Top 6 Samsung Unlock Tools to Remove Samsung Lock
When it comes to Samsung unlock without password, using a Samsung unlock tool can be a convenient way. But how to choose a proper one is hard to say. This article provides 6 Samsung unlock tools, including their main features, pros and cons, with which you can make a decision easier.
Author Avatar Joy Taylor Last Updated: Feb. 19, 2025
Read in: Read This Article in
Italiano
DroidKit – Easiest Samsung Unlock Tool 2025
Try the DroidKit unlock tool to remove your Samsung screen lock or bypass FRP on Samsung devices. It is available on all Samsung phones and tablets with a high unlock success rate.
Many Samsung users have complex passwords, pattern locks, or PIN codes on their devices. In rare instances, this can become a problem if the user wants to get into a locked Samsung without password, or the device is hacked or infected with malicious code. In this case, a Samsung unlocking tool shows its prominence.
What makes the best Samsung unlock tool? There are plenty of multifunctional software products that can help to overcome this issue, some of them specially designed for Samsung phones. If you wondering how you can choose a solution that can reliably unlock the phone and doesn’t require professional skills, keep reading the following part.
Also Read: How to Unlock Android Tablet without Google Account >
1. DroidKit [Fast & Easy]
DroidKit is a powerful Samsung unlock tool regardless of the reasons why access is disabled. It helps to bypass different types of locks, including numeric passwords, face recognition, fingerprints, PIN codes, and Samsung FRP locks. No matter if you forgot your Samsung password, or your Samsung phone won’t accept the password, DroidKit will fix them all. In addition, DroidKit can be used to upgrade or reinstall AndroidOS for Samsung phones and tablets. Its compatibility with more than 20,000+ phone models is a key asset.
Pros:
  • Supports almost all models of Android phones and tablets, even many older versions.
  • Unlock the screen in two ways: rooting or non-rooting (without a USB cable) devices.
  • Bypass FRP on Android and work with both Windows and Mac.
  • No tech knowledge is required. Everyone can handle it.
Cons:
  • DroidKit doesn’t provide a mobile APP or FRP bypass APK on Android devices.
Section 1: DroidKit – Samsung Screen Unlock
Before using this tool to remove the screen lock on your Samsung phone, you need to download and install DroidKit on your Windows or Mac computer.
Step 1. Launch DroidKit select Unlock Screen mode.
Choose Unlock Screen Function
Step 2. Connect your Samsung and click Start. Then, DroidKit will prepare the configuration file automatically. After that, tap on Remove Now.
Click the Remove Now Button
Step 3. Select your device brand and click Next. DroidKit will unlock your phone accurately according to your mobile phone brand.
Step 4. Follow the on-screen instructions to put your device into recovery mode and wipe the cache partition on your phone. Once you finish the above steps, DroidKit will start removing the screen lock. Wait a minute, and the screen will be unlocked.
Lock Screen Removal Completed
Section 2: DroidKit – Samsung FRP Bypass
As we have mentioned above, DroidKit provides an easy way to bypass Google account on Android without password. There is no need for any technical knowledge. The simple operation steps make it easy for everyone to follow. Moreover, DroidKit has optimized the FRP bypass mechanism for Samsung devices to ensure a high success rate. And it supports all Samsung phones and tablets that are running Android 6 to 15.
Follow the steps below to bypass FRP on Samsung with DroidKit:
Step 1. Launch DroidKit on your computer and choose the FRP Bypass option.
Bypass FRP Lock in DroidKit
Step 2. Connect your Samsung phone with a USB cable and read the specific details below and click on the Start button as the picture shows.
Step 3. After that, DroidKit will start preparing the configuration file for your device. Later, please click the Start to Bypass button.
Tap on Start to Bypass
Step 4. Follow the instructions shown to put your device in Recovery Mode and get your Android system version. Then, click the Next button.
Select System Version and Click Next
Step 5. Then, please follow the instructions to complete the corresponding Settings.
Complete Corresponding Settings
After completing the setting steps above, it will start to bypass the FRP lock. When the bypass process completes, your device will be restarted.
FRP Bypass Complete
FRP Bypass Complete
Also ReadHow to Unlock a Locked Android without Losing Data >
2. Dr.Fone
With this Samsung phone unlocking software, you can easily bypass several types of locks: pattern, password, PIN, and fingerprints. Dr.Fone perfectly works on a new generation of Samsung devices as well as on older models. It is capable of unlocking the screen without losing any content, but only if your phone brand is on the supported list. In other cases, unlocking can cause data loss. A friendly interface will help you to start and finish the process in a minute.
DrFone Unlock Android Phone
Dr.Fone Unlock Android Phone
Pros:
  • Dr.Fone is compatible with even old versions of Android phones.
  • Extremely simple and effective, with phones being unlocked in minutes.
  • There is no danger of valuable data loss in most cases.
Cons:
  • Requires a connection with the computer to unlock an Android phone.
  • APK files must be installed, which can sometimes cause additional issues.
3. GalaxyUnlocker Software
You need a constant connection to the Internet for this software to work properly. It reads the original SIM Network Unlock PIN and special codes so it can generate IMEI. By visiting the web, you can easily unlock the Samsung, by following a simple procedure. GalaxyUnlocker allows you to reset the phone to default settings, and that is great for recovering data that existed before then you forgot the password.
GalaxyUnlocker Unlock Samsung Phone
4. Android Device Manager
Android Device Manager can bypass any type of Samsung lock, with a great rate of success. It is a useful network tool, which doesn’t require any complicated steps in the process of unlocking the phone.
Pros:
  • Access to your device will be allowed quickly after you log into the Google account that was previously associated with the locked phone.
  • Enter a new password in the pop-up field of the ADM interface.
Cons:
  • You need to be sure that Android Device Manager is enabled on your smartphone if you decide to use this tool.
5. Find My Mobile
Find My Mobile is a very effective web-based Samsung unlock tool, in particular, if you searching for quick solutions. It is designed to locate the device, but can also be very helpful if you forget the pattern, password, or PIN code of your Samsung mobile. On the negative side, this tool has some trouble unlocking more complex phone locks, like face recognition and fingerprints.
Find My Mobile
Find My Mobile
Pros:
  • No need to download the software, just go to the websites and log in with your Samsung account.
  • The unlocking process will be finished in a second.
Cons:
  • But only if you previously attached the device to the Samsung account and enabled the Find My Mobile feature on your phone.
6. KingoRoot
KingoRoot appears to be designed to root Android phones. It does, however, have functions for unlocking your Samsung bootloader, removing its passcode, PIN, pattern, and fingerprints. When connected to a computer, it performs operations by automatically downloading the USB driver compatible with Samsung.
Unroot Android Phone With KingoRoot
KingoRoot
Pros:
  • Samsung multi-functional repair tool.
  • Improve phone performance.
Cons:
  • An unlocked bootloader is required.
  • Steps in a complex operation.
  • Possible security risks.
The above 6 Samsung unlock tools are popular among Android users. They provide convenience for those who need to access a locked Android with password. However, tools like Android Device Manager or Find My Device require the Google account information logged on your Samsung phone. The most time-saving choice is DroidKit, which aims to unlock Samsung screen lock and frp bypass plus some other Android management needs. Download DroidKit now and enjoy the best Samsung unlock tool ever!
