In search of a workable way to reset a Nokia Android phone when locked? Look no further. In this post, we will introduce a comprehensive guide that discusses the various ways to reset a Nokia Android phone. Also, we look at an alternative way to unlock a Nokia Android phone using software.
How to reset a phone that is locked? Just free download DroidKit to 1-click reset and unlock your Android device. It unlocks all screen locks like Touch/Face ID, passcode, pattern, etc. All Android devices like Samsung, Huawei, LG, etc. can be reset and unlocked by DroidKit.
Password protection on a Nokia phone can sometimes be a problem for a user, especially when you cannot remember the corresponding details used in locking your screen or a technical problem with Android software. In such a scenario, the best thing to do is to reset the device to default mode. That way, the screen lock password clears automatically, and you can create a new one.
But how do you reset your locked Nokia Android phone?
Is the method safe to use?
If you find yourself asking these questions, then this post is for you. Here we discuss everything about how to reset a Nokia phone that’s locked. In addition, we look at an alternative way to unlock a Nokia phone.
Reset is a restoration service designed to wipe or erase all content and settings stored on a mobile device or computer system. It’s often used to return most digital devices back to default settings, just like when it was newly bought.
Some of the content and settings that are erased via the reset include photos, contacts, documents, installed apps, and more. Before resetting a device, we strongly recommend that the owner back up all crucial data (content and settings) to avoid sudden loss.
While resetting will help you return your device to default or factory mode, it can also be used to remove screen locks.
Resettings your Nokia phone has its merits and demerits. Kindly check them out before proceeding with reset:
Factory Reset is similar to reset, as your device is returned to default mode. All installed apps, downloaded documents, contacts, and other files are cleared immediately after factory reset.
Before putting your Nokia phone to factory reset, kindly backup your crucial files. Once done, follow any of the directions below to reset the Nokia phone via factory reset:
Nokia has a reset code that can be used to restore it to factory settings. You can also use this code to unlock it. Follow the stepwise guide below to use the factory reset code to unlock your Nokia phone:
Step 1: Launch the Dial tab on your phone by clicking on the Phone ? icon.
Step 2: Next, type the factory data reset code: *2767*3855#.
Step 3: Once done, your Nokia Android phone will return to the factory settings, and automatically unlock.
Use the code *#*#7780#*#* to factory format your Nokia Android phone. The code only clears all files and settings. It doesn’t give the same results as the factory data reset code.
The aforementioned factory reset option only works when your Nokia Android phone isn’t locked. However, in a situation where it’s locked, this option works best. Follow the steps down here to reset with a code:
Step 1: Turn off the Nokia Android phone using the right key combinations.
Step 2: Next, hold and presses down the following buttons in the same order as below:
Ensure the keys above are held together simultaneously. Once done, a Formatting message will pop up on your screen.
Step 3: Now release all the keys, and wait patiently for your Nokia Android phone to reset to factory settings. Once completed, your device will unlock automatically.
Alternatively, you can reset your phone using the instructions below:
When next you want to set up password protection on this factory reset Nokia Android phone, use 12345 as your security code.
While a factory reset can help clear screen lock issues on a Nokia Android phone, it’s not the best option to employ, as data loss is often incurred. If you wish to unlock your Nokia Android phone without losing any data (content and settings), a professional Android unlock tool must be used.
There are countless Android unlock software on the internet to fix screen lock issues on your Nokia device, DroidKit – Android Phone Toolkit is the best option. With DroidKit, you can easily remove the screen lock from your Nokia phone with just a single click.
Your device doesn’t have to be unlocked for you to use this software. DroidKit bypasses the screen lock on your Nokia phone by scanning the device and installing a new firmware package. We strongly recommend this software because of the capability to remove screen locks without compromising your device or the data on it.
Free get DroidKit on your computer >>and learn how to unlock/reset Nokia phone with the simple steps below:
Step 1: Free download and launch DroidKit > Tap on the Screen Unlocker icon to proceed.
Choose Screen Unlocker
Step 2: Connect your Nokia phone to your computer with a USB cable > Hit the Start icon.
Connect your Locked Phone
Step 3: Now DroidKit will recognize your device and then prepare a configuration file for you > Tap on Remove Now button.
Click Remove Now Button.
Step 4: Once done, DroidKit will ask you to select your Android brand. Locate and click Nokia > Put your phone into Recovery Mode and follow the on-screen instructions to reset Nokia.
Finish Settings on Samsung
Step 5: Then, DroidKit will start removing the screen lock. Wait a minute, you will see the Screen Lock Removal Completed as below.
Lock Screen Removal Completed
For more info about the workable ways to reset a Nokia Android phone when locked, check out the queries and answers below:
Besides factory resetting, you can also unlock your Android phone using your Google Account or a third-party Android unlock tool like DroidKit. However, the latter option is the best way, as you don’t need to provide anything to unlock your phone.
On the other hand, the former, which involves Google Account, requires that you know/remember the password to the Google Account linked to the Android phone.
A factory reset can also be done via the settings panel of your Nokia Android phone. Follow these steps to do that:
With the guide above, you can easily reset your Nokia Android phone when locked. Of all the techniques provided, the DroidKit option is the best. DroidKit clears screen locks without tampering with your phone data or the OS. The software is worth investing in if you want to bypass screen locks freely and quickly without issues. Learn more about DroidKit now>>
