Samsung A13 FRP Bypass [Android 11/12/13/14]
Are there any easy ways to bypass FRP lock screen on your Samsung A13 with ease? 3 solutions are given to bypass FRP lock screen via only several clicks whether with a PC or not!
Samsung A13 FRP Bypass Tool
Download DroidKit to bypass FRP on Samsung A13 with the latest FRP bypass technique. No Google account or password is required. 100% easy to use. Support the latest Android 15.
Released in March 2022, the Samsung A13 is one of the top-ranked mobile devices to own, as seen in the chart below. This device is perfectly designed with an incredible camera resolution to facilitate high-end images when capturing your favorite moment, a highly sensitive fingerprint sensor to ease screen unlock, and lots more. What’s more, a rigid security system, Google FRP, restricts intruders’ access to your device and the data on it in your absence.
Samsung A13 Overview
Though the security system is a cool feature, it sometimes causes trouble especially when you lose your Google password as you will also be restricted access to your device. When such happens, you may get frustrated, but that should be history now that you’ve made it to this post. Here, we will reveal the various ways to bypass FRP lock on Samsung A13 with or without a PC.
Hot read: How to recover deleted photos on Samsung
Part 1. Samsung A13 FRP Bypass with PC [Android 11/12/13/14]
From your PC, you can get your Samsung A13 FRP lock bypassed. However, you must have a versatile Android unlocker on the ground to help you get the job done and one tool you can trust to help you out is DroidKit FRP bypass tool. This software facilitates quick removal of FRP lock from any Android device, including Samsung A13 without you having to provide any details. Moreover, the simplified UI makes the process super easy. It works with both Windows and Mac.
Benefits of Using DroidKit:
- Bypass FRP on Samsung A13 in easy steps.
- Clear instructions for new users. No technical skills are required.
- High success rate in Samsung FRP bypass.
- All-in-one Android device manager.
Steps to Bypass FRP Lock with PC Using DroidKit
Step 1: Download and launch DroidKid on your PC/Mac via the official website.
A screen with several unlock options will come up, click FRP Bypass to proceed. Click Start when the following screen pops up.
Choose FRP Bypass Mode
Step 2: Grab the FRP-locked Samsung A13, connect it to the computer using a reliable USB cable, and click Start.
If DroidKit detects your connection, a screen with the different Android brands that FRP bypass works on will appear. Choose Samsung for this post to continue.
Choose Device Brand
Step 3: Without delay, the software will scan the device and prepare a configuration file to bypass the FRP lock on it. When the preparation is completed, click Start to Bypass.
Click Start to Bypass
Step 4: On the subsequent interface, choose your Android version (the one for the locked Samsung A13), and click Next. Apply the on-screen prompt that appears to enter factory mode. Once done, click Reset.
Complete Corresponding Settings
FRP bypass will commence immediately. Wait until DroidKit completes the process then you disconnect the Samsung phone from the computer and start using it without FRP lock issues.
FRP Bypass Complete
Part 2. Bypass FRP on Samsung A13 without PC
Not in possession of a PC? Don’t worry as we’ve got other techniques that you can follow to bypass FRP lock on your Samsung A13 without a PC. Check and apply any of the methods down here:
1. Use Samsung A13 FRP Bypass APK
With the help of an FRP bypass APK, you can also complete FRP removal on your Samsung A13 device. This app focuses on FRP lock removal on Samsung devices and it can achieve this by resetting the device. To use this approach, kindly get all of these ready:
- USB Cable and an OTG cable.
- USB flash drive.
- A PC.
Once the above are ready, then follow the steps below to bypass FRP on your Samsung A13:
- Install FRP bypass APK and turn on the Samsung A13 you are having FRP lock issues on.
- Next, the setup wizard for the FRP bypass APK will come up. Follow the basic instructions provided to complete the setup and move to the next stage of the guide.
- Afterward, you will be directed to a screen titled Bypass Factory reset protection. Sign in to your Google Account to proceed.
- With the help of a reliable USB cable, connect your Android phone to the USB drive where the FRP bypass APK is installed.
- Now, File Explorer will launch on your Samsung A13. Kindly go to the folder where you have the FRP bypass APK, launch it, and initiate the installation.
- During installation, you might encounter a few errors such as an unknown source error, block installation error, and more. Once either of these comes up, go to Settings and activate the Unknown Sources option. The installation should commence immediately.
- After installation is finished, you will be directed to the Settings menu.
- Scroll down the settings screen and click Backup and reset > Factory Reset.
- Lastly, hit the Erase Everything icon and your Samsung A13 will be wiped.
Also Read: How to bypass Google account without OTG
2. Bypass FRP Samsung A13 Android 12 Using Talkback
If your Samsung A13 runs on Android version 12, you can leverage the TalkBack feature on it to bypass FRP lock without a PC. However, mind you, this approach is quite lengthy and requires your full attention so you don’t miss any step. Here’s the guide to follow for you to successfully bypass FRP lock on your Samsung A13:
- Start with turning off the FRP locked Samsung A13 and rebooting it after a while.
- Once the device comes up, connect it to a nearby WiFi network and head to the welcome page.
- Next, hold down the Power button + Volume Up button simultaneously for a few seconds to activate TalkBack on your device. While doing this, a popup message will appear on your screen, select Use to proceed.
- After that, scroll down to the bottom of the subsequent screen and draw the letter L in reverse.
- Select Using the App > Use Voice Command, then speak the word Google Assistant in a loud voice so your device can capture the sound and generate results accordingly.
Activate Talkback
- On completing the above, the Google Assistant app will come up. Kindly hold down the Volume Up and Power buttons together at the same time to deactivate the TalkBack feature.
- Again using voice command, launch the Google Chrome app on your Samsung A13 by saying “Hey Google, open YouTube”.
- When YouTube opens, click on your profile picture icon and select Settings from the options displayed.
- Next, click on Version info > YouTube Terms of Service.
- Click the Continue with consent > Next > No I’m fine icons to proceed further.
- Google Chrome will launch on your device, please visit the firmware site and click the iOS Launcher New icon to proceed.
- Agree to the terms of use on the subsequent screen, sign in to your Samsung profile, and then install the iOS launcher app from the Galaxy Store afterward.
- With the help of another Samsung device, launch Chrome and download Package Disabler Pro and Notification Bar APK files from the apk page.
- Afterward, install both apps and launch on the second Samsung device. Ensure you sign in to the same Samsung profile on the FRP-locked device on your second Samsung device. Still, on the second Samsung device, turn off all options leaving the Account and Backup option.
- Head to Settings on the FRP-locked device and click on Accessibility > Interaction and Dexterity, then toggle the Assistant Menu on.
- Click on Assistant Menu Item and delete all you have underneath leaving the Settings menu.
- Navigate back to Settings, click on Accounts and Backup> Restore data. and hit the three dotted lines at the bottom right corner of your screen. If you see a prompt asking you to update your Samsung Cloud, skip it and redo the process.
- Once the above goes through, the assistant menu screen will appear. Stay on the page for about 10 seconds, and you will be directed back to the previous screen. When this happens, hit the App Only > Install icon.
- Now exercise patience for the app to be restored on the FRP-locked Samsung A13 device, then navigate to your home screen, launch the notification bar, and set it up.
- Click Accessibility > Installed Services > Notification bar and toggle the appropriate icon to enable it.
- Go back to the settings menu again on your device and click on Privacy > Permission Manager > Files and Media. Click on the three-dotted icon and enable View System.
- Locate the Package Disabler Pro click on it and select Allow management of all files.
- After that, disconnect from WiFI and start the Package Disabler Pro configuration. Once you get to the KLMS Agent screen, turn on the WiFi connection and wait patiently until the KNOX validation is completed.
- Input Setup in the search field provided and choose Android Setup.
- Check the Disable ticker and click on CLEAR DATA after the Samsung Wizard setup screen.
- Finally, go back and apply the onscreen instructions to complete the setup.
FAQs About Samsung A13 FRP Bypass
1. Will I lose data after Samsung A13 FRP bypass?
Definitely, data loss is imminent when you bypass FRP lock on your Samsung device using any of the methods above. However, if you have your Google Account password, and input it in the field provided on the FRP lock page, then data loss won’t happen.
2. Is it free to bypass FRP on Samsung A13?
Yes, it is free to bypass FRP lock on Samsung A13, in fact, all Android devices. However, when you use third-party software to get the operation done, you have to subscribe to complete it.
Bypassing FRP lock on Samsung A13 can sometimes be challenging, especially when you are a newbie and have no guide to assist you. But with this post at your disposal, getting rid of FRP lock from your device shouldn’t be a problem anymore. Select any method from the 3 techniques recommended and your device will be free from FRP restrictions. DroidKit is the most preferred method from the list provided. The software offers smooth removal of FRP without a password. Also, the steps required are short and not as lengthy as the others.
Vital Android FRP Bypass Tips
How to Bypass FRP in Different Situations
Joy Taylor
