This article offers easy solutions for Samsung J5/J5 Prime FRP bypass with and without a PC. We’ve covered everything from dedicated bypass tools like DroidKit and Odin to manual steps using Talkback and Google Keyboard.
DroidKit allows you to bypass FRP on Samsung J5 and J5 Prime in an easy way. Download it now and fix Samsung J5 stuck on FRP lock page issues effortlessly. Support all Samsung phones running Android 6 to 15.
Are you stuck on the Google sign-in screen but don’t remember the passcode? Do you want to bypass it and start using your phone without worries? You’re in luck! This article will provide a complete guide on the Samsung J5 FRP bypass with and without using a PC. These solutions also work seamlessly for Samsung J5 Prime FRP bypass. So, regardless of your device, this guide will help you unlock your phone effortlessly! Ready for it? Let’s go!
You may also like: How to bypass FRP on Samsung A13
This section will show you how to remove the FRP screen using a PC. Whether you’re looking for a quick and effortless solution or a dedicated bypass tool, we’ve got you covered!
Do you want the easiest way to bypass the Google account on the Samsung J5? DoridKit is just what you need. It offers a one-click solution to bypass the Google account on Samsung J5/J5 Prime! Moreover, it is fully compatible with Android 6, 7, 8, and higher, allowing you to remove the FRP screen without any issues. The best part? You don’t need to go through any technical steps! Here are the advantages of using DroidKit for Samsung J5/J5 Prime FRP bypass:
Step 1. Open DroidKit on your PC. Select the “FRP Bypass” tool from the main screen. A new window will open.
Choose FRP Bypass Mode
Step 2. Connect your J5/J5 Prime to the PC. Click the “Start” button and select Samsung as your phone’s brand.
Click Start
Step 3. DroidKit will start downloading the configuration profile for your device. Wait for it to complete. Then click “Start to Bypass.”
Tap on Start to Bypass
Step 4. Choose your phone’s Android version from the next window. You can verify it from the picture of the boot screen. Then click “Next” to proceed.
Choose System Version and Click Next
Step 5. To bypass the FRP lock, follow the on-screen steps. Once you are done, click the “Reset” button.
Follow the On-Screen Guide and Click Reset
Step 6. DroidKit will start removing the Google lock. Once the process is complete, you can verify it using the window shown below.
FRP Bypass Complete
Let’s move on to the next Samsung J5 Prime FRP bypass solution!
Odin offers an easy and quick way to remove the Google lock on J5/J5 Prime. It is a firmware flashing tool that erases all the data on your phone, including the FRP lock.
Here’s how you can use it.
Step 1. Download the firmware combination files from SamMobile. Install the latest Odin software and launch it.
Step 2. Click the “AP/CP/CSC” buttons and select the respective files for each option.
Step 3. Turn off your J5/J5 Prime. Press the Home, Volume Down, and Power buttons until you get a Warning message. Then press the Volume Up button once to enter Download Mode.
Step 4. Odin will detect your device. You can verify it by looking for a blue box above “ID: COM.” Click “Start” to begin flashing.
Bypass FRP on PC with ODIN
That’s how the Samsung J5 FRP bypass with Odin works!
Also Read: How to fix Android stuck on Odin mode
If you don’t want to use a computer or download additional software, don’t worry. You can use the Google keyboard and Talkback to remove the FRP lock with your phone.
Google Keyboard offers a straightforward solution for Samsung J5 FRP bypass without a PC. Let’s see how to use it.
Step 1. Turn on your phone and tap the text box on the Google sign-in screen. The Google keyboard will appear.
Step 2. Tap and hold the “@” button until the Settings menu appears. Press “Keyboard Settings” and click the three dots at the top right. Then, select “Help & Feedback.”
Open Keyboard Settings
Step 3. Choose the “Using Google Keyboard” option. Then, click and hold any text on the page and open Websearch.
Step 4. Type “Settings” in the search box to open the Settings menu. Then, scroll down and click “About device.”
Step 5. Tap your phone’s “Build number” seven times. Then, go back to the settings and press the “Developer options.” Then, turn the toggle on for “OEM unlocking.”
Click on Developer options.
Reboot your phone and add a new Google account to bypass Samsung J5 FRP without a PC.
You may also like: How to fix Samsung keyboard keeps stopping
Talkback is an accessibility service available in both J5 and J5 Prime. You can use it to get past the Google lock screen and download an FRP bypass tool on your phone.
So, how does it work?
Step 1. Press and hold two fingers on the Welcome screen to enable Talkback. Then, draw an L on the screen.
Step 2. A menu will appear. Select “Talkback Settings” from here. Scroll down and turn on “Single-tap activation”
Tap on TalkBack Settings to Proceed
Step 3. Scroll up and select “Text to speech Settings.” Tap the gear icon next to “Samsung text to speech…”
Open Samsung Text-to-Speech Settings
Step 4. Choose “Settings for Samsung text-to-speech.” Click the code number under “Version” to open the Galaxy Store. Press the Home button three times to turn off Talkback.
Press the Version Code
Step 5. Search for “Samsung Internet browser” in the Galaxy store and open it.
Search and Open Samsung Internet
Step 6. Search for the FRP Bypass website. Open any site and download the FRP Bypass and Google Account Manager files.
Step 7. Click “Open” after installing the FRP Bypass app and use the on-screen guide to sign in to a new Google account.
Go to the FRP Bypass Website
You can use the new account details to bypass the FRP lock!
Do you want to prevent an FRP lock on your J5 or J5 Prime in the future? Here are some key factors to consider.
That’s all! We have shared three practical solutions for the Samsung J5 FRP bypass. You can easily bypass the Google account on your Samsung J5/J5 Prime using Talkback, Google Keyboard, Odin, or Droidkit. While all methods are effective, consider using DroidKit for a one-click solution to bypass FRP and unlock your phone effortlessly.
