“I need 2 phones for my work and found my used samsung s22, but I forgot its screen password as I haven’t used it for a long time, how to factory reset it?” This is a question from a forum user. Many people may encounter similar situations. This article will show you 5 methods to solve this problem.
Currently, smartphones play an increasingly important role in our daily lives. Having no access to them can be a total disaster for young generations. If you also want to know how to factory reset Samsung S22/S22 Ultra without the password, don’t worry! This article will give you some advice.
Factory reset is an important operation. As long as you decide to do this, you may lose all your data on your device if you don’t have a backup. Therefore, before discussing how to factory reset a device without a password, it is necessary to figure out the situations to do so:
Having known these situations of Samsung S22 factory reset, let’s learn 5 effective ways to factory reset your locked Samsung device.
How to factory reset Samsung S22/S22 Ultra without a password? You can choose DroidKit, an all-in-one android toolkit. DroidKit is a comprehensive problem-solving software for Android, almost supporting all Android devices with Android Version 5 and above. It is a professional and trustworthy tool for Samsung users, which is easy to use. With just a few clicks, the difficulties of the device you met would be solved.
Main Features:
Let’s learn how to use DroidKit step by step:
Step 1. Download and install DroidKit on your computer. Connect your Samsung S22 to the computer with a USB cable. Then choose the Screen Unlocker option.
Choose Screen Unlocker
Step 2. Choose Start first, and then click Device Connect. Make sure your Samsung device is connected to your computer.
Connect Your Device and Computer
Step 3. After the device configuration file is prepared, choose Remove Now.
Preparing the Configuration File
Step 4. Choose the correct device brand, Samsung. Then tap on Next to continue the process.
Choose Your Device Brand
Step 5. Follow the instructions on the screen to enter recovery mode on Samsung S22. Choose “Wipe data/factory reset”.
Remove the Screen Password
Step 6. After the process is completed, you can see the “Screen Lock Removal Completed” page on your screen, and your Samsung S22 is successfully restored to factory reset.
Remove Screen Lock
DroidKit can effectively factory reset your Samsung S22 and simplify the process. With just a few clicks, you can restore your phone to the original system state even if you cannot remember the screen password.
Google Find My Device is another method to factory reset your Samsung S22 without the password, which can be applied to all Android devices. However, if the “Device Protection” feature is enabled on your Samsung S22, you would be asked to use a Google account to complete device activation. Make sure that you remember the Google account credentials and Find My Device is enabled beforehand. These are the steps:
Step 1. Open your browser and visit the Google Find My Device Website.
Step 2. Log in to your Google account.
Step 3. Select the device you want to reset on the left of the page.
Step 4. Click ERASE DEVICE and confirm the action.
Erase Data on Samsung
Step 5. Then you would be asked to verify your Google account. After entering the necessary details, click Erase to complete the final confirmation.
Step 6. Complete the whole process of factory reset. Your Samsung device will be reset and the data will be erased.
This method may ask you to provide the used Google account. If you don’t have it, you can choose another method.
Using Samsung Find My Mobile is another choice to restore your Samsung S22 to factory settings. Similar to Google Find My Device, you should remember your Samsung account credentials, and the Find My Mobile feature should be enabled in advance. The stepwise guide is as follows:
Step 1. Open your browser and visit the Samsung Find My Mobile website.
Step 2. Log in to your Samsung account and enter the password. You may be asked to enter another verification code.
Step 3. Select your Samsung S22/S22 Ultra from the list of devices associated with your account.
Step 4. Click the Unlock option on the left side of the page, and follow the subsequent operations.
Step 5. Click the Wipe Data option and confirm the operation. Then the factory reset operation will begin and the device will be reset to factory settings.
Samsung Find My Mobile is one of the methods to restore your device to its original system state, while it has some preconditions. It is essential to make sure you meet all those conditions.
After introducing some methods that need both a phone and computer, there is a method that only needs your phone—Recovery Mode. But this method will clear the entire mobile system, and it is inevitable. So, you’d better back up the data on your Samsung S22 first. The step-by-step guide is below:
Step 1. Power off your Samsung device:
Press and hold the Power button until “Power off” appears on the screen. Click “Power off” to shut down your Samsung S22.
Turn off Your Device
Step 2. Enter the recovery mode:
Press and hold the Volume Up, Home, and Power button at the same time. When the Samsung logo appears on the screen, release the Power button while still holding the Home and Volume Up buttons. Then, you can enter the recovery mode.
Enter Recovery Mode
Step 3. Choose “Wipe data/factory reset”:
Select “Wipe data/factory reset” via the Volume buttons and press the Power button to confirm it.
Select Wipe Data/Factory Reset
Step 4. Choose “Yes” to confirm erasing data:
Select “Yes – delete all user data” to erase data on your device.
Delete Data on Samsung
Step 5. Choose “reboot system now”:
After the deletion is completed, select “reboot system now”, and your Samsung device will be restored to factory settings.
Factory Reset your Samsung
Factory resetting your Samsung S22/S22 Ultra via recovery mode is convenient for users who don’t have their computers around. However, data loss might be a big trouble making them a headache.
Another method to factory reset your device without the password is to use a hidden factory reset code, but it is not applied to every type of Samsung device. You can try it. If it doesn’t work, you can choose another method. Here are steps:
Step 1. Tap the “Emergency Call” button on the locked screen.
Step 2. Type “*2767*3855#”
Step 3. Wait for the factory reset process to complete.
Similar to recovery mode, it erases all data on your Samsung S22.
Facing the dilemma of how to factory reset your Samsung S22 without the password, we mentioned 5 ways in this article: using DroidKit, Google Find My Device, Samsung Find My Mobile, recovery mode, and factory reset code. We recommend you choose DroidKit, which is professional and safe to protect your privacy. Download it for free, try it now!
