3 Ways to Bypass FRP on Realme C11 Without Password
The Realme 11 is popular for its impressive design, strong performance, and affordability. Key features include a high-resolution camera, long battery life, fast charging capabilities, and a vibrant display. It’s particularly appreciated for offering premium features at a budget-friendly price, making it an attractive option for value-conscious consumers.
Author Avatar Joy Taylor Last Updated: Jan. 03, 2025
You may set up your Realme C11 with a Google account. But you forget the account information when you want to sell it or give it away. Then the next person will get stuck on the FRP lock screen after factory resetting Realme C11. Don’t worry, here we will introduce 3 ways to bypass FRP on Realme C11 without a Google account or password.
Also Read: How to unlock Realme phone without screen password
Method 1. Bypass FRP on Realme C11 Android 11/12/13/14
There are several ways available to bypass FRP on Realme C11. However, some FRP bypass methods may have restrictions on your Android version. Some methods only work for Relame C11 FRP bypass on Android 11, while the others may be available on Android 12 only.
DroidKit FRP bypass is a powerful tool for Realme C11 FRP bypass on Android 6 to the latest Android version. It supports more than 10 Android brands to bypass Google accounts after factory reset, including Realme, Samsung, Xiaomi, and more.
How to bypass FRP on Realme C11 with DroidKit:
Step 1. Download and install DroidKit on your computer. Both Windows and Mac are supported.
Step 2. Launch DroidKit and choose FRP Bypass from the main screen. Then use a USB cable to connect your Realme C11.
Choose FRP Bypass Mode
Step 3. Choose your Android brand from the page and continue. Here you can just click the Realme icon.
Choose Device Brand
Choose Device Brand
Step 4. Follow the instructions to finish the FRP bypass on Realme C11.
FRP Bypass Complete
FRP Bypass Complete
When the FRP bypass process is finished, your Realme C11 will restart and you can set it up with a new Google account.
Method 2: Realme C11 FRP Bypass with Reset Code
Besides using the DroidKit FRP bypass tool, there are 2 ways to bypass FRP on Realme C11 for free. These 2 methods are available for Realme C11 FRP bypass with some complicated operations. And the success rate is low according to some tests. Just like the master code to unlock Android phone with passcode, using a reset code is another straightforward method to bypass FRP on your Realme C11. This method involves using a secret code to reset the device, bypassing the Google account verification.
Access the Dialer:
  • On the welcome screen, tap on the “Emergency Call” option.
  • Enter the following code: *#*#7378423#*#*.
Service Menu:
  • The code will open the service menu. Navigate to “Custom Settings” and select “Factory Reset.”
  • Confirm the factory reset process.
  • Complete the Setup:
  • Once the reset is complete, your Realme C11 will reboot.
  • Follow the on-screen instructions to set up your device. You should now bypass the FRP lock and gain full access to your phone.
You may also like: Master code to unlock
Method 3: Use Talkback to Bypass FRP on Realme C11
The Talkback method is a widely used technique to bypass FRP on Android devices, including the Realme C11. This method exploits the accessibility features to bypass the Google account verification process.
Activate Talkback:
  • Turn on your Realme C11 and connect to a Wi-Fi network.
  • On the welcome screen, tap on the text field for Wi-Fi password input and hold the “@” symbol until a settings menu appears.
  • Select “Google Keyboard Settings.”
Access Help & Feedback:
  • In the Google Keyboard Settings, tap on the three dots in the upper-right corner and select “Help & Feedback.”
  • In the Help & Feedback menu, type “Use Morse Code” and select it from the list.
  • Play the video embedded in the help article and tap on the video link to open YouTube.
Open the Browser:
  • Once on YouTube, tap the account icon and then “Terms & Privacy Policy” to open the browser.
  • In the browser, navigate to a trusted APK download site and download an FRP bypass APK (e.g., QuickShortcutMaker).
Install and Run the APK:
  • Once the APK is downloaded, install it by allowing unknown sources in the settings.
  • Open the installed app and use it to navigate to “Google Account Manager” and then “Google Account Login.”
  • Use the app to add a new Google account.
Complete Setup:
  • Restart your Realme C11 and complete the setup process. You should now be able to bypass the FRP lock.
FAQs About Realme C11 FRP Bypass
1. What is the best FRP bypass tool for Realme C11?
Among most FRP bypass tools in 2025, DroidKit is efficient and easy to use. It works on Android phones and tablets for more than 10 Android brands. DroidKit is worth trying if you want to bypass FRP on Realme C11.
2. Can I bypass FRP on Realme C11 without a computer?
Yes, you can bypass FRP on Realme C11 without a computer. Methods like using the Talkback feature or entering a reset code directly on the device do not require a computer. Also, you can try some FRP bypass APK to bypass FRP on Realme C11 without computer.
Bypassing the FRP lock on your Realme C11 can be challenging, but it is achievable with the right methods. This article covered three effective ways to bypass FRP on the Realme C11 without a password: using DroidKit, utilizing a reset code, and leveraging the Talkback feature. Each method provides a step-by-step guide to help you regain access to your device. DroidKit is recommended to try with easier steps and a higher success rate.
