In this article, you will explore all about the Samsung M01 FRP unlock tool. You will learn what FRP is and how you can use a tool like DroidKit to bypass it in just three minutes. You will also discover a few ways for Samsung M01 Core FRP bypass.
Whether you have forgotten your password or purchased a second-hand device, DroidKit is your best choice. As a professional FRP Unlock Tool, it can quickly and safely help you unlock the Samsung M01 FRP lock and restore the device to normal use.
Are you locked out of your Samsung M01 because of the FRP lock? Do you want to unlock it and regain access to your device? If yes, you are not alone! Many Samsung M01 users face this issue and have no clue what to do. While the FRP feature protects your device, it can also cause trouble when you forget your Google account credentials linked to it. In this situation, you will need a Samsung M01 FRP unlock tool. It will help you remove the FRP lock. If you don’t know any, don’t worry!
This article will explore the best FRP unlock tool. We will also walk you through the step-by-step guide to use it and remove the FRP lock in just three minutes. Let’s dive in!
The Samsung Galaxy M01 is a budget-friendly smartphone, best to fulfill your basic daily needs. With this phone, you can make calls, text, and use the browser. It offers all the basic features that other smartphones offer. However, it is less expensive.
samsung galaxy m01
Samsung Galaxy M01 comes with a moderate screen size and a durable battery. Here are some key specs and model details for this smartphone:
Feature | Specification |
Model Name | Samsung Galaxy M01 |
Launch Date | June 2020 |
Display | 5.7 inches, PLS TFT LCD |
Resolution | 720 x 1520 pixels |
Processor | Qualcomm Snapdragon 439 |
RAM | 3GB |
Internal Storage | 32GB |
Rear Camera | Dual 13MP + 2MP |
Front Camera | 5MP |
Battery | 4000mAh, non-removable |
Operating System | Android 10, upgradable to Android 11 |
Colors Available | Black, Blue, Red |
Now that we have explored the specs of the Samsung Galaxy M01, let’s move forward and learn about why we need to bypass the FRP lock in this device.
FRP/Factory Reset Protection is a security feature in Android devices from version 5 to the latest ones. This feature is developed by Google and is incorporated into all Android devices, including Samsung M01. This feature automatically turns on when you register and log in to a Google account on your device.
The purpose of FRP lock is to secure your phone, specifically Android phones like the Samsung Galaxy M01. When this lock is enabled, you need to enter your Google account details to use your phone after a reset.
But you could get locked out if you forget your account info or buy a used phone with FRP active. This can be frustrating. In this case, unlocking the FRP lock is needed. You cannot access your phone features without unlocking this lock.
This is where the Samsung M01 FRP unlock tool comes in. It gives you control of the phone again. You don’t need your or the previous owner’s Google account details. You can unlock and use your phone right away without anyone’s help.
However, this can be a problem if you purchase a secondhand phone with FRP active or forget your own Google account details. In such cases, the Samsung M01 FRP unlock tool comes to the rescue. Let’s explore the best one in the next section!
When it comes to the Samsung M01 FRP unlock tool, DroidKit wins all the crowns. It is the most reliable and effective way to do the job. One of the best things about this tool is its user interface. No matter to which background you belog, have tech knowledge or not, you can easily use this tool. There is no need to be a tech expert.
DroidKit is also known as the one-stop solution for all Android-related issues. It is not just limited to bypassing the FRP lock. This powerful tool is equipped with many other useful features. Let’s find out what it has for all of the Android users out there.
After installing DroidKit (without ads and plugins) on your computer, you can also:
Step 1: First, download and install the DroidKit on your PC/laptop. Once the installation is done, open the software and select “FRP Bypass” from the options.
Choose FRP Bypass Mode
Step 2: Now, connect your Samsung M01 to your PC via a USB cable. DroidKit will start recognizing the device. Once done, click “Start” and select “Samsung” as your device brand.
Choose Device Brand
Step 3: Next, DroidKit will start preparing the configuration file for your Samsung M01. Once done, click “Start to Bypass” and proceed.
Click Start to Bypass
Step 4: Now select the system version of your Samsung M01 and click the “Next” button. Remember, The boot screen varies from the Android version. DroidKit provides five boot-screen views for reference. Select accordingly.
Choose System Version
1.Please confirm the Android system version you selected is right, or the bypass will probably fail.
2.The tablet series option supports Android 9 and later versions for tablets, while for Android 8 and earlier versions, it is recommended to use Android 6 or Android 7/8.
Step 5: Now, you need to go to the “Enter your current password” interface. Follow the on-screen instructions to complete the corresponding settings. After entering the factory mode, click the “Reset” button.
Go to Enter your Current Password Interface and Click Reset
Step 6: After clicking reset, DroidKit will start bypassing the FRP lock on your Samsung M01. Once the process is completed, you will see the below interface.
FRP Bypass Complete
Thats it! Just a few clicks, and you will make your Samsung M01 device functional again. Although there are various tools and methods to bypass the FRP lock, DroidKit stands out due to its ease of use and effectiveness.
If you are dealing with Samsung M01 Core FRP bypass, there are various methods to do so. However, each of them may vary in ease and effectiveness. You can try to find a special tool or app. Some people say you can do it by yourself, but it’s hard. Be careful when trying these methods. You might damage your phone.
Here are some other methods for Samsung M01 Core FRP bypass:
Sometimes, Samsung provides official tools or customer support for bypassing FRP. You can visit their official website or call them for assistance.
This method requires the IMEI number or serial number of the device. This information can usually be found on the back of the device or on the box.
At the same time, Samsung may ask the user to provide proof of purchase or other relevant documents to verify the legal ownership of the device. Once verified, Samsung will remotely unlock the user’s device. This process is usually completed online, and the user does not need to send the device to Samsung.
If you remember your Google account but can’t log in, try resetting your password. Once it’s changed, you will be able to enter it on your FRP-locked device.
How to reset your Google Account password:
Step 1. Visit the Google login page. Enter your Google account email address and click “Next”. Select “Forgot your password?“: On the password input page, click the “Forgot your password?” link.
Step 2. Google will ask you to answer a few questions to verify your identity. You may be asked to choose to verify your identity through a mobile verification code, an alternative email address, or answer security questions. Select the verification method that suits you and follow the prompts.
Step 3. After successful verification, you will be directed to the “Create a new password” page. Enter a new password.
Step 4. Click the “Change password” button to complete the password reset process.
This method is especially effective for those who are familiar with the operation of Android devices. By installing a dedicated FRP bypass app, you can easily bypass Samsung M01/ Samsung M01 Core FRP.
Step 1: In the device’s setup wizard, connect to a Wi-Fi network and proceed until the device asks for Google account information.
Before you proceed, you need to restore your device to factory settings and then perform the initial setup. This includes basic settings such as selecting a language and connecting to a Wi-Fi network. After completing these steps, the device will prompt you to enter the Google account information associated with the device. This is the verification process for the FRP lock.
Please remember to back up important data in advance.
Step 2: When you get to the Google account login page, tap the text on the page (such as “Email Address” or “Password”) to highlight it, then tap the three-dot menu icon in the upper-right corner. In the menu that appears, select “Help & Feedback” or “Terms of Use.”
Step 3: On the “Help & Feedback” page, tap any feedback item and select “Open in Browser.” This will open your device’s web browser.
Step 4: In the browser, search for and download the app called “FRP Bypass APK.” Please note that downloading third-party apps can be risky, so get it from a trusted source.
Step 5: Once the download is complete, tap the file to begin the installation. You may be prompted to allow the installation of apps from unknown sources, so enable this permission in Settings.
Step 6: Once the installation is complete, open the FRP Bypass app and tap “Settings” to enter the device’s settings page.
Step 7: In Settings, find and select “Backup & reset” or “About phone”, then select “Reset factory settings” or “Erase all data”. Confirm the operation and the device will reset and restart.
Step 8: After the restart, you will be able to set up the device without entering the Google account information again, thus successfully bypassing the FRP lock.
In addition to the above method, you can also bypass the FRP lock on Samsung M01 and Samsung M01 Core by calling the emergency number. This method does not require any additional tools.
Step 1: Again, first connect the device to a Wi-Fi network and enter the page that asks you to enter your Google account information.
Step 2: On the Google account verification page, click the “Emergency Call” button to enter the dialer interface.
Step 3: Enter “*#0808#” or other specific code on the dialer interface (you can try *#9090# or *#7284#, the specific code may vary from device to device). This will open the USB settings or Service Mode menu.
Step 4: On the USB settings page, select “DM+ACM+ADB” mode or similar options (may vary from device to device). This will allow the device to interact more extensively with the computer via USB.
Step 5: Connect the device to a computer via USB and use third-party tools such as Odin or other tools to flash custom firmware or unlock tools to bypass the FRP lock.
Step 6: After completing the setup, restart the device and follow the prompts to complete the initial setup to successfully bypass the FRP lock.
If you are an Android user and do not want to use a computer, we recommend you to use Method 2 or Method 3 to bypass your Samsung M01 FRP lock. If you do not have technical knowledge and want to completely solve the Google FRP lock problem as soon as possible, consider using DroidKit. It is one of the best Samsung M01 FRP unlock tools that can help you remove FRP lock in just three minutes. You do not need to go through arduous steps. Just a few clicks and you are done! It also offers many other features. It can help you solve all Android-related problems while bypassing Samsung M01 FRP.
