This article introduces multiple methods to bypass Samsung A70 FRP lock for the latest Android 6-14. These methods can effectively help users regain control of their devices when they forget their Google account password or buy a second-hand device.
For Samsung A70 users, FRP Bypass has become a pressing need. As a popular mid-to-high-end smartphone, Samsung A70 is known for its 6.7-inch Super AMOLED display, triple camera system, and powerful 4500mAh battery. However, even such a feature-rich device is not immune to the trouble of FRP lock.
This article will take a deep dive into how to successfully bypass the factory reset protection (FRP) of Samsung A70 on the latest Android system. We will detail the simple steps using the DroidKit tool, as well as other effective bypass methods to ensure that you can easily deal with various account lock situations and give full play to the full potential of this excellent phone.
Yes, the Samsung A70 FRP (Factory Reset Protection) can be bypassed. FRP is a security feature designed to prevent unauthorized persons from accessing a device after it has been reset. It requires the user to enter the Google account credentials previously associated with the device after a factory reset.
DroidKit is a powerful tool designed to fix a variety of issues on Android devices, and is particularly good at bypassing FRP. For Samsung A70 running Android 9 to 11, DroidKit not only provides simple operations without technical background, but also can quickly bypass FRP and restore full device access without damaging device data.
DroidKit also has many valuable features, such as:
Steps to bypass Samsung A70 Android 11/12/13/14 FRP:
Step 1. Download the latest version of the DroidKit software, install and launch it for operation. Select FRP Bypass.
Choose FRP Bypass Mode
Step 2. Once done, plug your Samsung A70 device into your computer via a USB cable and click on the green “Start” button.
Step 3. After that, it will begin preparing the configuration file for your device. Once the preparation process ends, press the Start to Bypass button. Then, follow the instructions shown in the image to put your device in recovery mode.
Click Start to Bypass
Step 4. Check the boot screen, and according to the boot screen, select the Android System version of your device.
Choose System Version
Step 5. Follow the instructions on the screen and click Reset.
Complete Corresponding Settings
Step 6. After completing the steps above, the device will be restarted and the FRP Lock is also removed successfully.
FRP Bypass Complete
TalkBack was originally designed as an accessibility feature for visually impaired users, but it also provides an unexpected breakthrough for FRP bypass. Next, we will introduce in detail how to use the TalkBack feature to successfully bypass the FRP lock of Samsung A70.
Step1. Turn on your Samsung A70 and connect to a Wi-Fi network.
Step2. Enter the Google account verification page, then follow the setup wizard until the device prompts you to enter your Google account information.
Step3. Enable TalkBack:
Step4. Press the Volume Up and Volume Down buttons simultaneously for about 3 seconds to disable TalkBack.
Step5. Access Settings:
Step6. Disable Google Play Services:
Step7. Restart the device and continue with the setup, FRP will be bypassed.
Using TalkBack to bypass FRP lock requires users to have a high level of proficiency in device navigation and some specific operations. The gestures and voice commands used by TalkBack are different from the operations in normal mode, so users may need to spend some time to familiarize themselves with these operations. We recommend that you find a video on YouTube to follow the instructions.
Related reading: Samsung A50 frp bypass
1. Turn on your Samsung A70 phone, click the “Start” button, click to agree to the terms and conditions and click “Next”
2. Connect your Samsung phone to a Wifi network
3. Now press the Volume Up button and the Power button at the same time and tap Use. Quickly tap the Volume Up button and the Power button again to enable Talkback
enable Talkback
4. Now draw “⅃” (reverse L) and choose to use voice command. Then say open Google Assistant. Finally press “Volume Up” + “Volume Down” to disable Talkback.
5. Select Keyboard =>> Type YouTube. Then open YouTube
6. Click on your user icon and select Settings =>> About =>> YouTube Terms of Service
7. Now it will lead you to the Chrome Browser
Chrome Browser
8. Open the OS14 Launcher from the results => Tap on Install & Open
9. Go to Settings =>> Accounts & backup =>> Backup & Restore =>> Backup data
Accounts & backup
10. Uncheck everything except Apps and then tap Back up. All data backed up Tap done, Let’s back to our FRP Locked phone
11. Go to Settings =>> Accessibility =>> Tap on Interaction & dexterity =>> Turn on Assistant Menu
12. Tap on Select Assistant Menu items and Remove all the items except Menu Settings. Then go to Accounts & Backup and Restore Data (Do Not update Samsung Cloud)
13. Select Restore Data & Quickly tap Assistant Menu=>Tap on Back Key once
Doing this will prevent the Samsung Cloud Updating and will allow Restore data
14. Restore Apps Only & Tap Install
15. Select Accessibility => Installed Services
Installed Services
16. Allow Notification Bar => Allow
17. Select Notifications => Allow Notification Bar
18. Go to Settings =>> Privacy =>> Permission Manager =>> Files and Media
Files and Media
19. Click on 3dots => Show System
20. Search & Select Package Disabler Pro and Turn On Allow management of all files.
21. Go back to the Menu
Agree & Enable Admin =>> Activate
22. On KLMS agent: enable WiFi or Mobile data from the Notification bar and then Tap on Agree
KLMS agent
23. Tap on Search icon and search for Setup
24. Then Select Samsung Setup Wizard (com.google.android.SecSetupWizard) and clear data
25. Now Just Go back and Setup initial steps. You have successfully bypassed the Samsung A70 phone
In this article, we have discussed in detail how to bypass FRP on Samsung A70. We have introduced multiple methods and highlighted the use of DroidKit for Samsung A70 FRP Bypass.
DroidKit is an ideal tool for bypassing FRP protection due to its ease of use, data security, and full support for the latest systems.
If you are also looking for FRP bypass methods for other models, you may be interested in Samsung A50 FRP Bypass.
