“This device was reset to continue sign in with a Google account” is a very common issue in new Android devices. In this article, we will discuss 4 easy methods to bypass Google account verification.
What to do if you receive the message “This device was reset to continue, sign in with a Google account that was previously synced”? Free download DroidKit to bypass Google account verification even without account or password. No skills are needed. Supports Android 6 and above. Covers Samsung, Mi, ViVo, OPPO, etc.
Have you factory reset your device? Then you may be stuck on the “this device was reset to continue sign in with a google account” error. Or if you buy a second-hand Android device, you may also see this message if the previous owner hasn’t removed the Google account completely. And you can’t access this device until you enter the correct Google account information to verify.
It can be frustrating not to be able to access your device, especially when it’s not so easy to find the Google account details. Google account is a type of service error. Many factors can cause this, but it most commonly occurs after the factory reset of a device. If you are having the same problem, then this guide can be helpful in fixing it. Let’s get started!
And you may also like this article: How to Bypass Google Account without OTG Cable or Computer >
What does it mean when it says this device was reset to continue sign in with a Google account that was previously synced on this device? This is a Google verification to improve the security of new Android devices. It is added by Google after Android 5.0 OS and is also known as Factory Reset Protection (FPR). This error appears after the factory reset of a device. If your phone is reset you may need to enter the google account information to access the device.
This Device Was Reset Error
To clearly understand the purpose of this feature. Let’s suppose someone stole your phone. The thief might be able to reset it to factory settings and access it. This feature helps prevent that by requiring a previous Google account to set up the device after a reset. That way, only someone who knows the correct email and password can use the phone.
You may also like: How to bypass FRP on Samsung
Why you get the message “this device was reset to continue, sign in with a Google account that was previously synced”? If you have the latest version of Android phone and you have done the following things:
Then, this protection feature will automatically turn on for your device. It will help ensure the device is accessible to an authorized user only. In case you lost your phone, or it got stolen. The person who would find it has to perform a factory reset to remove the screen security. After the factory reset, he will get stuck on this error and have to enter the Google account to access the device.
But that cannot always be the case; forgetting your Google account and password is very common nowadays. If you have forgotten yours, then you must be going through this frustrating situation. So, can you bypass Google account verification after reset? Yes, of course. And in the next part, we have got you the best solutions to fix the issue.
People forget their phone password and perform a factory reset to remove it. But they don’t know that the “the device was reset to continue sign in” error can also be problematic. But don’t panic; here are 4 easy methods to bypass Google account verification.
If you are looking for the easiest and fastest way to make “this device was reset to continue, sign in with a google account that was previously synced” bypass, then DroidKit – Android Phone Toolkit is exactly what you need.
As the name suggests, it is an all-in-one tool built for Android problems. In this tool, you can find solutions to almost all Android problems, such as bypassing Google account, recovering lost and deleted data, extracting data from Google backups, unlocking Android screen, and more. With its powerful performance, DroidKit has been recommended by many users as the best choice for bypassing FRP lock. It helps you to bypass FRP lock on multiple devices, including Samsung, Xiaomi, Redmi, OPPO, ViVo, Motorola, etc. And you can learn more about DroidKit’s features in Google account removal below.
Now free download DroidKit and follow the steps below to bypass Google account verification quickly.
Step 1. Launch DroidKit on your Windows or Mac computer. Select FRP Bypass mode on the main screen.
Choose FRP Bypass
Step 2. To start removing the Google account, you need to connect your phone to computer first, and then click Start and select device brand to proceed.
Step 3. DroidKit will start preparing your configuration file. Once the preparation is completed. Click the Start to Bypass button.
Tap on Start to Bypass
Step 4. Just follow the on-screen instructions to put your device in recovery mode. Find and select the system version of your Android device > Click the Next button.
Select System Version and Click Next
Step 5. And then just set your device as the on-screen guide and wait for DroidKit to bypass FRP lock.
Complete Corresponding Settings
Step 6. After completing these steps, the device will be restarted, and the FRP lock will be removed successfully.
FRP Bypass Complete
When you receive the “this device was reset to continue sign in with a Google account” message, you can resort to OEM unlocking feature on your Android phone. It allows you to perform anything on your phone without any limitations via the bootloader. Now, let’s start by trying the OEM feature to bypass Google account verification/Factory Reset Protection (FPR). Follow these easy steps to use this feature.
Step 1. When you see the error “Verify your account,” then long press “@” on the keyboard until a new window appears.
Step 2. Now click on the option “Google Keyboard Settings.”
Step 3. You will see three dots in the upper right corner, click and select “Help & Feedback.” > Press long on any random text to copy it > A search icon will appear, tap and type “Settings” in it.
Step 4. Go to “Settings,” then move to “Developer options” and enable OEM unlocking.
Enable OEM Unlocking
If you don’t see the Developer option, click on the builder number 7 times.
Step 5. Long press the power button to reboot your phone. Now while setting up, you will get “Add your account” instead of “Verify your account.”
Get Add Your Account Screen
Another effective method to bypass Google account verification/FRP lock is using FRP Bypass APK. It is basically a third-party app in APK format. You can use it to get done with this situation. But to perform this, you will need.
If you have these three, you are good to go. Follow the below instructions to get “this device was reset to continue, sign in with a google account that was previously synced” bypass.
Step 1. Download the APK app on your computer and copy the file onto your USB flash drive.
Install FRP Bypass APK
Step 2. Turn on your Android device where you are facing the FRP error. Wait until the Verify your Google toggle appears.
Step 3. Now connect an OTG cable with the USB and your Android device.
Step 4. You will see the file explorer feature on your mobile phone. Locate the APK file you downloaded and install the app on your Android phone.
Step 5. Once the installation is complete, tap on open from the development settings option. It will open the settings menu.
Step 6. Now scroll down and click on the “Backup and Reset” option. Then select the “Factory Data Reset” option and confirm.
This action will erase everything from your device, including your previous Google account. Finally, you will be able to access your phone again.
If you still can’t bypass “this device was reset to continue sign in with a Google account”, the last way is to hard reset your Android device. It will wipe all the data, including the account synced with the device. But in case you don’t know how to factory reset manually. Follow the instructions given below to bypass Google account verification now.
Click on Wipe Data/Factory Reset
It will start wiping your device, and you won’t face this issue after a restart.
With the above methods, you may successfully make “this device was reset to continue, sign in with a Google account that was previously synced” bypass. And if you don’t want to face this FRP error again. Then remove the previously synced Google account from your device. Here is how you can do it:
Step 1. Go to your phone’s Settings > Cloud and Accounts > Accounts.
Go to Cloud and Accounts
Step 2. Now select Remove Account to sign out from the Gmail account.
The steps to remove the account depend on your phone model; the screenshots shown here are from a Samsung Android device, yet the process is likely to be similar across other models.
We know “this device was reset to continue sign in with a Google account” can be annoying. Fortunately, there are solutions for preventing this issue and resolving it when it does occur. We hope the methods explained in this guide have fixed your issue. And if you want to solve this problem as quickly as possible, DroidKit will be your first choice due to its high efficiency and convenience. Just get DroidKit for free and try it out! Don’t forget to tell us in the comment box which method did the magic.
