4 Ways to Do Samsung A7 FRP Bypass with/without Computer
How to bypass Samsung A7 FRP lock in an easy way? Is there more than one ways? Read this article to give you answers.
Author Avatar Joy Taylor Last Updated: Sep. 23, 2024
What is FRP and is it Possible to Bypass FRP?
Factory Reset Protection (FRP) is a new security feature in Android devices. It has been introduced in devices with version 5.0 and above. FRP acts as a safeguard to prevent unauthorized users from accessing your device. However, the real question is, can you bypass it without a PC?
Well, you can bypass FRP Samsung without PC. This feature gets enabled after a factory reset. It requires your Google account details Image named with your device to unlock the screen. So, if your device gets lost or stolen, nobody can access it unless they enter your Google account.
Many reasons make users reset their devices. But little do they know that they can get in trouble if they don’t remember their Google account credentials. Most of the time, users have no clue what to do in this situation. But luckily, various ways can help you with Samsung FRP bypass without PC. Let’s explore some ways to do Samsung A7 FRP bypass now!
How to Bypass Samsung A7 FRP Lock with PC
To execute Samsung A7 FRP bypass, we have 3 ways with computer. Consider the technical difficulties, try the below methods one by one as you like.
Method 1. Bypass Samsung A7 FRP via DroidKit
One way to bypass FRP on a Samsung device is by using a specialized Android unlocking tool like DroidKit-Android Phone Toolkit. This allnone solution helps you safely bypass FRP lock on Samsung devices. Additionally, it can unlock lock screens, upgrade your system, recover lost data, and fix system issues. Here are some key features of DroidKit for Samsung FRP bypass:
  • Quick: You can remove the FRP lock or Google account in just a few minutes and regain access to your device.
  • User-friendly: DroidKit is easy to use, allowing you to bypass FRP at home.
  • Success: Supports Android 6 and later versions, with specific solutions for different systems to ensure successful bypassing.
  • Works on other devices too: Besides Samsung, DroidKit also works with Xiaomi, Redmi, POCO, and OPPO devices.
  • Safe and secure: Equipped with advanced encryption and free from malware, it ensures your privacy and device security.
Now just free download DroidKit and here are the steps to use it to FRP bypass Samsung.
Step 1. Open DroidKit on your PC/Mac, and click the FRP Bypass option from the interface.
Choose FRP Bypass Mode
Step 2. Connect your Samsung device to your PC using a USB cable and click Start. Then you need to choose the device brand.
Choose Device Brand
Choose Device Brand
Step 3. DroidKit will prepare a configuration file for your device; therefore, don’t unplug your phone during the process. After that, click on Start to Bypass.
Tap on Start to Bypass
Step 4. Select your Android system version from the given options and click Next.
Choose System Version
Step 5. Continue following the onscreen instructions on the DroidKit interface to complete some settings on your device.
Complete Corresponding Settings
Step 6. Once you complete the steps on the screen, it will bypass the FRP lock on your device, and then you can access your phone easily.
FRP Bypass Complete
FRP Bypass Complete
Way 2. Bypass FRP Samsung with SIM PIN Code
Looking for a free way to bypass the FRP lock on your Samsung device? The Samsung FRP SIM PIN method is a simple option. This approach uses your SIM card to get a link or code from Google to reset your password. You’ll need to insert your SIM into another phone to receive the Google message. Here’s how to do it:
  1. After resetting your Samsung phone, it will ask for your Google account details. At this point, select “Forgot Password.”
    Tap on Forgot Password
  2. Remove your SIM from the locked Samsung phone and place it into another device. Choose the option to reset the password using your phone number. Google will send you a reset link via text.
  3. Set a new password and use it to unlock your Samsung phone.
Way 3. FRP Bypass Samsung with Odin
Another method to bypass the FRP lock on Samsung devices is by using Odin, a Windows software created by Samsung. While Odin primarily helps root Samsung phones and install firmware updates, it can also assist in bypassing the FRP lock by adding custom features.
This method is a bit technical and requires some files to be set up on your PC, including:
  • Samsung FRP Files
  • Samsung USB Drivers for Windows
Once you have these files ready, follow these steps to bypass FRP on your Samsung using Odin:
  1. Download and install Odin on your Windows computer.
  2. Put your Samsung device into Recovery Mode by pressing and holding the Volume Down and Power buttons. Release the Power button but keep holding the Volume Down button until you see the Recovery Mode screen.
  3. Connect your device to your PC with a USB cable, and then open Odin.
  4. Odin will show a list of .zip files needed for the FRP bypass process.
  5. Click on the AP, CP, and CSC tabs in Odin, then browse and select the downloaded files from your PC. These files are part of the Samsung FRP files you obtained earlier.
    Click AP/CP/CSC Options
How to Bypass FRP on Samsung Device without PC
If you don’t have access to a PC, you can still remove the FRP lock on your Samsung device using an FRP Bypass APK. Here’s how to do it:
Step 1. Connect your Samsung device to a WiFi network.
Step 2. Tap the arrow next to the WiFi network and select “Manage Network Settings.”
Step 3. Choose “Static IP > IP Address.”
Step 4. Enter any text in the IP address field, then long-press it until the “Web Search” option appears.
Step 5. Search for “FRP Bypass APK” and download and install the app.
Step 6. Open the FRP Bypass APK, then go to “Settings > Try.”
Step 7. Navigate to “Fingerprints, Face, and Password > Screen Lock > Pattern” to set a new lock pattern for your device.
Step 8. Return to the main screen and enter the new lock pattern.
Step 9. Tap “Skip” to bypass the FRP lock.
And that’s it! You can bypass the FRP lock on your Samsung device with just a few simple steps.
In sum
Dealing with the FRP lock can be a hassle, but luckily, there are ways to bypass it. In this article, we have explored 4 ways to do Samsung A7 FRP bypass. Notably, DroidKit offers a seamless and easy way for users. Additionally, this tool is an all-round Android toolkit that is worthy to try!
