedicate a lot of effort to create product security features.
As there is no universal unlock PIN for Android, what if I forgot my PIN to unlock my phone? There are still some ways for you, like backup PIN, Google account, etc. Now, just keep reading to learn the methods to unlock PIN for Android!
When users forget their PIN, pattern, or password, DroidKit – Android Phone Toolkit is a powerful tool that can assist them. It is a one-stop Android solution that can help you solve all Android problems, including unlocking Android screen. And it is an excellent choice for not tech-savvy users because it is easy and straightforward to use. DroidKit can help you unlock all Android devices easily, no matter what Android brand it is, like Samsung, LG, etc., or whether it runs an old system or the latest system. You can also read on to learn more about what DroidKit can do for you when it comes to unlocking.
Now get DroidKit for free and follow the steps below to unlock PIN for Android with simple clicks by using it.
Step 1. On your PC/Mac, open DroidKit and select Screen Unlocker mode.
Choose Screen Unlocker
Step 2. Attach your Android smartphone to the PC by USB cord. Then you need to press the Start button.
Connect Your Android Device
Step 3. The configuration file for your device will then begin to be prepared. When the procedure is finished, tap on Remove Now.
Click Remove Now Button
Step 4. Choose your Android brand and keep following the DroidKit interface’s instructions to set the smartphone in recovery mode.
Finish Settings on Android
Step 5. After that, Android screen lock removal will start. And your device will start up when the removal procedure is finished.
Lock Screen Removal Completed
The most frequent justification for this strategy is that the user must remember their PIN or lock screen pattern. Anybody may encounter this, which can be irritating, especially if your device has crucial data you need access to.
You can reset Android PIN and recover accessibility to your smartphone by selecting the “Forgot Pattern” option. Also, if a person doesn’t have access to a computer, they can choose to employ this approach. And this method doesn’t require a computer, so it is quite convenient for those who cannot use the computer. To unlock PIN for Android without using a PC, follow the below instructions for an effective response!
Step 1. When you continually try to unlock your phone, a screen declaring “Incorrect pattern” appears. Click the “Forget pattern” button.
Step 2. Choose the choice to Enter Google account details as shown below.
Select Enter Google Account Details
Step 3. Input the username and password for your Google Account that you already registered to your phone.
Step 4. After signing in, you will get a link to that email where you may either immediately design a new pattern for the device or a new passcode.
It’s crucial to remember that not all Android devices and models can support the “Forgot Pattern” option. Also, you can only activate this approach if you remember your Google account login information or if your device is online.
If you lose your primary PIN or password, you can form a backup PIN, a 4 to 6-digit number, to unlock your Android smartphone. This vital security feature can assist you in regaining control over your gadget without erasing any data. Please note that to avoid conducting a factory reset of the device, a Backup PIN is the primary method to unlock PIN for Android without losing data.
Your smartphone will be locked and require the login information for your Google account if you repeatedly input your primary PIN or password incorrectly or forget it. You can only utilize this approach if you remember your Google account or your device is online.
If you’ve set the backup PIN prior, and you remember that PIN, then you can follow the below steps to unlock PIN for Android:
Step 1. Insert the wrong password or pattern while using the screen lock.
Step 2. If it is still known, choose Backup PIN in the bottom right corner of the screen.
Choose Backup PIN
Step 3. To proceed, enter your device PIN and click Done.
Step 4. You can reset the lock screen password by going to the Screen Unlock settings after entering the proper PIN.
Though there isn’t a universal unlock PINJ for Samsung, Samsung comes with a function called “Find My Mobile” that enables you to monitor, find, remotely manage and unlock your device. It’s essential to remember that you must first activate Remote Unlock on your device to utilize the Find My Mobile function. Moreover, other Android smartphones cannot use this function; it is exclusively accessible for Samsung devices.
To unlock PIN for Android using Find My Mobile, follow these steps:
Step 1. On your computer, look for “Google Find My Device.”
Step 2. Use the same account to log into the program and configure your locked device.
Step 3. Click the Lock button after choosing your device.
Choose Lock Option from Google Find My Device
Step 4. Enter a temporary password next. Re-click the Lock button.
Step 5. Restart your locked device after that. Your smartphone will then show a password display. To finally unlock your smartphone, enter the new password.
An adequate degree of protection is added to your Android smartphone when a PIN or password is set up, preventing unauthorized access. Moreover, forgetting your PIN or passcode might be troublesome because you won’t be able to use your smartphone.
So, how to unlock Android phone if forgot PIN? In fact, you can unlock your smartphone using your Google account credentials if you have connected it to your Google account. “Google account verification” or “Factory Reset Protection (FRP)” is the term of this feature. To unlock PIN for Android in this way, you should follow the instructions below:
Step 1. Your smartphone will show that it is locked after repeatedly entering the incorrect PIN or passcode.
Step 2. Click the “Forget pattern” or “Forget PIN” link on the screen.
Choose the Forgot Pattern
Step 3. The login details for your Google account will be requested.
Step 4. Your phone will check your Google login details against Google’s servers when you input them.
Step 5. Once your login information is accurate, you will be asked to set up a new PIN or password for your phone.
Step 6. You will have control over your gadget once you have set up a new PIN or passcode.
It’s vital to remember that your device must first be connected to your Google account for this function to work. Also, if you still need to activate a connection to the internet or if your Google account details need to be corrected, this function is not for you.
When you launch your Android smartphone in safe mode, all third-party apps that may create problems are disabled while only the necessary system apps and services are running. The safe mode might be helpful while attempting to unlock PIN for Android in a few different ways:
A safe mode in the Android device will be achieved by following the steps mentioned below:
Step 1. Hold down the power button while pressing it to bring up the power choices menu.
Step 2. When the “Reboot to safe mode” choice displays, continue to press the “Power off” option.
Step 3. To restart your device in Safe mode, tap “OK.”
Put Phone into Safe Mode
Step 4. Try using your password to unlock your smartphone after it is in Safe mode. If you are successful, it indicates that a third-party app or lock screen app caused the problem.
Step 5. Try rebooting it in standard mode and trying again if you still have trouble unlocking your smartphone.
It’s crucial to understand that if you’ve forgotten your Android device’s password, entering Safe mode won’t automatically open it. It can, however, assist you in locating and resolving problems that may prohibit you from unlocking your phone.
You should be aware of scammers who talk about the universal unlock PIN for Android, because there isn’t one. Just try one of the techniques described in this article to unlock your smartphone if you forgot the password. And we highly recommend you try DroidKit for free first due to its convenience, high speed, and high success rate. If you get access to all the functions of your device by using the techniques to unlock, tell us in the comment section. We love to hear from your side!
