Ultimately, a detailed comprehensive review should come in handy when you need to invest in a product you aren’t familiar with. This post is structured to discuss everything about the FRP bypass tool- Apex Launcher APK. In addition, we extend our discussion to the best alternative.
If you’re searching for an FRP bypass tool, DroidKit should be the top choice. This complete Android solution provides you with a Google FRP bypasser for Windows & Mac. And you can bypass any Samsung phone & tablet, Xiaomi, and Redmi FRP lock without any hassle!
Hi there,
I got a second-hand Android phone via auction after placing the highest bid. I got the device yesterday and everything on it was in good condition. However, unfortunately, it’s FRP locked. My colleagues at work suggested that I use the Apex Launcher APK to remove the FRP restriction. I’m kind of confused about the tool because I don’t know how it works. Is there anybody who has used this tool before now? If so, please what can you say about it?
Whether the situation above sounds familiar to you, or you’ve got something related, this post has got you covered. Here, we discuss everything about the Apex Launcher APK tool, which includes a brief description of it, how it works, the pros and cons plus the best alternative. Keep reading!
Further Reading: How to Bypass Google Account without OTG Cable or Computer >>
Apex Launcher FRP Bypass is a popular APK program focused on FRP unlock operations. It’s well-known for deactivating FRP locks on Android smartphones like Samsung, HTC, LG, and many others.
This program poses itself as the best FRP bypass tool in the industry because of its flexibility and broad functionality. Using Apex Launcher FRP Bypass is easy, as it powers a simple interface to ease users’ navigation.
Apex Launcher FRP Bypass has lots of interesting features under its radar. Some of these features include:
Below, we look at the advantages and disadvantages of using the Apex Launcher FRP Bypass tool, so you can decide to invest in it or find an alternative:
Pros
Cons
How to Use Apex Launcher APK to Bypass FRP
Firstly, you have to install the Apex Launcher FRP Bypass tool before using it to fix FRP lock on your Android phone. Check out the instructions below to download and install the program:
Now that you’ve successfully added Apex Launcher FRP Bypass to your phone, let’s proceed to how to use it.
Although Apex Launcher FRP Bypass is a cool tool to deactivate FRP lock screens, it’s better suited for people who are more technically savvy. If you need a perfect alternative, then you should invest in the DroidKit Android unlock tool.
DroidKit – Android Phone Toolkit is the most efficient Android repair tool suitable for fixing FRP screen locks. It offers the easiest way to deactivate FRP on an Android phone, as it scans your device and recommends a compatible firmware package to fix the system.
This software removes FRP locks from your phone at a great speed without compromising the data on it or crashing the OS. DroidKit is lightweight, simple to navigate, and powers several customizable features.
DroidKit Android Unlocker
Here are some fantastic things powered by the DroidKit Android unlock tool:
DroidKit Full Version
DroidKit is a complete Android unlock tool with lots of incredible features to help fix your Android phone. It deactivates FRP locks without complications. Unlike Apex Launcher FRP Bypass, this software removes FRP at a remarkably high speed with no rigorous steps involved. What’s more, its other functions, such as unlocking screen locks, recovering data, etc., can help you solve the problem in time. With DroidKit as a one-stop tool, you don’t need to spend a lot of money to find a professional service, but to solve the problem at home!
What DroidKit can do for you with its FRP Bypass function:
Free get DroidKit and follow the detailed step guide to unlock FRP lock now:
Step 1. Download and Install DroidKit on your PC > Launch it and choose FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect the FRP-locked Android phone with a USB cable > Click on the Start button.
Step 3. DroidKit will prepare the configuration file for your device > Tap on Start to Bypass. Follow the steps on the screen to put your phone into recovery mode > Select your device’s Android and tap on Next.
Step 4. Follow the steps on the screen to put your phone into recovery mode > Select your device’s Android and tap on Next. Set up your phone according to the on-screen instructions, including wiping the cache partition.
Choose System Version
Step 5. After that, it will start to bypass FRP lock automatically. You will see the interface below when it is completed.
FRP Bypass Complete
Now we’ve explained everything about Apex Launcher FRP Bypass, you can easily decide whether or not to invest in it. However, we advise that you use DroidKit for FRP lock operations instead of the Apex Launcher FRP Bypass. It’s the best tool to fix FRP on your phone. Explore more about DroidKit now >>
