A Samsung S6 may need to be unlocked without a password for a variety of reasons, such as a locked screen or a lost password. This post covers five useful Samsung S6 unlock techniques, ranging from factory reset to Google account. Additionally, you will understand how to quickly unlock your smartphone without using a password via a reliable third-party tool. Let’s get started!
Download DroidKit now to unlock Samsung S6 without password or Google account. It provides the easiest way to access your Samsung S6. Support all Android devices.
Do you fail to access your Samsung S6 because of a forgotten password or Google account? Or maybe you purchased an old device that has an unreachable screen lock. This comprehensive Samsung S6 unlock guide covers how to unlock Samsung S6 without password. Read on to discover step-by-step methods to unlock your Samsung S6 hassle-free.
Also Read: Best Samsung FRP bypass tools
If you are locked out of your Samsung Galaxy S6, you can use a Google account to unlock it. The smartphone might request Google account details after several failed attempts to obtain passwords, PINs, or patterns. This procedure is ideal if you can recall your Google account password and have an Android device with Android 4.4 or lower. You could try another unlocking method if you forgot your account password.
You can only use this method to reset your lock screen if you’ve previously linked a Google account to your device.
For this method:
Step 1. Enter an incorrect password or pattern on the lock screen 5 times.
Step 2. Wait about 30 seconds until the “Forgot Pattern” option appears, then tap on it.
Samsung S6 Forgot Pattern
Step 3. Enter your backup PIN or log in with your Google account details.
Enter the Google account email and password associated with your device. Make sure it’s the same account you used when setting up the phone.
Step 4. Once unlocked, you can set a new unlock pattern for your device.
Using Google account to unlock Samsung S6 is limited to a few Android versions. If your Samsung S6 is not supported to unlock with the Google account, you can try the next methods.
If you find yourself locked out and unable to recall the password, having your Samsung S6 factory reset is always possible. This procedure, however, will eliminate all the data on your phone and return it to default settings, so ensure that you have some backup for essential information before proceeding.
To use this method:
Step 1. Turn off the Samsung S6 device. Keep holding the “Volume Up,” “Home,” and “Power” buttons.
Step 2. After a few seconds, a boot menu will appear. Use it to select “Wipe Data/Factory Reset.”
Scroll down to “Wipe data/factory reset”
Step 3. Confirm by selecting “Yes” to delete all data, then press the “Power” button.
Step 4. When the reset is done, you’ll see a message saying the data wipe is complete. Finally, restart your phone.
This method may remove the lock screen and allow you to use your smartphone, you may be required to log in using a Google account that was previously associated with the device owing to Google’s FRP or Factory Reset Protection.
Regaining efficient access to your phone can be done easily with Android Device Manager. Using your phone to unlock your device from another device is simple if it is online and connected to your Google account. If you’ve previously enabled Android Device Manager (now known as “Find My Device”) on your Samsung Galaxy S6, you can use it to unlock your phone remotely.
For this method:
Step 1. Sign in with the Google account associated with your locked phone in Android Device Manager.
Samsung S6 in Find My Device
Step 2. Select your device from the list and click the “Lock” option on the screen.
Find My Device Unlock Samsung S6
Step 3. Provide the necessary information to set a new lock screen password.
Another useful way to get back into your Samsung S6 is to use an unlock code. This method lets you get around the screen lock without a password, which is particularly useful for network-locked devices. You may have peace of mind and regain access to your phone by swiftly and effectively restoring its functionality with the right unlock code. To use this approach:
Step 1. Contact your carrier or a reliable source to get the Samsung S6 unlock code.
Step 2. Turn off your Samsung S6.
Step 3. Insert a SIM card from a different carrier into the device. Power on your phone.
Step 4. Wait for the screen to show the “SIM Network Unlock PIN” prompt.
Samsung Network Unlock PIN
Step 5. Enter your carrier’s unlock code, then tap “Unlock” to complete the process.
The above methods to unlock Samsung S6 require a logged Google account or an unlock code. What if you have nothing about them? Using a powerful Android unlocker like DroidKit will solve your problem quickly. No matter if you want to unlock the Android screen lock or bypass FRP after factory reset. DroidKit fixes them all on your Samsung S6.
Key Features:
Here are some simple steps to use Droidkit to unlock your Samsung S6:
Step 1. Start the process by installing Droidkit on your computer.
Step 2. Use a USB cable to connect your Samsung S6 to the PC. Choose “Screen Unlocker” from the main menu after launching the program.
Choose Screen Unlocker
Step 3. Click “Start” to begin the unlocking procedure. Then choose the “Device Connected” option. The software will create a configuration file; wait for this to finish.
Connect your Locked Phone
Step 4. After setup, click “Remove Now” to proceed.
Select the “Remove Now” Button
Step 5. Follow the prompts to enter Recovery Mode, then select “Wipe Cache Partition.” The software will start the unlocking process; please be patient until it is completed.
Step 6. Once finished, your Samsung S6 will restart, allowing access without a password.
The Lock Screen Is Removed Successfully
As we have mentioned above, DroidKit is good at FRP bypass too, including Samsung S6 FRP bypass. If you factory reset your Samsung S6 without password and then get stuck on the Google account verification page, you can use the DroidKit FRP bypass function.
The steps to get around FRP on your Samsung S6 are as follows:
Step 1. Open DroidKit on your PC, then choose “FRP Bypass” from the menu.
Click FRP Bypass
Step 2. Attach a USB cord to your computer and connect your Samsung S6.
Step 3. The tool will create a configuration file for your device. Make sure to keep your phone connected during this process. Once it’s ready, click “Start to Bypass.”
Launch the FRP Operation
Step 4. Select your Android version from the list that appears and click “Next.”
Step 5. To finish the Samsung S6 setup, adhere to the on-screen instructions.
Follow the Bypass Steps
Step 6. You will be able to unlock and control your smartphone without logging into your Google account after following these steps.
FRP Bypass Complete
To sum up, there are several methods to unlock the Samsung S6, such as using their Google account, performing a factory reset, or using the unlock code. Every technique offers a straightforward way to get back into the device. For the best results, consider using DroidKit, which streamlines the unlocking process while ensuring your data stays safe and secure.
