If you have forgotten your phone password, we have a perfect solution. Here, you will read about using tools like OTG and Google Keyboard to perform a Samsung A23 FRP Bypass. We will also discuss steps to use professional tools to Bypass FRP. Let’s get started with Samsung A23 FRP Bypass methods.
Using the best Samsung A23 FRP bypass tool to fix the Samsung stuck on the FRP lock screen. Activate your Samsung A23 with a new Google account in 3 minutes. Supports all Samsung phones and tablets running Android 6 – 15.
Factory reset your Samsung A23 only to find it is FRP-locked on the activation screen? Don’t know the Google account or password to remove FRP on Samsung A23? No worries. FRP (Factory Reset Protection) is a safe and easy method to prevent unauthorized access to your Android phone.
Let’s discuss the details of the Samsung A23 FRP Bypass. Using FRP protects your phone data. But, if you forget your registered Google account password it can turn into an issue. This way, your phone will be unlocked. For this issue, you can consider FRP Bypass. Here are 3 ways to bypass FRP on Samsung A23 without Google account or password. Check them out now!
Also Read: How to disable factory reset protection
To remove the existing FRP lock on Samsung A23, you can use the logged Google account and password to achieve this. However, without the account information, you should try some FRP bypass tools. Among several tools, DroidKit is a perfect one for Samsung A23 FRP bypass. By using this tool you can not only bypass FRP but also unlock various Android models including Samsung A23. Just take a few simple steps, and there you go! You will be able to use your phone without any issues.
1. Download DroidKit on your computer. Launch it and choose the FRP Bypass mode.
Choose FRP Bypass Mode
2. Then connect the phone to the computer using a USB cable and click the Start button.
Connect the Device and Click Start
3. Now, the software will detect your phone and prepare the Device Configuration File. After this, click the Start button and choose your phone brand.
4. When the process is completed, click the Start to Bypass button.
Click Start to Bypass
5. Now, in the window that appears, choose the boot screen. DroidKit has five boot screens available in different mobile versions and models.
Choose System Version
6. Now, go to enter the current password interface for the device and follow the instructions that appear. After this, click the Reset button on the app.
Click Reset
7. Now, the Bypass FRP lock process will start. After the Bypass FRP is completed, your phone will restart, and the FRP lock will be removed successfully.
FRP Bypass Complete
Now, the FRP on your Samsung A23 is bypassed. You can use another Google account to register your phone and enjoy.
We have another method for you to Bypass FRP. This method includes using an OTG cable and an FRP Bypass APK. For this, you just need a fast internet connection, your computer, and an Android OTG cable. By installing FRP APK files you can remove FRP lock from your phone. Now, let’s use OTG and APK files to Bypass the FRP lock on a Samsung A23 device.
Here are the most trusted APK files according to user’s research:
Now, we will move on to the steps to install and use APK files.
Take the FRP Bypass APK file and the Samsung A23 Android 13/14 as examples. Now, here are the steps to proceed:
1. Download an FRP Bypass APK File and install it on your computer.
2. Now copy the APK file on a flash drive and connect the Flash drive to your phone using the OTG cable.
Connect OTG Cable to Samsung A23
3. After the file manager pop-up appears, install the APK file on your phone.
4. Now, you will be able to access your phone settings.
5. Find the Backup and Reset option and click it.
6. Now select Factory Data Reset > Reset Devices > or > Erase everything.
7. After this, remember that the media files, device settings, downloaded files, your Google account, and System and app data will be deleted from your computer.
8. Your phone will restart, and the FRP lock will be successfully removed.
Now, let’s look into another method to Bypass FRP.
In case you don’t have access to another computer or OTG cable, we have another method for you: using a Google keyboard. This method is complex and lengthy, but it works without an OTG cable or external device. Let’s move on to the next steps.
Here are the steps to Bypass FRP on Samsung A23 using Google Keyboard:
1. At the FRP Lock screen, when the keyboard pops up, tap and hold the @ key till the Samsung settings page opens.
Open Keyboard Settings
2. Now open the keyboard settings and click three dots on your screen.
3. Now, select the Help and Feedback option.
4. Now, from the Help page, click the Use Google Keyboard on the screen.
5. After this, click and hold any of the text on the screen and then select Websearch at the top of the screen.
6. Now, use the search bar to search for Settings, open Settings, scroll down, and click the About Phone option.
7. Now click on Software information and click on your phone Build number seven times to activate the Developer options.
Tap the Build Number 7 Times
8. Now go back to the About Phone menu and tap on the Developer options that you just enabled.
Click on Developer Options.
9. After finding the OEM Unlocking option enable it. Then click on the back option twice.
Allow OEM Unlocking Pop-Up
10. Now return to the main menu. Now, restart your phone.
11. Finally, add a new Google account to your device, and you are all set to go.
These were the methods used to bypass FRP on Samsung A23. Try these out and find the most suitable one for you.
It’s uncertain whether to use the SIM PIN code for Samsung A23 FRP bypass. The steps are complicated and long. Also, most users said it’s useless to bypass FRP after trying SIM PIN code.
Many tools are available, yet DroidKit is the best Samsung A23 FRP Unlock tool. Using DroidKit, you can easily remove the FRP lock from your phone. Other methods, like OTG cable and Goggle keyboards, are also available.
In this article, we have discussed the easiest methods to remove the FRP lock from your mobile. DroidKit is the best Samsung A23 FRP Bypass tool. If you don’t have access to a computer or an OTG cable, you can use Google Keyboard to Bypass FRP. We have discussed all these methods with you so you can find the most suitable one.
