Factory Reset Protection (FRP) is a Google security feature that prevents unauthorized access to your device after a factory reset. While it’s essential for protecting your data, it can become an obstacle if you forget your Google account credentials. This guide explains how to bypass FRP on a Samsung J8.
FRP is activated when you link a Google account to a Samsung device, such as the Galaxy J8. After a factory reset, the phone will ask for the previously linked Google account credentials. If you forget your login details, here are two methods to bypass FRP:
DroidKit is a versatile Android tool designed to fix various issues, especially for Samsung devices. It offers several useful features, including Samsung J4 FRP bypass. Besides that, it helps with data recovery, system repairs, and device content management.
With its wide range of functions, DroidKit tackles common problems Android users face. Whether you’re trying to regain control of your device or recover important data, DroidKit is a reliable solution.
Key Features of DroidKit:
Steps to Factory Reset S21 Without Password via DroidKit:
Step 1. Download DroidKit on your PC. Install it and connect your S21 to the PC using a USB cable.
Step 2. Launch DroidKit and select the “FRP Bypass” mode from the main interface.
Step 3. Then make sure your device is connected with the PC stably. Choose your brand and click “Start” from the new window.
Step 4. DroidKit will prepare the configuration profile. Once complete, click the “Start to Bypass” button.
Step 5: After clicking the start to bypass button, select the OS of your device. Then, click the “Next” button and proceed.
Step 6: Now, navigate to the “Enter your current password interface” and follow the on-screen instructions to enter factory mode. Once you have done so, click the “Reset” button.
Step 7: After clicking the reset button, DroidKit will start the Samsung J4 FRP bypass process. Once completed, you will see the below interface.
– If not already done, go to Settings > General Management > Reset > Factory Data Reset.
– Set up the phone and connect to Wi-Fi. On the Google verification screen, tap the @ symbol, then Google Keyboard Settings > Help & Feedback.
– In Help & Feedback, select any topic, then tap Use Google Search. Search for and open Chrome.
– Find and download a trusted FRP bypass APK. Install it by navigating to Downloads.
– Open the app, go to Settings > Accounts, and add a new Google account.
– Restart the device, and it will no longer ask for the previous account details.
If these methods don’t work, contact Samsung Support. You will need proof of ownership, like a receipt or original packaging.
Contacting Samsung
Bypassing FRP on a Samsung J8 can be done using a PC or APK method, but always follow legal and ethical guidelines. To avoid future issues, keep your account information updated and disable FRP before selling or gifting your device. DroidKit is a comprehensive tool to fix all kinds of Android issues, try it now!
