Phone locked with passcode, Face ID or pattern and failed to unlock it? Android Device Manager unlocks the device to regain access to your phone. Or you can use an alternative Android password unlocker to unlock Android phone without Android Device Manager or without Google account.
Free download DroidKit to remove any kind of locks on Android phones to unlock your device in one click.
Privacy of the phone content is important for everyone, and we most commonly use locks to protect our photos, videos, contacts, and documents from unauthorized access. But sometimes we can’t access our phones because we can’t unlock them. Luckily, there is a tool that can help us with it.
Unlock Android Device
Android Device Manager is an integral part of Android OS and arrives on every new phone. It’s packed with innovative and effective features, allowing the user a lot of possibilities. You can use the unlock option to quickly get around the passcode and get access to all the data on your device.
As we previously explained, Android Device Manager is a great option for unlocking Android phone without losing data, but you can use it only if you enable it before forgetting the password. If you currently don’t have a problem accessing your phone settings, set up ADM, and save your time in the future.
Click the Erase Button to Unlock Your Android
Here are the steps for unlocking the Android phone with Android Device Manager:
ADM will successfully remove the lock in just a few moments. If something doesn’t work properly, try again, and check the internet connection. When the process of removing the screen lock finishes, you can immediately use the new password and access your Android data.
In case you can’t activate Android Device Manager unlock function because you didn’t enable it on the phone before locking, there is an amazing Android screen unlocker, called DroidKit. This full-way Android phone data savior is designed to help you fix many Android system problems like Android can’t be unlocked.
You can easily remove any type of screen lock, even face recognition and fingerprints. Also, it supports FRP bypass on Android. Besides, it can restore lost data from many outlets, like restoring data from your Google account. Check some of its main features below.
To remove a screen lock from any Android smartphone using DroidKit, just follow these steps:
Step 1. Download and install DroidKit on your computer and launch it. Connect your Android phone to the computer via a USB cable and choose Screen Unlocker.
Choose Unlock Screen Function
Step 2. Read the information on the next page. Connect your phone to the computer and click on the Start button.
Connect your Locked Phone
Step 3. When you see the interface below, click the Remove Now button.
Click Remove Now Button
Step 4. Select your device brand and click Next.
Step 5. Follow the steps below to remove the screen password.
Finish Settings on Sony
Step 6. Once you finish the above steps, DroidKit will start removing the screen lock. Wait a minute, you will see the Screen Lock Removal Completed page below.
Lock Screen Removal Completed
After unlocking the screen lock on your phone, you can enter the device again without password. DroidKit makes it possible to restore data on your phone when you set up it after unlocking, including photos, contacts, messages, and other important files.
Android Device Manager is a security tool that provides system visibility, remote app management capabilities, automatic security updates and more management functions for Android devices. It can be used to find, lock or erase a lost phone to ensure data security.
To enable Android Device Manager, you can follow the steps.
Step 1. Go to your Android device Settings>Locations>Turn on Location access.
Step 2. Then go to Settings>Google>Security>Remotely locate this device, also check “Allow remote lock and erase”.
Step 3. In security settings, scroll down and tap “Device administrators”, then check “Android Device Manager”.
Thus your Android Device Manager has been enabled successfully.
If you can’t unlock your Android device due to some unavoidable reasons, you can use ADM to erase your phone and set it up later. As long as you have enabled Android Device Manager before locking the phone. Otherwise, you can use Droidkit to remove the screen lock in your device to regain access.
You can deactivate Device Lock Controller on Neon Ray Pro with the following steps.
Step 1. Go to Settings and access the Lock Screen option.
Step 2. Toggle off the switch to disable the device lock controller immediately.
Step 3. Then your Device Lock Controller on Neon Ray Pro will be deactivated. If you’d like to re-activate it, go to Settings and enable it in seconds.
If you ever find yourself in a situation where you forget the screen password, it’s good to know that you have amazing solutions at hand to quickly resolve this problem. A great internal tool for Android smartphones – Android Device Manager, with an unlocking feature, can bypass any type of lock in a few steps. Also, as a great and effective alternative, you can try multipurpose DroidKit software. Download it right now!
