Exploring effective 4 ways to bypass FRP lock on Samsung A20 in this article, having more freedom to take control of your own devices!
DroidKit allows you to bypass FRP lock on Android like Samsung, Huawei, Xiaomi and so on without passwords.
The Samsung Galaxy A20 is a popular budget-friendly smartphone, known for its robust features and user-friendly experience. However, one common issue many users face is dealing with Factory Reset Protection (FRP). FRP is a security feature designed to prevent unauthorized access to your device after a factory reset. While it’s useful for protecting your data, it can also be a hassle if you forget your Google account credentials. In this guide, we’ll walk you through the Samsung A20 FRP bypass process, helping you regain access to your device without the original login credentials.
Before diving into the bypass method, it’s crucial to understand FRP. Introduced by Google in Android 5.1 (Lollipop), FRP is designed to prevent unauthorized users from resetting and accessing a lost or stolen device. When a Samsung Galaxy A20 is factory reset, it will ask for the Google account details previously synced to the phone. This is a vital security measure, but it can become an obstacle if you’re locked out of your own device.
So several scenarios may require a Samsung Galaxy A20 FRP bypass:
If you’re facing any of these issues, conducting Samsung A20 FRP bypass is inevitable. Here we will introducing several ways with full guide.
In this section, we offer diverse ways to unlock FRP via different Samsung A20 FRP unlock tool.
DroidKit is a highly effective FRP bypass tool that allows you to easily remove a Google account from your Samsung phone without needing a password. It enables you to bypass the FRP lock, delete the previously synced Google account, and log in with a different Google account to access all Google services. In addition to FRP bypass, DroidKit offers a complete Android solution, including the removal of all screen locks on any Android device and recovery of deleted files.
Here’s how can you remove Samsung Google account with DroidKit:
Here is how to bypass the Google account on Samsung:
Step 1. Download and install DroidKit on your Windows PC or Mac. Launch the software and select the “FRP Bypass” option.
Choose FRP Bypass Mode
Step 2. Connect your Samsung phone to the computer using a USB cable, then click the “Start” button as shown. Then choose your device brand.
Choose Device Brand
This process will erase data from your device. Please ensure you back up your data beforehand.
Step 3. DroidKit will prepare a configuration file for your device; therefore, don’t unplug your phone during the process. After that, click on Start to Bypass.
Step 4. Follow the instructions to enter Recovery Mode and identify your Samsung device’s Android system version. Then, click “Next.”
Choose System Version
Step 5. Continue following the on-screen instructions to complete the necessary settings for your device.
Go to Enter your Current Password Interface and Click Reset
Step 6. Once the settings are finished, the FRP bypass process will begin. When it’s complete, your device will restart, and the FRP lock will be removed.
FRP Bypass Successfully
The Samsung FRP SIM PIN method is one of the easiest ways to bypass the FRP lock. It works by using your SIM card to receive a link or code from Google to reset the password. You’ll need to insert your SIM card into another device to receive the text from Google. Here’s how to complete the FRP bypass:
Step 1. After resetting your Samsung phone, it will prompt you to enter your Google credentials. At this point, tap on “Forgot Password.”
Step 2. Remove the SIM card from the locked Samsung phone and insert it into another device. Choose the option to reset the password using your phone number. You’ll receive a text with the link to reset your password.
Step 3. Set a new password using the link provided, then use this password to unlock your Samsung phone.
Another way to bypass the FRP lock on Samsung devices is by using Odin, a Windows-based software developed by Samsung. Odin is primarily used to root Samsung phones and install firmware updates, but it can also help bypass the FRP lock by upgrading your device with custom features.
Before you begin, you’ll need to download and install the following files on your PC:
Once these files are in place, follow these steps to bypass the FRP lock using Odin:
Step 1: Download and install Odin on your Windows PC.
Step 2: Put your Samsung device into Recovery Mode by pressing and holding the volume down and power buttons. Release the power button while continuing to hold the volume button until the Recovery Mode screen appears.
Step 3: Connect your device to the PC using a USB cable, then launch Odin.
Step 4: Odin will display a list of .zip files required to proceed with the FRP bypass.
Step 5: Select the AP, CP, and CSS tabs in Odin, then browse and import the necessary files from the Samsung FRP files you downloaded.
Step 6: Once all the files are imported, click “Start” to initiate the FRP bypass process.
Click AP/CP/CSC Options
Step 7: The process will take a few minutes. When it’s complete, you’ll see a “PASS” message, indicating the FRP lock has been successfully removed.
A PASS Message Pops up
Since this method is more technical and can be challenging for some users, you might want to explore easier alternatives for bypassing the FRP lock.
Users frequently ask: “How to enable Samsung A20 Google Account Bypass without PC?” If you don’t have access to a PC, you can still remove the FRP lock on your Samsung device using an FRP Bypass APK. Here’s how to do it:
Step 1: Connect your Samsung device to a Wi-Fi network.
Step 2: Tap the arrow next to the Wi-Fi network, then select “Manage Network Settings.”
Tap Manage Network Settings
Step 3: Tap “Static IP,” then choose “IP Address.”
Step 4: Enter any random text in the IP address field, then long-press it until the “Web Search” option appears.
Step 5: Search for “FRP Bypass APK,” download, and install the APK on your device.
Step 6: Open the FRP Bypass APK and navigate to “Settings > Try.”
Step 7: Go to “Fingerprints, Face, and Password > Screen Lock > Pattern” and set a new pattern lock.
Step 8: Return to the main screen and unlock your device using the new pattern.
Step 9: Tap “Skip” to bypass the FRP lock.
This simple method allows you to bypass the FRP lock on your Samsung device without a PC.
Executing Samsung A20 FRP bypass can be a simple process if you follow the correct steps. To save your efforts and keep data security, we suggest DroidKit, one comprehensive Android toolkit that can only only bypass FRP on different brands, but also empowering you unlock other locks like PIN, Patterns, digital numbers, fingerprints and so on. Try this tool now!
