If you are locked out of your phone because you forgot your Google account password, you will have to perform the Bypass FRP. The best method to perform Samsung M11 FRP Bypass is to use professional tools.
Download DroidKit to bypass FRP on Samsung M11 without Google account or password. Supports all Samsung phones and tablets running Android 6 to 14 system. No technical skills are required. Friendly to every Android user.
The FRP feature on Samsung is a security tool. It protects the device against hacking, data misuse, or malware issues. Using FRP, users can’t access their phones without a synced Google account. It can be an issue if you lose access to your phone. This will also cause you frustration. This is when Samsung M11 FRP Unlock Tools come into use. Now, we will move on to the details of the FRP Bypass.
Also Read: How to unlock Samsung pattern without losing data
It’s hard to remove FRP on Samsung M11 if you don’t have the Google account information. But bypass FRP on Samsung M11 can be an easy thing. Using a third-party FRP bypass tool will help you regain access to your Samsung M11. DroidKit, as a complete Android device manager, is the best choice as a Samsung M11 FRP Unlock tool. With DroidKit, you can quickly bypass FRP on kinds of Android devices besides Samsung M11. Download DroidK first and follow the steps to bypass FRP on Samsung M11 now.
1. Launch DroidKit on your computer. Then, choose the FRP Bypass mode after launching it.
Choose FRP Bypass Mode
2. Then, connect the phone to the computer by using a USB cable and click the Start button. The software will automatically detect your phone. Then it will proceed with the Device Configuration File. If there is an issue with phone detection, try changing the USB cable. In this case, click OK on the screen that appears.
Connect the Device and Click Start
3. Now, choose your phone model and click the Start button.
Choose Device Brand
4. Now, it will begin preparing the Device Configuration File. After the process completion, click the Start to Bypass button.
Tap on Start to Bypass
5. Now, choose the boot screen. DroidKit has five boot screens according to different mobile versions and models.
Choose System Version
6. Now, go to enter the current password interface for the device. After this, follow the instructions that appear. Then, click the Reset button on the app.
Click Reset
7. The Bypass FRP lock process will start now. After the Bypass FRP process is completed, your phone will restart. Then, the FRP lock will be removed successfully.
FRP Bypass Complete
Now, we will look into other methods for the Bypass FRP.
You don’t have to worry if you don’t have a computer/PC. Using the Talkback method, we can remove the FRP lock.
Here are the steps to perform Bypass FRP on Samsung M11:
1. Power on your Samsung M11 and click on Start. Agree with the terms and conditions and click Next. Now, on the Wi-Fi page, select your Wi-Fi connection.
Choose WiFi Network in Samsung M11
2. Now, press the Power and Volume increase buttons simultaneously. Click the Use button, then again press the Power and Volume Up button. This will enable Talkback.
Activate TalkBack in Samsung M11
3. Now, draw a reversed L on your screen and click Use voice commands.
Click Use Voice Commands in Samsung M11
4. Now, say, open Google Assistant. As the “Welcome to Bixby” screen appears deactivate Talkback by pressing the volume up button and Power keys simultaneously.
5. Then, Tap on the “Sign in” button and sign in using your Samsung account. Next, check all the circles and then tap on “Agree.” Tap on “Cancel” when the pop-up appears.
Sign in to Samsung Account
6. Tap on the Start button. After this, the Bixby main screen will appear. Click on the Mic icon and say “Open YouTube”. Once you are on YouTube, tap on the Profile icon > Settings > About > YouTube Terms of Service.
Tapping On YouTube Terms and Services
7. Then, the “Welcome to Chrome” screen will appear. Tap on “Accept & continue”. On the next screen tap on “No Thanks” to avoid syncing.
8. On the Chrome search bar, type this URL: https://frpfile.com/bypass, and hit enter.
9. Scroll down and tap on “Open Setting App”. Settings app will open. Here you can view your signed-in account.
Open Settings App
10. Get another Samsung phone and log in with the same Samsung account you used on the previous phone.
11. Now, tap on Chrome on this phone. Tap on “Accept & continue”, then tap on “No, Thanks” In the search bar, type the following: https://frpfile.com/bypass.
12. Scroll down and tap on “Alliance Shield App.” It will start downloading the app. A pop-up will appear, tap on “Settings,” and now enable “Allow from this source.” Now go back, a pop-up will appear again, tap on “Install.”
Install Alliance Shield
13. After the installation, go to Settings > Accounts > Backup, check the “Apps” and “Home screen,” to enable backup, and tap on “Back up now”.
Backup Data in Samsung M11
14. After the backup, go to your FRP lock phone (on the previous phone). Tap on Settings > Accounts and Backup > Restore Data > Update Cloud.
Backup Data and Update Cloud in Samsung M11
15. Wait for a few seconds. Again tap on Restore Data. Select another Samsung phone you used from available options. Select “Apps” and “Alliance Shield X” and hit Done.
16. On the screen that appears, tap on “Restore.” and hit “Install” to initiate app installation. Once installation is complete, go back to the https://frpfile.com/bypass and tap on “Alliance Shield.”
Backup Alliance Shield X App
17. The Alliance Sheild X app will open. Log in or register into the app. Tap “Next” to grant access to the app, and tap “Agree” to grant the app permission. Add the device name and hit finish.
18. Inside the Alliance Sheild X app, tap on “App Manager.” On the next screen, check the box next to “Don’t Show This Next Time”. Now tap on the Close button.
19. Search “Mode” in the search bar. Scroll down to “Service mode” and tap on it. Then tap on “Open,” select the DM + MODEM + ADB option and tap on “Ok.”
20. Now, connect your phone to the PC/laptop using a USB cable.
21. Open the FRP File tool on your PC/laptop, click on the folder “ADBFRP Tool,” and then click on the file “ADBFRP Tool.”
Open FRP File on PC
22. The “ADB Bypass FRP Tool” screen will appear. It will show the “OFFLINE” status for your connected phone.
23. Now, after this, a pop-up will appear on your phone. Check the “Always allow from this computer” option and tap “Allow.”
24. After granting permission on the phone, your phone status will appear as “ONLINE” on the “ADB FRP Bypass Tool” on the PC. Now tap on “Remove FRP,” then click “Ok.”
Online Status of Your Phone in ABD Bypass FRP Tool
25. A pop-up will appear on your phone. Tap on “Allow”.
26. The FRP Bypass process was successful. Now, restart your phone. A “Starting Android” screen will appear. Tap anywhere on the screen to continue. Now tap on the “App Cloud” icon and tap “Always.”
27. After your phone starts, tap on “Settings”.
28. Now in “Settings”, tap on “General Management.” Now scroll down and tap on “Reset.”
29. In the Reset screen, tap “Factory data reset,” and next tap on the Reset button and the Delete All button.
Reset Your Phone to Factory Settings
Now, your FRP Bypass process is completed. Here is another method to Bypass FRP using the APK tool.
You can also reaccess your phone using APK tools to perform Samsung M11 FRP Unlock.
These are the steps to do Bypass FRP using the APK files:
Yes, some methods exist to perform a Samsung M11 FRP Bypass free. You can use an OTG cable to connect the phone to a PC, a flash drive, or APK files to remove the FRP lock from your phone.
The FRP lock in a Samsung M11 is a security feature that protects your phone after a factory reset in an untrusted environment. This lock is automatically enabled when you have signed in with a Google account on your Samsung device.
FRP is great for keeping your phone secure. However, forgetting your password and being unable to access your phone is a huge issue. But no worries! This article provides a step-by-step guide on using a professional Samsung M11 FRP Unlock Tool and discusses the most straightforward methods for Samsung M11 FRP Bypass. It also uses APK files and the Talkback feature to Bypass FRP. Go ahead and try these methods to Bypass FRP on your Samsung M11.
