Your Samsung A10 is FRP-locked and don’t know how to solve this problem? No worries, we will introduce 3 effective ways to bypass FRP on Samsung A10/A10s no matter you are running Android 9, 10, 11 or 12. Keep reading!
Download DroidKit to bypass FRP on Samsung A10 in a few steps. No Google account or password is required. Support the latest Android 15 on all Samsung devices.
The Samsung Galaxy A10, a popular choice among budget smartphone users, comes packed with essential features and a sleek design. However, one security measure that can pose a challenge for users is the Factory Reset Protection (FRP) lock. The FRP lock is a security feature designed to prevent unauthorized access to your device after a factory reset, but it can also lock you out of your device if you forget your Google account credentials. In this guide, we will explore how to bypass FRP on Samsung A10 using different methods, ensuring you regain access to your device seamlessly.
Also Read: How to factory reset Samsung A10 without password
Generally, you can turn off FRP on Samsung A10 in the settings app before performing a factory reset. This operation requires the Google account password to be verified. Without a password, you may need to use a third-party FRP tool for Samsung A10 FRP bypass.
The easiest way to bypass FRP on Samsung A10 is using the DroidKit FRP bypass tool on your computer. It is a comprehensive tool designed to help users tackle various Android issues, including the FRP lock on Samsung A10 devices. DroidKit FRP bypass supports multiple Android brands running Android 6 to Android 15, such as Samsung, Xiaomi, OPPO, and more. Here’s a step-by-step guide on how to use DroidKit for Samsung A10 FRP bypass.
Step 1. Download and Install DroidKit on your Windows or Mac computer.
Step 2. Launch DroidKit and Select FRP Bypass from the main page. Then use a USB cable to connect your Samsung A10.
Choose FRP Bypass Mode
Step 3. Follow the instructions to choose the Android brand and initiate the FRP bypass process.
Choose Device Brand
Step 4. Wait for the process to complete. Once done, your Samsung A10 will restart without the FRP lock, allowing you to set up your device as new.
FRP Bypass Complete
Besides FRP bypass, DroidKit is also a useful tool for Android lock screen removal, Android data recovery, and Android system repair. It works as an all-in-one Android device manager for you to manage your phone easily.
Odin is a powerful tool used for flashing firmware on Samsung devices. This method requires some technical know-how, but it is effective in bypassing the FRP lock. Follow these steps:
Bypass FRP on PC with ODIN
Once your device restarts, follow the on-screen instructions to set it up. The FRP lock should be bypassed.
You may also like: How to fix Android stuck in Odin mode
Using an FRP bypass APK is another method, though it has a lower success rate compared to the previous methods. Here’s how to use an FRP bypass APK:
To avoid dealing with FRP lock in the future, it’s essential to turn off FRP on your Samsung A10 before performing a factory reset. Here’s how you can do it:
By following these steps, your FRP lock will be turned off.
Bypassing the FRP lock on a Samsung A10/A10s can seem daunting, but with the right tools and methods, it becomes manageable. This guide has explored three effective methods: using DroidKit, utilizing Odin, and employing an FRP bypass APK, as well as how to disable FRP before a factory reset. Remember, the DroidKit and Odin methods are more reliable, while the APK method may have a lower success rate. Always ensure you follow the steps carefully to regain access to your Samsung A10/A10s without hassle.
