This guide explains Mi Flash Unlock, what it is, and how to unlock your Xiaomi device. It also covers how to unlock a Mi locked screen. Finally, it introduces DroidKit as an efficient tool for screen unlock, providing simple steps for using it. We recommend using DroidKit, an efficient screen lock removal tool that ensures data integrity and support for various Android devices.
Are you locked out of your Xiaomi phone and unable to access it? Mi Flash Unlock comes in handy in this situation! With the aid of Mi Flash Unlock, you may quickly unlock your Xiaomi device and resume access to your important and valuable data. We’ll define Mi Flash Unlock and walk you through the unlocking process in this 2024 guide. However, we suggest utilizing DroidKit, a tool that can remove screen locks without erasing your data, if you want a quick and secure method to unlock Android devices.
Xiaomi developed an official tool named Mi Flash Unlock Tool to unlock the bootloader of their Xiaomi, Redmi, and POCO devices. Unlocking the bootloader offers advanced customizations, such as installing custom ROMs, rooting, or simply changing your device’s OS. Mi Flash tool’s key functions include compatibility with most Xiaomi models, a simple setup, and a fast unlock process. This tool is essential for users who want more control over their device’s performance and software. Some of its additional features are:
Key Features
Check out the steps below to use the Mi Flash Unlock Tool:
Step 1. Download and install the Mi Flash Tool from the official website.
Step 2. Power Off your Mi mobile device. Press and hold the “Volume Down” and “Power” buttons simultaneously to enter Fastboot mode. Look for the Fastboot screen with the Mi rabbit mascot.
Fastboot Screen
Step 3. Continue by connecting your mobile to your PC through a USB cable.
Step 4. Download the Mi Unlock Tool zip file and extract it using 7Zip or another archive program.
Step 5. Double-click on “miflash_unlock.exe” to open the unlock tool on your computer.
Step 6. Log in to your Mi account using the tool interface.
Login to Mi Account to Unlock Phone
Step 7. The tool will check if your Mi account is linked to the connected phone. When done, you will see, “Phone connected.”
Phone Connected
Step 8. If prompted, click “Unlock anyway” to unlock the bootloader.
Step 9. The tool will show the unlocking progress. Please remember that this process will erase all data on your device. Once it’s done, you’ll see “Unlocked successfully.”
Step 10. Choose “Restart Mobile Phone” for rebooting your device. You might see a warning about the unlocked bootloader when it boots up. Follow the on-screen instructions to set up your device and log in to your Google or Mi account.
For Android users who may find themselves locked out of their mobiles for various reasons, DroidKit— a reliable Android Unlocker tool— is helpful. Its Screen Unlock feature empowers users to unlock their phones without rooting their devices or needing complex technical knowledge about it. Whether the device has a fingerprint, PIN, Password, or face unlock set up, DroidKit will have you covered in any scenario.
Moreover, DroidKit can be the perfect choice for users who have purchased a secondhand Xiaomi device with FRP lock on! It lets you bypass the FRP lock and get back access to your device. In addition to unlocking, this program offers Data Recovery features that can help you recover deleted contents from your SD card or device. It is a flexible option for anyone experiencing device issues because it also features a System Repair feature to resolve typical Android faults.
Key Features:
Here are the steps to unlock your locked screen using DroidKit:
Step 1. Start the process by installing DroidKit on your computer. Link your Android device to the computer by a USB cable.
Step 2. Open DroidKit and select the “Screen Unlocker” mode from the main screen.
Choose Screen Unlocker
Step 3. Click the “Start” button to begin the process.
Connect Your Android Device
Step 4. Wait while DroidKit prepares the configuration file for your device. Once preparation is complete, you will see a new interface. Click the “Remove Now” button.
Preparing the Configuration File
Step 5. Select your device brand and head to Next. DroidKit will give your instructions to put your device into recovery mode and wipe cache partition on your device.
Step 6. After this, the tool will begin removing the screen lock. It will take a few moments, so please be patient.
Lock Screen Removal Completed
Step 7. Your device will restart after the unlocking procedure is complete, enabling you to view all your data without inputting a password.
DroidKit’s user-friendly design and unambiguous instructions make it the perfect solution for anyone looking for a dependable and speedy method to regain access to their Mi device.
This post covered how to use the Mi Flash Unlock tool to unlock your Mi devices. We reviewed the procedures and emphasized the importance of protecting your data while unlocking. A dependable solution is essential if you are locked out of your phone. This is where DroidKit is useful. You can quickly unlock your Android cellphone using this tool. For a simple and secure method of getting back into your phone without erasing any data, we advise downloading DroidKit.
