14 Best Samsung FRP Tools for FRP Bypass 2025
Locked out of Google account verification on Samsung? Don’t worry, read this post to know top 14 Samsung FRP tools with thier key features and choose the suitable one to bypass FRP on your Samsung phones or tablets.
Author Avatar Joy Taylor Last Updated: Mar. 07, 2025
DroidKit – Bypass FRP on Samsung in Easy Steps
Free download DroidKit to bypass Google lock on Samsung without account credentials. As the best Samsung FRP tool, Droidkit helps to bypass Google accounts for all Samsung with Android OS 6 -15. No technical knowledge is required.
To bypass FRP on Samsung phones, you should first log into your Google account. But if you don’t know the account or password, you may need a third-party tool for Samsung FRP bypass to get out of a Google-locked phone. Which Samsung FRP tool is the best and how do you choose a suitable one? This article lists 14 Samsung FRP bypass tools with their introduction and features. Check the following part and find out the best Samsung FRP tool effortlessly.
1. Droidkit – Best Samsung FRP Bypass Tool [Easy & Secure]
When you search for Samsung FRP tools, Droidkit is always the first one to choose if you want to bypass your Google account after resetting. Or you are using a second-hand Samsung without removing the Google account. As a professional FRP unlocker, DroidKit can help you bypass FRP on Samsung with a few clicks. Without wide compatibility, this tool supports all Samsung devices running Android 6 – 15. Its ease of use and high success rate in FRP bypass make DrodiKit stand out from multiple competitors. As an all-in-one Android toolkit, DroidKit also supports backing up Samsung with a black screen, fixing Samsung system issues, etc.
Main Benefits of DroidKit FRP Bypass:
  • Bypass Samsung FRP without Google account credentials effortlessly.
  • Support multiple Android phone models, such as Samsung, Xiaomi, OPPO, etc.
  • 100% Secure and easy FRP bypass process with a high success rate.
  • Available for both Windows and Mac.
Before starting, download and install DroidKit on your Windows or Mac computer. Then follow the instructions given below to use this powerful FRP bypass tool.
Step 1. Launch DroidKit on your computer. Then select the FRP Bypass mode from the menu.
Choose FRP Bypass Mode
Step 2. Now connect your Samsung smartphone to the PC or laptop via a USB cable. Then click the Start button and select your device brand.
Step 3. Then you need to choose the Android system version of your device. Click Next to continue.
Choose System Version
Step 4. Follow the on-screen instructions to complete some settings on your device.
Complete Corresponding Settings
Step 5. DroidKit will start to bypass the FRP lock of your Samsung phone. Once it is completed, you will see the below interface.
FRP Bypass Complete
FRP Bypass Complete
Considering the success rate and security, we believe that DroidKit will be the best choice as a successful Samsung FRP unlock tool. However, you can also explore other tools in the next section.
2. SamFw Tool Latest Version Free Download
As versatile Android unlocking software, SamFw FRP Tool addresses various needs of Android device users. One of its key features is bypassing the FRP lock, making it particularly useful for individuals who have accidentally locked their devices or purchased an FRP-locked phone. Beyond FRP unlocking, SamFw FRP Tool supports exiting Download Mode, resolving Soft Brick issues, and flashing devices using Odin.
SamFw official webpage interface
The key features of the SamFw Tool are as follows:
  • Compatible with the Windows operating system.
  • Free to download and use without charge.
  • The intuitive interface makes it easy to use for beginners.
Cons:
  • Needs USB debugging and other permissions possibly raising security issues.
  • No support to bypass Samsung FRP on Mac.
3. King Tool – Free FRP Bypass Samsung
King Tool is an Samsung FRP removal tool developed by A.K Sumon. It helps users to remove the FRP lock from Samsung devices. It supports devices with Android versions Oreo 8.0, Pie 9, Android Q10, Android R11, Android 12, and tablets. You can download the latest version from its official website.
King Tool
King Tool
Key Features:
  • It can repair and restore your device’s IMEI number.
  • Customer support is available for queries.
  • It is free to download.
Cons:
  • Complex steps and processes to bypass FRP on Samsung.
  • Lack of Official Support & Updates.
4. Samsung FRP Helper v0.2
Samsung FRP Helper uses the ADB feature to bypass the FRP lock. You can download and install the Samsung FRP Helper v0.2 on your PC. It supports Samsung Android versions 9, 10, 11, 12, and 13 to bypass the FRP lock. The Samsung FRP Helper tool comes with two methods. One is the Calling Method (Real Term Method), and the other is the ADB method. Below are the key features of this Samsung FRP bypass tool.
Samsung FRP Helper V0.2
Key Features:
  • It has a very easy-to-use interface.
  • This tool can automatically detect the ADB file when the phone is connected to a PC.
  • You can download and use it for free.
Cons:
  • Limited success rate in Samsung FRP removal.
  • Complex interface may not be suitable for beginners.
5. Google Account Flashing Tool
This tool is also one of the best Samsung FRP unlock tools and helps to bypass Google verification after a factory reset. The Gadget Doctor has developed it. It supports various smartphone models, including HTC, MI, Samsung, Qualcomm, MTK, and SPD. You only need to download the Google account flashing tool and install it on your device. Then, you can follow the on-screen instructions to bypass the FRP lock.
Key Features:
  • It has a very simple interface.
  • This tool also covers the old version of SP Flash.
Cons:
  • Not work on newer Samsung models with updated security patches.
  • Incorrectly flashing an FRP file can cause the device to get stuck or brick the device.
6. FRP Lock Google Verification Bypass Tool
FRP Lock Google Verification Bypass Tool is also designed to bypass the Google verification lock from Android. It is an effective Samsung FRP tool that works very well on Samsung Android devices. Other than that, it supports HTC, Motorola, Huawei, Lenovo, Oppo, LG, and Xperia.
Key Features:
  • It is compatible with Android versions 5.1.1 to 7.1.
Cons:
  • Not work on newer Android versions (Android 11, 12, 13, 14).
  • Downloading from an untrusted website contains a high risk of malware or viruses.
7. SAM FRP Tool
SAM FRP Tool is designed to simplify the process of bypassing FRP locks on Samsung devices. It is an essential tool for users who find themselves locked out of their smartphones. With its user-friendly interface, you can easily act and regain access to your device. You can download this Samsung FRP unlock tool from here.
SAM FRP tool
SAM FRP tool
Key Features:
  • It supports almost all models of Samsung Android devices.
  • It also has a network-unlocking feature.
  • It is more affordable than other paid Software.
  • You can also repair and restore your device’s IMEI.
Cons:
  • Potential risks for Samsung device bricking or stuck on boot loops.
  • No official support or guaranteed updates.
8. Pangu FRP Bypass Tool
The Pangu FRP Bypass Tool is also designed to remove the FRP lock. It works on Samsung, LG, Mi, and HTC with Android versions 7.0, 7.1.1, and 7.1.2. This solution for FRP bypass was tested in 2018 and worked very well. However, if you cannot bypass the FRP lock with an old version, you can try the new file.
Pangu FRP Bypass
Pangu FRP Bypass
Key Features:
  • It can remove the FRP lock with or without a computer.
  • No compatibility issues, especially with Samsung phones.
  • You can download it for free.
Cons:
  • Might contain compatible issues with Android 11, 12, 13, and 14.
  • No guarantee of success rate in Saamsung FRP bypass.
9. Free Bypass APK
Samsung users can download this tool to remove the Google account from their device. Users don’t remember their Google account credentials. Therefore, they get stuck at the FRP lock screen. In this situation, Free Bypass APK files come to the rescue. You can download it and use it to bypass the FRP lock.
Key Features:
  • An efficient tool for Samsung devices.
  • It is easy to use and is compatible with all Android versions.
Cons:
  • Not from official sources, possibly contains viruses, spyware, or malware.
  • Sometimes fails to open, crashes, or freezes the device after installation.
10. GSM Flasher ADB Bypass FRP Tool
GSM flasher is one of the easiest ways to flash or bypass the FRP locks on Android devices. But it requires a USB cable to do so. You can download and install the GSM Flasher tool on your PC in just a few minutes. You can easily unlock any Android phone using this flash tool in a few clicks.
GSM Flasher Tool
GSM Flasher Tool
Key Features:
  • It is compatible with both Windows and Mac.
  • It can also help you remove the pattern lock on your device.
Cons:
  • ADB mode must be enabled on the device for the tool to work.
  • May contain viruses, spyware, or unwanted programs.
11. FRP HiJacker by Haggard
FRP HiJacker By Haggard is the next FRP bypass tool in our list designed for Samsung. HiJacker by Haggard is free to use. However, its download is unsafe and can expose your device to malware and viruses. The success of the removal of the FRP lock is not guaranteed.
Start the FRP bypass
Key Features:
  • You can bypass the FRP lock in download mode (Odin mode).
  • It can also help you fix the Softbrick (no boot or boot loop) without any firmware flash files.
  • You can perform ADB operation by enabling the USB debugging mode.
  • It can also help you bypass the FRP lock using a phone dialer.
Cons:
  • The effectiveness of FRP bypass on Android 11, 12, 13, and 14 cannot be guaranteed.
  • Incorrect use may cause boot loops or software corruption.
12. UnlockJunky
UnlockJunky is another tool in our list that helps to bypass the FRP lock. It is relatively more efficient and fast than other tools. With UnlockJunky, you can bypass the FRP lock within 5-10 minutes. It supports phone models, including Motorola, ZTE devices, and Samsung. However, it is known to be best for Samsung smartphones.
UnlockJunky
UnlockJunky
Key Features:
  • It offers carrier services unlocks and Samsung account unlock.
  • Support is available in case you have any queries.
  • Everything is carried out online.
Cons:
  • Downloads from unverified sources may contain malware, spyware, or trojans.
  • As an online service, there’s a risk of scams for users.
13. Octoplus FRP Tool
Octoplus FRP Tool is also an amazing way to bypass FRP on your Android phone. This Samsung FRP tool supports phone models, including Motorola, LG, Alcatel, and Huawei. You can bypass FRP using FastBoot Mode, Download Mode, or Factory Mode. Unfortunately, for now, the Samsung FRP bypass server is not working.
Octoplus FRP Tool
Octoplus FRP Tool
Key Features:
  • It is paid and relatively expensive.
  • You can unlock only one device with one payment.
  • You can bypass the FRP tool without losing data.
Cons:
  • Requires technical knowledge of flashing, ADB, and firmware handling.
  • Complex interface and steps, not user-freindly for beginners.
14. D&G Password Unlocker
D&G Password Unlocker helps Android users remove the FRP lock from their mobiles/tablets in a few seconds. This Software works on brands including Samsung, Lenovo, Motorola, HTC, Yuphoria, Xiaomi, and Huawei. The best part is it supports all OS systems like XP, Vista, 7, 8, and 10. The tool can let you flash an Android mobile phone and rewrite the firmware. And you can learn more about this Samsung FRP tool below.
Key Features:
  • It is compatible with a ton of OEMs.
  • It can also remove the screen lock, pattern lock, and bloatware.
  • You can compare the above tools and select one that best fits your needs and budget.
Cons:
  • High failure rate on some Samsung devices, especially those with newer Android versions.
  • Boot loops or software corruption sometimes happens during FRP bypass process.
FAQs about Samsung FRP Tool
1. Why do You Need A Samsung FRP Tool?
Imagine you decided to reset your Samsung Android phone to take a fresh start. But when you turn on your phone after a reset, you just come up with an FRP lock screen. In this situation, what would you do?
That’s where the Samsung FRP Bypass tool swoops in to save the day. Although FRP is incorporated for the safety of your device, it can also be a trap. Especially when you are someone who usually forgets his digital account credentials.
2. What Makes the Best Samsung FRP Tool?
Since it’s hard to choose an FRP tool for Samsung to bypass Google account, some features you should consider include:
  • Bypass FRP quickly – DroidKit can quickly bypass FRP lock/Google account in just a few minutes, allowing you to re-enter your device immediately.
  • High success rate guaranteed – DroidKit provides customized FRP bypass solutions for different Android devices and systems, meeting a variety of needs and ensuring a high success rate.
  • User-friendly interface and operation – You only need to click a button to bypass FRP easily. Foolish operation. Accessible for anyone to use.
  • 100% safe and clean – It will never cause any damage to your device. Your data will not be leaked to others.
Having introduced 14 Samsung FRP tools in the above part, you can choose your preferred one to use. Some of the tools are designed for Samsung FRP bypass only, while some others support more phone types. Among all the FRP tools, Droidkit is highly recommended for bypassing FRP on Samsung phones for its high success rate. Its security and easy steps make this tool stand out from all competitors. Download Droidkit and use your Samsung phone without the previous Google account right now!
