This Samsung A12 unlock guide covers five ways to unlock your Samsung A12 without losing data, from using Find My Device to Safe Mode. It includes simple steps for each method and bonus tips for bypassing FRP locks. We recommend DroidKit – an efficient screen lock removal tool – featuring one-click unlock, FRP bypass, and reliable data protection for quick access.
DroidKit allows you to unlock any phone password, it supports 20,000+ models of phones & tablets. You can unlock the device no matter you forgot pin, pattern, face recognition, etc.
Do you need assistance with bypassing the Samsung A12 lock screen without losing files? This article provides five simple techniques to help users in getting back into their smartphones easily while keeping their content safe. From one-click solutions like DroidKit to using Find My Device, each method is easy to follow with clear instructions. We also offer extra tips for bypassing the FRP lock if needed. Continue reading to determine the most effective unlocking technique, and consider utilizing DroidKit for a speedy and effective Samsung A12 unlock!
Yes, a locked Samsung can be unlocked! Below are the ways of unlocking a Samsung device, particularly if you forget the pattern, PIN, or password. You can use DroidKit, Samsung’s Find My Mobile or Google’s Find My Device. Each technique involves a set of procedures, some easier than others. With most options, you won’t lose your data, but a factory reset might. Therefore, don’t panic if you’re locked out; you can effortlessly and safely get back into your Samsung using these ways.
Now, let’s discuss some ways to unlock the Samsung A12 Screen:
To unlock your Samsung A12 in one click, DroidKit- an all-in-one Android screen unlocker offers a quick, easy solution for users who may need to remember their lock screen password or need access without data loss. As a result, DroidKit’s Screen Unlock lets Android users remove locks, including PINs, patterns, and passwords, with no need for more sophisticated configurations. It is fully professional and simple, does not need specific programming, and is compatible with over 20,000 models. Moreover, DroidKit offers additional features such as system repair, data recovery, and FRP Bypass for Google accounts.
Key Features:
Now, let’s explore some simple steps to unlock Samsung A12 using DroidKit:
Step 1. Begin by installing DroidKit on your computer. Connect your Samsung A12 to the computer using a USB cable.
Step 2. Open DroidKit and choose “Screen Unlocker” from the main menu.
Choose Screen Unlocker
Step 3. Press “Start” to initiate the unlocking process.
Connect Your Android Device
Step 4. DroidKit will set up a configuration file, so wait a few moments for it to complete. Once ready, click “Remove Now” to continue.
Preparing the Configuration File
Step 7. Choose your device brand and then hit Next. Then follow the on-screen instructions to put your device into recovery mode and wipe cache partition on your device.
Step 8. DroidKit will begin removing the lock. Wait for the process to finish.
Remove Screen Lock
Step 9. Once you have done this, your Samsung A12 will restart, allowing you to access it without a password.
Using Find My Device allows users to manage their Samsung A12 remotely. This Google feature enables device location tracking and remote lock removal. After signing in with your Google account, you can erase the device, which removes the lock screen while resetting the phone. However, this process deletes all data, making it important to consider. For this method:
Step 1. Open a web browser on your computer and go to Google Find My Device.
Step 2. Log in with the Google account linked to your Samsung A12 by entering your email and password.
Step 3. Find your Galaxy A12 in the device list and click “ERASE DEVICE.”
Choose Erase Device
Step 4. Confirm by clicking “ERASE DEVICE” again and then tapping “Erase” to proceed. Once your A12 connects to the internet, it will reset, erasing all screen lock information, such as the Pattern, PIN, and Password.
Find My Mobile is a management portal offered particularly by Samsung for its devices. You can remotely unlock your A12 device by logging in with your Samsung account. This approach is a practical option for locked devices, enabling users to find and back up their phones if necessary. To use this:
Step 1. Go to the Find My Mobile website (now part of SmartThings Find) and log in with the Samsung account linked to your locked device. Select your device from the list that appears.
Step 2. Once your device is located, click on the “Unlock” option. Confirm your choice by clicking “Unlock” again.
Select Unlock Option
Step 3. Enter your Samsung account password and click “Next” to complete the unlocking process. Your device will then be unlocked, allowing you access.
A factory reset can unlock your Samsung A12 when other methods fail. This approach erases all personal data but restores access to your device. Although it’s a quick solution to regain control, users should know that all information will be lost. Therefore, it is recommended to backup important data.
To unlock Samsung A12:
Step 1. Press the power button until the menu appears, then select “Power off” to turn off your Samsung A12.
Step 2. Now, simultaneously press and hold the volume up and power buttons until the Samsung logo shows up. Release the buttons to enter Recovery Mode.
Step 3. Use the Volume buttons to scroll to “Wipe data/factory reset,” then press the Power button to select it.
Move to Wipe Data/Factory Reset
Step 4. In Recovery Mode, navigate to “Reboot system now” using the volume buttons and confirm with the power button.
Step 5. Your Galaxy A12 will restart, removing the previous pattern lock and allowing you to access your device.
Booting your Samsung A12 into Safe Mode helps troubleshoot lock screen issues caused by third-party apps. Users can temporarily disable these apps to identify and remove any problematic software. This method maintains all personal data while providing a safe environment to resolve lock problems, ensuring a smoother experience when accessing the device again. For this method:
Step 1. Press and hold the “Power” button until the power menu appears. Tap “Power Off” to turn off your Samsung device.
Step 2. Now, press the Power button again to turn the device ON until the Samsung logo appears and then hold the “Volume Down” button.
Step 3. “Safe Mode” will appear in the lower left corner of the screen. Once in Safe Mode, find and uninstall any third-party apps causing the lock.
Unlock via Safe Mode
Step 4. Restart your device to return to normal mode, and it should work without the lock.
DroidKit is an excellent tool for quickly getting around the FRP lock on your Samsung A12. Without erasing any data, it enables you to unlock your device, especially if it’s secondhand and you don’t know the Google account credentials. Quickly get back inside your phone with easy steps and an easy-to-use interface. Check out the simple steps to bypass FRP Lock on Samsung A12:
Step 1. Open DroidKit on your Mac or PC and select “FRP Bypass” from the main menu.
Click FRP Bypass
Step 2. Connect your Samsung device to the computer using a USB cable. Click on “Start” and choose your device brand.
Select Correct Brand
Step 3. DroidKit will generate a configuration file for your device. Ensure your phone remains connected during this step. Once ready, click “Start to Bypass.”
Click Start to Bypass
Step 4. Select your Android system version from the list and click “Next.”
Select the Correct System Version
Step 5. Follow the on-screen instructions in DroidKit and then click Reset to continue.
Go to Factory Mode
Step 6. After finishing the steps, DroidKit will help you regain access to your Samsung A12.
Droidkit Bypassing FRP
Q1. What is the default PIN for Samsung a12?
The Samsung Galaxy A12 does not have a universal default PIN. Instead, the PIN is typically set by the user during the initial setup or when enabling security features like the lock screen. If you haven’t set a PIN yourself, the device may not require one unless a specific security feature has been activated.
Q2. What if Samsung A12 hard reset not working?
If your Samsung A12 hard reset isn’t working, ensure you’re using the correct method by turning off the device and pressing the “Volume Up” and “Power” buttons until the Recovery Mode appears. If this doesn’t work, check if the buttons are functional, as faulty hardware can hinder the reset process. Alternatively, use software tools like “Samsung Smart Switch” to reset or restore the device via a PC, or “Samsung Find My Mobile” to reset it remotely if it’s linked to a Samsung account. For more advanced fixes, consider flashing the firmware using tools like “Odin”, but ensure you have the correct firmware for your device model.
Q3. Samsung Galaxy A12 unlock codes list?
Samsung Galaxy A12 does not have a universal “unlock code list” as unlocking depends on the type of lock and the situation. If you want to unlock you Samsung A12, Try DroidKit!
This post examined several ways to unlock your Samsung A12 without erasing any data. Each technique has its advantages and makes getting back into your device simple. For the most efficient solution, consider using DroidKit. It simplifies the unlocking process and ensures your data remains safe. We highly recommend downloading DroidKit for quick and reliable results.
