This guide shows three easy techniques for eliminating FRP from your Samsung A14 and A14 5G. You will know how to bypass it with DroidKit, Odin, or a method that requires no PC. All the Samsung A14 FRP bypass steps mentioned below are simple and helpful for regaining your device’s access in case you are locked out after a factory reset.
If you want an easy way to bypass FRP on Samsung A14, DroidKit is the best choice. It provides clear and accurate steps for Android FRP bypass. Follow the step-by-step instructions to finish Samsung A14 FRP bypass on Windows or Mac without passwords.
Samsung A14 or A14 5G FRP bypass is not easy, and it can be very stressful when you are locked out of your Samsung after the factory reset, realizing that you need to remember the Google account details. However, it is possible to deal with this problem and unlock your device with the assistance of particular methods. This article introduces 3 methods to bypass FRP on a Samsung A14 or A14 5G. No matter if you want to use a computer or not, there is a way out.
The easiest way to bypass FRP on Samsung A14 is using DroidKit. As a powerful and all-in-one Android device manager, DroidKit FRP bypass is the ultimate way to bypass FRP locks on all Samsung devices efficiently and quickly. This tool can easily remove and unlock your gadget, usually without expertise and prior technical knowledge. Apart from FRP removal, other aspects of DroidKit include removing all Android lock screens, upgrading Android systems, recovering lost Android data, and repairing damaged systems.
Below are some key features of DroidKit for Samsung FRP bypass:
No, let’s explore the simple steps to use Droidkit for FRP Bypass:
Step 1. On your Windows or Mac computer, launch DroidKit and choose “FRP Bypass” from the main menu.
Choose FRP Bypass Mode
Step 2. Attach your Samsung device to the PC by a cable. Then, click “Start” and select the brand of the device.
Choose Device Brand
Step 3. DroidKit will create a configuration file for your device. Make sure your phone stays connected during this process. Once it’s ready, click “Start to Bypass.”
Step 4. Choose your Android system version from the available options, then click “Next.”
Follow the Bypass Steps
Step 5. Keep following the instructions in DroidKit to complete the necessary settings on your device. When done, DroidKit will regain access to your phone.
FRP Bypass Complete
Odin is an effective Windows-based tool developed by Samsung and used internally to communicate in the download mode, also known as Odin mode. However, users can utilize this utility to easily remove the FRP on Samsung A14 or A14 5G. Odin can get beyond the FRP lock; however, it’s used primarily to root Samsung devices and install custom kernels or firmware updates.
This method is more technical and requires some preparation, including downloading essential files like Samsung FRP Files and Samsung USB Drivers for Windows. Once you have these files ready on your PC, you can use Odin to upgrade your device with custom features, bypassing the FRP lock and restoring access to your phone. For this method:
Step 1. Download and install Odin on your Windows PC.
Step 2. Hold the volume down and power buttons together, then release the power button while keeping the volume button pressed until Recovery Mode appears.
Step 3. Connect your device to the PC with a USB cable, then launch Odin.
Step 4. Odin will show a list of .zip files needed for the FRP bypass process.
Step 5. Select the AP, CP, or CSC tabs in Odin, and import the necessary files from the Samsung FRP files you downloaded.
Step 6. Choose “Start” to initiate the FRP bypass procedure.
Step 7. Wait a few minutes until you see the “PASS” message indicating that the FRP lock has been successfully removed.
Bypass FRP on PC with ODIN
FRP after factory reset may be useful in terms of security, but that’s not necessarily the case, especially if you forget the login details or buy a new device with FRP activated. Fortunately, removing the FRP lock on your smartphone without a PC is possible so you can complete the process successfully.
Google Account Recovery approach involves receiving a verification link or code on the SIM card registered with Google, hence resetting the Google account password and gaining control of the device. To use this method:
Step 1. After you reset your Samsung phone, you’ll be asked to enter your Google credentials. Enter the incorrect password first, then click “Forgot Password.”
Step 2. After unlocking your locked Samsung phone, remove the SIM card and insert it into another device. If you select to reset the password with your phone number, a text message with a reset link will be sent to you.
Step 3. Use the link to “Create a New Password”, which you will need to unlock your Samsung phone. Return to the FRP screen and enter the new password on your Samsung A14/A14 5G.
The Samsung A14 doesn’t come with a default PIN. Users set their own during the initial setup. If forgotten, a factory reset might be required. You can also try DroidKit to unlock Samsung without a password.
If you have a locked Samsung A14 and wish to reset it, switch off the device and then use the Volume up Power button combination. When the recovery menu shows up, choose the ‘Wipe data/factory reset’ option.
There is a way to bypass Samsung A14 with a password by employing a professional tool such as DroidKit. DroidKit can unlock your device’s lock screen, giving you safe and efficient access.
In this article, you learned how to remove the FRP lock on Samsung A14/A14 5G using tools like Odin and the Google Account Recovery option without PC. Both methods provide a simple method of unlocking your device if locked out. However, to be more precise and to use DroidKit in a much simpler and more effective way, you had better use it. It is an effective tool that helps you make the process faster and safer to unlock your Samsung device in a few steps.
