If you want to know about FRP bypass, this article offers easy methods for the Samsung M21 FRP Bypass.
Do you have a habit of forgetting your passwords all the time? It’s hard to remember all of them at once. Where would you keep all your passwords? Maybe in the notes on your phone. What if you forget the Google account password itself? You happen to factory reset your device or maybe forget the lock screen password/PIN code/Pattern.
Don’t worry! We got you. This article offers three methods for Samsung M21 FRP Bypass. Let’s learn about what FRP (Factory Reset Protection) is and why it’s important.
Yes, it might be necessary in some scenarios. We shall discuss them but before that let’s see what Factory Reset Protection is.
Factory Reset Protection (FRP) is a security feature that comes with Android Version 5.1 and later. It protects your device against unwanted access in case of theft or lost and found.
When you make a Google account on your Samsung M21 or any Android phone, the FRP lock is automatically set.
Moving to the reasons to FRP bypass now.
There are several reasons that warrant FRP bypass. Like,
We strongly advise against bypassing FRP on stolen phones. The information we discuss here should be used in accordance with the law.
Let’s find out how to bypass the FRP lock.
Like all Android phones, bypassing the FRP lock on the Samsung M21 is not difficult. We bring you three methods to FRP bypass your device. Each method is mentioned in a step-by-step fashion. You will find it helpful.
Without delay, let’s move on.
The first method is the most convenient method of Samsung M21 FRP Bypass.
Droidkit by iMobie is the perfect Android toolkit. It offers several features, from removing lock screen locks to moving phone data around. It can recover photos, WhatsApp chats, messages, and more without root. You can use it to fix system issues and transfer, manage, and back up any data from one place.
One tool of DroidKit that is worth mentioning here is FRP Bypass. Easy and reliable for almost any Android phone that attempts to FRP lock up your phone.
Let’s see how we can do it.
Step 1 – Download and Install the tool
Download the latest version of DroidKit from the Website. Launch the tool. Choose the FRP Bypass mode.
Choose FRP Bypass Mode
Step 2 – DroidKit FRP Bypass tool
The FRP Bypass window opens up. Connect your Samsung M21 to the computer using a USB cable. Click on the Start button.
Step 3 – Select the Brand Name
Select the brand name of your device, which in this case is Samsung. The process will start. It can take a while, so please stay patient.
Choose Device Brand
Step 4 – Start to Bypass
When the window says the Configuration File Preparation is Done, click the Start to Bypass button.
Tap on Start to Bypass
Select the Android version you are using on your device to proceed.
Choose System Version
Step 5 – Almost there!
Follow the on-screen instructions. Click on the Reset button.
Click Reset
Bypassing the FRP lock can take time. Wait! Click on the Done button when the process is complete.
FRP Bypass Complete
There’s another way to FRP bypass your device. It is by using the Talkback feature.
You are not going to like it. Trust us! It does work. It is somewhat technical and time-consuming.
We will go through it step by step, along with picture illustrations where needed. Let’s go!
Step 1 – Initiating the process
Restart your device. Connect it to a stable WiFi. After connecting, go back to the Start screen.
Connect to Nearby WiFi Network
Step 2 – Calling on Talkback to help!
Draw the J on the screen. As soon as Talkback shows up, select the Use Voice commands option. Speak to say, Open YouTube. Disable the Talkback now by pressing and holding your device’s Volume Up and Power buttons.
Activate Talkback
Step 3 – YouTube coming to the rescue
On YouTube, go to the Settings. Tap on the About. Tap on the YouTube Terms of Service.
Get Out of YouTube
Step 4 – Open Google Chrome
The browser opens up after the previous step. In the search bar, type https://tiny.cc/frptools \s or https://bit.ly/2NKxXYs. Access the FRP bypass APK. Select the Tap To Open FRP APPS. Go to the Galaxy Store, click on Open > Click to Open.
Enter the Galaxy Store app
Step 5 – OS14 Launcher application
You are taken to the Galaxy Store and search for the OS14 Launcher. Install and Open the application. Sign in with your Google account if the Galaxy Store asks.
Step 6 – Install APK Files from the Google Chrome
Go back to the browser. Download the Notification Bar APK and Package Disabler Pro. Install these files on your phone.
Step 7 – Assistant Menu to Restore Data
Go to the Settings. Then, select Accessibility. Select Interaction and dexterity. Activate the Assistant Menu.
Activate Assistant Menu
Tap on the Select Assistant menu items. Go to Accounts and backup. Tap on Restore Data. Press the Assistant menu and then Restore Data.
Tap on the Assistant Menu Button
Step 8 – Notification bar installation
Press the Back key to restore applications. Tap Done on its completion. Return to the menu and find the Notification Bar APK. Select Installed Services > Accessibility. Give Notification Bar permission > Allow Only Certain Notifications > Enable the notification bar. Pull down the notification bar to see if it’s working.
Install Notification Bar APK
Step 9 – Install Package Disable Pro
Go to the phone Settings > Privacy > Permission Manager Media and Files. Tap on the three dots to proceed. Then, Display System Search > Choose Package Disabler Pro > Allow file management.
Step 10 – Last few steps!
Turn off the device’s WiFi and mobile data. Open the Package Disabler Pro. Check the box that says I Agree and tap on Enable Admin. Turn on WiFi or Mobile Data. Tap Agree. The app will let you know that Know license validation is completed. It can take a while.
Step 11 – Be careful with these final steps.
Search for Android Setup in the application. Choose and then Disable it. Choose Samsung Setup Wizard. Return now and set up the basic steps. Your device has been bypassed successfully.
FRP Bypassed Your Samsung M11 Successfully
FRP bypass is always challenging without a PC. You can FRP bypass the Android 11 and 12 OS versions of your Samsung M21 with the Google Keyboard method.
Without further delay, let’s get to it.
Step 1 – Get to the Help page
Switch on your Samsung M21 by pressing the Power button. Select a language and connect with a stable WiFi network. Now, you will be asked for the password of the previous Google account, which wasn’t logged out before the factory reset.
Tap on the text field, and when the keyboard shows up, tap and hold the @ key to go to the Settings menu. Now, choose Google Keyboard Settings. In the top right corner, tap the three dots and select Help & Feedback from the menu.
FRP Bypass via Google Keyboard
Step 2 – Get to the Settings Menu
Once the Help page appears, tap the Use Google Keyboard option. Tap and hold the screen to select any text, and then tap on Websearch in the top right corner. A search bar will show up. Now type Settings and tap on Settings from the search results.
Go to Settings Menu
Step 3 – FRP Bypass
Find and tap on About phone. Tap on the Software information and find the Build Number option. Tap on the Build Number seven times to switch on the Developer mode. Go back and tap on the Developer options.
tap on the Build Number icon
After the Developer options show up, tap on OEM Unlocking and tap on Back twice.
Allow OEM unlocking pop-up
Restart the device and connect to the WiFi network again. You will have to add a new Google account.
Let’s conclude the article.
That’s all about the Samsung M21 FRP bypass! We have provided you with two ways of doing it.
DroidKit is the go-to tool to bypass FRP Samsung M21. It offers many other features, like, a screen unlocker, data recovery, data extractor, data manager, and system cleaner.
Using the TalkBack feature to FRP bypass Samsung M21 is very technical. It is a very long technical method to FRP bypass earlier Android versions. It might only sometimes be effective for devices with the latest Android versions.
The Google Keyboard method is less energy draining than the Talkback method. The easiest method with a 100% guarantee is DroidKit.
We hope that you find this article helpful.
