Download MSM Download Tool Latest Version and How to Use
Are you struggling with making a decision on whether or not you should invest in the MSM Download tool? This post is what you need. Here, we’ve compiled everything about the MSM Download tool, including the pros, cons, and a detailed guide on how to use it. In addition, we share the alternative to MSM Download tool.
Author Avatar Joy Taylor Last Updated: Nov. 14, 2023
Ever heard of the MSM Download tool but don’t know anything about it? If so, and you are looking for a comprehensive overview of it, this post has got you covered.
Here, we give you a detailed overview of the MSM Download tool, which will cover what MSM Download tool is, the pros and cons, with the corresponding how-to guide. Furthermore, an alternative MSM Download tool will be introduced.  Keep reading.
What Is MSM Download Tool?
MSM Download Tool is a popular program specifically for Oppo, OnePlus, Realme, and Vivo Android users to flash stock the firmware package associated with their devices. It also comes in handy when you need to clear or fix software issues like OS crash, Android boot loop, and more.
Additionally, you can use the MSM Download Tool to fix FRP Lock and remove password protection like patterns, PINs, and others. The MSM Download Tool integrates well with the Windows computer system.
What Can MSM Download Tool Do?
The MSM Download Tool is designed to fix a plethora of complications arising from the rooting or flashing of an Android device. With this program, you can quickly clear problems like FRP Lock, forgotten passwords/patterns, screen stuck at the boot logo, DRL errors, and more from the comfort of your home.
Although factory reset can also fix the aforementioned problems, it’s not a reliable solution as the problems might still persist. So, therefore, MSM Download Tool is the better solution.
While MSM Download Tool helps you fix complications on your Android device easily and quickly, it does have its dark sides. Some of the problems with this tool include;
  • Connection timeout error.
  • Advanced user interface, which makes it difficult for newbies in the tech space to navigate around.
  • Sudden loss of data.
  • If not properly used, it can cause your phone OS to crash.
  • The stepwise guide to use MSM Download Tool is quite lengthy.
With all of the downsides above, if you still wish to use the MSM Download Tool for your device, apply the procedure in the next section of this post.
How to Download MSM Download Tool Latest Version?
Use any of the links in the table below to download a version of the MSM Download Tool on your Windows computer system:
Version Download Link
MSM Download Tool DOWNLOAD
MSM Download Tool 4.0.58 DOWNLOAD
MSM Download Tool 5.0.15 DOWNLOAD
  • After downloading MSM Download Tool, navigate to the download folder on your computer, and extract the corresponding files.
  • Once done, run the MSM Download Tool folder.
  • Now kindly install the PDAnet.exe file and CodeMeterRuntime.exe.
  • Next, proceed to open CodeMeterRuntime.exe and click on the Licence file icon.
  • import the corresponding Licence, then head to where you have Oppo_MSM_Download_Tool_None_Lic_2000.
  • Once you see the Licence Activated message, then the MSM Download Tool is successfully installed, and you can use it.
How to Use MSM Download Tool for OnePlus?
Check out the direction below to use the MSM Download Tool for your OnePlus Android phone:
Step 1: Firstly, update or install the most recent USB Driver on your Windows computer to enhance smooth communication between your phone and the tool. After that, download and extract the appropriate version of the MSM Download Tool on the computer using the guide above.
Step 2: Once done, run the tool, and the interface below will appear on your Windows computer screen:
Step 3: Log in with your details, and select Other from the options under User type. Hit the Next button to continue.
Step 4: Now put off your OnePlus phone and activate EDL mode so that the MSM Download Tool can access and flash it. Use the guide below to enable EDL mode:
  • Press the Volume Up and Volume Down buttons simultaneously.
  • Keep holding both keys, then connect the phone to your Windows computer.
  • Once MSM Download Tool recognizes your phone, you will find the Connected prompt on your screen just as below:
Wait for the Connected Prompt
  • Wait patiently for the MSM Download Tool to flash the stock firmware of your OnePlus phone.
  • After that, your device may commence the factory setup screen. Configure your device and start using it.
Note: To successfully use MSM Download Tool to fix your Android device, there are certain pre-conditions to fulfill. Find below some of these preconditions:
  • Firstly backup your device before you proceed with using the MSM Download Tool to fix any issues. The reason is that MSM Download Tool flashes your device clearing all installed apps, photos, videos, and many other types of data.
  • The device must be 60% charged before you proceed with employing the service of the MSM Download Tool.
  • You must have an Android USB Driver installed on your PC.
Best MSM Download Tool Alternative – DroidKit
No doubt that the MSM Download Tool is quite complicated to use. Besides the lengthy stepwise guide, you need to be careful while using it to avoid bricking your phone. To avoid all of these issues, a third-party Android unlock tool like DroidKit can be used to bypass screen lock on your OnePlus phone.
DroidKit is the #1 Android unlock tool suitable for fixing the screen lock issue you are currently battling with on your OnePlus. This simple yet efficient software fixes screen lock without compromising the device or data stored on it.
Unlike MSM Download Tool, which is limited to Oppo, Vivo, Realme, and OnePlus, DroidKit removes screen lock for a variety of Android brands, such as Samsung, Nokia, Lenovo, HTC, and those which MSM Download Tool supports.
Next, you can get DroidKit for free on your computer, and learn how to unlock any phone password with the simple steps below:
Step 1. Launch the software and click Screen Unlocker.
Choose Screen Unlocker
Step 2. Connect your Android phone via a USB cable and Start to unlock. Note: All content on your device will be erased after the screen lock gets removed successfully.
Connect your Locked Phone
Step 3. After the connection, DroidKit will prepare the configuration file for you. Once finished, tap on Remove Now button to continue.
Click Remove Now Button
Step 4. DroidKit will detect your device brand. Here we take Samsung as an example, you can follow the on-screen instructions to remove Samsung’s password.
Finish Settings on Samsung
Remove Password on Samsung
Step 5. After that, DroidKit will start the unlocking process immediately. Wait a minute, you will see Screen Lock Removal Completed page below.
Lock Screen Removal Completed
FAQs on MSM Download Tool
Enhance your knowledge about MSM Download Tool with the frequently asked queries and answers below:
Where are hidden apps stored on Oppo?
There are several ways to hide apps on your Oppo phone. You can choose to use the built-in App Lock or install a third-party tool to help you out. However, should you use the built-in App Lock on your device, follow these steps to find the hidden apps:
  • Tap on the Phone icon to access the dial page.
  • Next, enter your App Lock passcode (also known as Access Number), and the hidden app page will come up.
How long does the MSM Download Tool work?
The MSM Download Tool does not have a stipulated time frame for operation, however, the tool is subject to stop working at some point. While the software can start fixing your Android device immediately, it may take some time to work for other users. Thus, its operation fluctuates.
Can I install an APK app on Oppo?
Sure, you can. However, you need to make provisions for the corresponding APK app to install on your Oppo device successfully. Here’s how you can do this:
  • Click on the Settings buttons (the gear ⚙️ icon on your phone Home Screen).
  • Scroll and click Security > Unknown source installations.
  • Now turn ON/OFF the app
With this post, you can easily tell whether or not you should invest your funds in the MSM Download Tool. Even though the tool can help you fix screen lock issues, DRL errors, FRP locks, and more, there are too many downsides attached to it.
We implore you to use DroidKit Android unlock software in place of the MSM Download Tool. It powers all of the wonderful features of the MSM Download Tool and more, such as junk file removal, data recovery, data management, etc. This software unlocks your device without distorting your data.
