The Samsung A51 is popular for its sleek design, vibrant Super AMOLED display, versatile quad-camera setup, and affordable price. It offers a great balance of features and performance, making it a favorite among mid-range smartphones. Its long battery life, expandable storage, and reliable performance further contribute to its popularity.
Due to its popularity, Samsung A51 is still the best choice for some users. To make it more valuable, you may consider a second-hand Samsung A51. Notice the case that you have paid for a second-hand phone, only to find it is locked by the existing Google account. Then you have to bypass the Google account for full access to the Samsung A51.
Samsung A51
Also read: How to fix Samsung stuck on logo issues
DroidKit FRP bypass is a comprehensive tool designed to handle various Android issues, including FRP bypass, Android screen lock removal, Android system repair, and more. You can check the benefits of using DroidKit to bypass FRP on Samsung A51:
Here’s a step-by-step guide on how to use DroidKit to bypass FRP on a Samsung A51:
Step 1. Download and install DroidKit on your computer. Both Windows and Mac are available to use.
Step 2. Launch DroidKit and click on the FRP Bypass option. Use a USB cable to connect your Samsung A51 to the computer.
Choose FRP Bypass Mode
Step 3. Follow the guide to choose your phone brand and continue.
Choose Device Brand
Then the instructions will lead you to prepare the configuration file and bypass FRP on your Samsung A51 effortlessly.
FRP Bypass Complete
Why Choose DroidKit?
DroidKit stands out as the best option due to its ease of use and high success rate. It supports various Samsung devices, including the A51, and offers a user-friendly interface that simplifies the FRP bypass process.
D&G Password Unlocker is a free tool that can bypass FRP on Samsung devices. Here’s how to use it:
How to Use D&G Password Unlocker Tool All FRP Bypass Lock
The SamFw Tool is another popular choice for bypassing FRP on Samsung devices. Here’s a step-by-step guide:
SamFw FRP tool opening interface
SamFirm FRP Tool is known for its comprehensive features and support for the latest Samsung models. Here’s how to use it:
Tool Name | Pros | Cons |
DroidKit | Easy to use, high success rate, supports multiple devices | May take some time to bypass FRP for some phones |
D&G Password Unlocker | Simple interface, no need for technical expertise | Limited features, not frequently updated |
SamFw Tool | Supports a wide range of Samsung devices, user-friendly | May require multiple attempts, less reliable for the latest models |
SamFirm FRP Tool | Supports latest Samsung models, comprehensive features | Requires technical knowledge, complex interface |
1. What Is the Best Samsung A51 FRP Unlock Tool?
Bypassing FRP on a Samsung A51 requires specific tools designed to remove or bypass the Google account verification process. These tools are essential for users who find themselves FRP-locked out of their devices. Here are some of the most popular Samsung A51 FRP bypass tools in 2024:
2. How to Bypass Samsung A51 FRP Without Computer?
Bypassing FRP without a computer can be more challenging but not impossible. You can use methods such as:
Using an OTG Cable and a Flash Drive: Transfer an FRP bypass APK to the flash drive, connect it to the phone via OTG, and install the APK to bypass FRP.
Using Samsung’s “Find My Mobile”: If you can contact the previous owner of the Samsung A51 and he’d like to help you remove FRP remotely. You can ask him to log in to “Find My Mobile” and remotely unlock your device.
3. Can I Factory Reset Samsung A51 After Bypass FRP?
Yes, you can factory reset your Samsung A51 after bypassing FRP. However, doing so will re-enable the FRP lock if you reset the device again without removing the Google account linked to it. But don’t worry, you can use DroidKit to bypass FRP again if you have factory reset the Samsung A51.
Bypassing FRP on a Samsung A51 can be a straightforward process if you have the right tools. In 2024, several options are available, including DroidKit, D&G Password Unlocker, SamFw Tool, and SamFirm FRP Tool. Among these, DroidKit stands out for its ease of use and high success rate. Whether you need to bypass FRP due to forgotten credentials or other reasons, this guide provides detailed instructions to help you regain access to your device. Always remember to back up your data and follow security best practices to protect your information.
