Are you stuck on the FRP lock of your Samsung A03/A03 Core? Did you factory reset your phone and forgot the Google account password? This article offers you easy and convenient ways of bypassing FRP.
Samsung A03 and Samsung A03 Core come with Android 11, which is upgradable, and Android 11 Go version, respectively. Both phones were launched in November of 2021. Good battery life, dual sim, and a dedicated slot for microSD with good camera specs, among other features, were given to the customers at an excellent price.
However, some Samsung A03/A03 Core users says they get stuck on the FRP lock, which is a security feature of Android OS Version 5.1 (Lollipop) and higher. If you also forgot your Google account credentials and are now stuck on FRP, you have come to the right place. Here we will show you some easy methods to bypass Google account Samsung A03/A03 Core. Let’s move on to solving your problem after a brief discussion of both the Samsung A03 and A03 Core phones.
Samsung A03 and A03 core are priced very budget-friendly. Both phones offer dual sim, good connectivity, a 5 MP front camera, and a 5000 mAh battery. However, there are some differences in features, which are listed below:
Samsung A03 | Samsung A03 Core | |
Resolution | 720 x 1560 pixels | 720 x 1600 pixels |
RAM | 3 GB and more options | 2 GB |
CPU Cores | 2 GHz | 1.6 GHz |
Rear Camera | 48 MP + 2 MP Dual | 8 MP |
Weight (gm) | 196 grams | 211 grams |
Let us move to the next part of the article, where we will go through the steps of how to FRP bypass your Samsung A03/A03 Core phone using a PC.
If your device has been factory reset under any unfriendly circumstance, there’s a way to bypass FRP conveniently using a PC. Let us introduce you to DroidKit – Android Phone Toolkit. It is the one-stop solution for almost all Android problems, including FRP bypass. With this tool, you can bypass Google account/FRP lock in simple clicks without any hassle. And then, you can log in to another Google account and enjoy the service freely. You can learn more about what DroidKit can do for you below.
Now you can free download DroidKit and follow the steps below to bypass FRP on Samsung A03/A03 Core using DroidKit.
Step 1. Launch Droidkit and click on FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect the A03 or A03 core to the PC via a USB cable. Click on the Start button and select the brand of your device, which in this case is Samsung, to proceed.
Step 3. Wait while the process is preparing configuration file for your device. On completion of the process, the following window will appear. Click on the Start to Bypass button.
Click Start to Bypass
Step 4. Select the operating system and device model according to the screen interface and click on the Next button.
Choose System Version
Step 5. Proceed to the device’s current password interface and follow the on-screen directions to finish configuring the appropriate settings.
Complete Corresponding Settings
Step 6. Wait for the process to finish. Eventually, the device will restart, and the FRP lock will be removed successfully.
FRP Bypass Complete
We have discussed how to FRP bypass Samsung A03/A03 Core by using a PC.
If you don’t have a PC, there are other ways to FRP bypass that vary with your Android version. For Samsung A03/A03 Core with the Android 12 version, you need to follow the instructions given in the next part. Without delay, let us move to it.
FRP bypass is always technical and difficult to do without a PC. With the proper guidance, yes, it is possible. You can FRP bypass the Android 12 OS version of your Samsung A03 and A03 core by the following steps. Without further delay, let’s get to it.
FRP Bypass via Google Keyboard
Click on Developer options.
This is the simplest way to FRP bypass your samsung a03/a03 core with the Operating System version of both Android 11 and 12.
There is another way to bypass Android 11 via an app called Alliance Shield X. To know more about it, let us move to the next part.
You have already gone through how to bypass FRP via PC. Without a PC, it becomes very technical but still possible. If the phone is factory reset without signing out of the Google ID, the phone will ask for the previous Google ID password. To bypass FRP on Samsung A03 and A03 core, you need to consider the following steps,
Step 1. Switch on the phone and tap on ‘Start.’ Agree to the terms and conditions. Tap ‘Next’.
Step 2. Connect your phone to a WiFi network and return to the welcome screen. Tap several times on the blank area of the welcome screen until the setup is processed.
Step 3. Go to the WiFi Setup screen, tap ‘See All Networks,’ and then ‘Add new network.’
Step 4. Tap on the QR code scanner icon. When the QR code scan shows up, tap on the image icon.
Step 5. When Files appear on the screen, tap on the top left corner to expand ‘Open from.’ Now press and hold the Drive icon. Google Drive info will appear on the screen.
Step 6. Select permission and tap on the ‘Search’ icon. Type and search for ‘Settings’.
Step 7. Tap on ‘Settings’ from the search results. Tap on ‘Accounts’ and then ‘Add Account.’ Select ‘Samsung Account.’ Sign in with a samsung account ID and password.
Select Samsung Account
Step 8. Go back to the ‘Settings’. Find and tap on ‘Apps & Notifications.’ Tap on ‘All Apps.’ Find ‘Android setup’ and select ‘Force Stop.’ Tap ‘Storage’ and then tap ‘Clear Cache.’
Step 9. Select ‘Google Play Services’. When it opens up, Tap on ‘Disable’ and ‘Force Stop it.’ Select the Samsung Setup wizard and tap ‘Force stop it.’ Tap on ‘Chrome’ and search for https://tiny.cc/frptools or https://bit.ly/2NKxXYs
Step 10. Go to the FRP bypass APK and tap the ‘FRP Apps section.’ Select and Open ‘Direct Install Alliance Shield Manager.’ The Galaxy store will open up. Install and Open the ‘Alliance App Shield X App.’
Step 11. Now tap Next > Next > Next > Got it
Step 12. Tap ‘Register’ and enter your username, password, email, and confirmation code. Tap ‘Submit’ and verify your email. If you already have an Alliance Shield Account, just sign in.
Access the Alliance Shield App
Step 13. Name your device and proceed by tapping on ‘Next.’ Enable ‘Device Admin’ and then tap ‘Activate.’ Samsung Knox is not present on the phone; tap ‘Next’ and ‘Finish.’ Tap on ‘App Manager.’
Step 14. Search and open ‘Android setup’ and then ‘Actions.’ After this, tap ‘Force Stop’ and ‘Wipe App Data.’
Step 15. Then go to ‘Activities.’ Select and Open ‘Android Setup’. (com.google.android.setupwizard.predeferred.PreDeferredSetupWizardActivity)
Step 16. Now your device will show ‘To Unlock Sign In With your Google Account.’ Lock the phone by pressing the power key.
Step 17. Open the notification bar and tap ‘Settings.’ Select ‘General Management’ and then ‘Reset’. Tap ‘Factory Data Reset’. Enter your password into your Samsung account and then tap ‘OK.’
Eventually, the FRP lock will be removed from the Samsung A03/A03 core.
In the next part, some of the frequently asked questions regarding Samsung A03 and A03 Core are listed. To know more, let us give it a read.
How do you track the Samsung A03/A03 Core using the Find My Mobile service?
If the phone is lost, it can only be tracked if the phone is connected to the internet via WiFi network or Mobile data. To enable this feature,
How do I set up the APN and reset it on the Samsung A03/A03 Core?
If the APN settings are incorrect, you can set it up yourself. To do so, follow the instructions,
How do you check the signal strength on Samsung A03/A03 Core?
To check the signal strength, follow the given instructions,
That’s all about the Samsung A03/A03 Core FRP bypass! We have provided you with three ways of doing it. Follow the step-by-step guidance given above to bypass FRP.
Among all, Droidkit is the best tool to bypass FRP on your Samsung A03/A03 core due to its convenience and high success rate. It also has many other features, including a screen unlocker, data recovery, data extractor, data manager, system cleaner, and so on. Just free download DroidKit to try it now!
