How to Unlock Home Screen Layout Samsung/Android
If home screen layout is locked, how to unlock it? In this post, we will show you how to unlock home screen layout easily and quickly.
Author Avatar Joy Taylor Last Updated: Aug. 14, 2024
You’ve just picked up your trusty Android device, eager to customize your home screen perfectly. You want your favorite apps at your fingertips, arranged just as you like them. But, to your surprise and frustration, your home screen layout is locked, seemingly trapping your apps in a digital puzzle.
We’re on the verge of uncovering the reasons behind your locked home screen layout and, most importantly, how to liberate yourself from its restrictions. Brace yourself to reclaim authority over your home screen, shaping it to reflect your unique style.
Moreover, if you’ve ever encountered the predicament of being entirely locked out of your Android device, stay tuned for a valuable bonus tip that could prove to be a lifesaver. Let’s plunge right in!
Bonus Tip: Here are some other Android tips for you.
Why Is Your Home Screen Layout Locked?
Your smartphone is your trusty companion, but it can be downright perplexing when your home screen layout decides to play hard to get. Here, we’ll uncover the potential culprits behind your locked home screen layout, shedding light on this digital mystery.
  • Accidental Settings Mishap: Adjusting phone settings can make your home screen look different. Accidental settings changes often cause your home screen layout to alter.
  • Meddling Third-Party Apps: Third-party apps can be like those unexpected guests. These apps may come with their home screen management features; that can lock your layout.
  • Software Updates: Your smartphone is constantly receiving updates to improve performance and security. A software update may reset your preferences, leaving you with a locked layout and frustration.
Understanding these potential reasons for a locked home screen layout is the first step toward resolving the issue. Further, we’ll show you how to unlock your layout and protect it from any unexpected changes down the road.
Your Samsung home screen arrangement seems to be causing you some frustration, and you’re enthusiastic about regaining authority. No need to fret, as we’re embarking on a voyage to free up your layout and let your creative juices flow. Below, you’ll find a systematic guide detailing how to accomplish this.
Step 1. To kick start the process, initiate by accessing your device’s settings. Locate and tap on the “Settings” application residing within your Samsung device.
Step 2. While within the settings menu, proceed by scrolling downward until you spot the “Home Screen” option.
Step 3. Within the “Home Screen” settings, seek out the “Lock Home Screen Layout” choice. When you’ve located it, simply switch it off.
Disable Lock Home Screen Layout
By following these instructions, your Samsung home screen will be open to your customization, allowing you to personalize and arrange it to your heart’s content. But what if you’re using a different device? Don’t worry. We have a solution for that scenario as well!
Keep reading to unlock the layout on your Android device other than Samsung.
How to Unlock Home Screen Layout Android
Unlocking the home screen layout on an Android device may vary slightly depending on the brand. Here are instructions for a few popular brands:
Unlock Home Screen Layout Xiaomi/Redmi
  1. Open “Settings” on your Xiaomi/Redmi device.
  2. Select “Home screen.”
  3. Find and turn off the “Lock home screen layout” option.
Unlock Home Screen Layout Huawei
  1. Open the settings
  2. Tap on “Home screen & wallpaper”
  3. Tap on “Home screen settings.”
  4. Deactivate Lock layout
Unlock Home Screen Layout Realme/Oppo
  1. Access “Settings” on your Realme/Oppo device.
  2. Choose “Home screen, Lock screen & Always On Display” option.
  3. Find and turn off the “Home screen locked” option.
Bonus Tip: How to Unlock Android Screen without Password
Imagine waking one morning, bubbling with excitement to kickstart your day, only to be met with the disheartening revelation that you’ve forgotten the password required to unlock your Android device. Panic sets in as you grapple with the realization that your entire digital existence is seemingly trapped behind an impassable barricade. There’s no need to worry. We have a lifesaver for you. A practical tool called DroidKit – Android Phone Toolkit!
DroidKit is your all-around superhero for all things Android-related. Whether you’re dealing with forgotten passwords, data recovery, system glitches, FRP locks, or any other Android issue, DroidKit has your back. When you forget your Android password, it can unlock it for you only in simple clicks and steps. Anyone can use this tool without any skills or root. And it has no limitations on the screen lock types. All of them, like 4-digit/6-digit passcode, Face/Touch ID, pin, pattern, etc. can be unlocked by this tool quickly. It’s your trusty sidekick, always ready to swoop in and save the day, ensuring your Android experience remains smooth and trouble-free.
Now DroidKit supports all Android devices like Samsung, Huawei, OPPO, etc. Just follow these steps to retrieve access to your device and rescue your day.
Step 1. Free download and launch DroidKit on your computer and select the Screen Unlocker mode.
Choose Screen Unlocker
Step 2. Connect your locked device to your computer, and click the Start button to initiate the unlocking process.
Connect your Locked Phone
Step 3. DroidKit will now start preparing the necessary configuration file for your specific device. After that, tap on the Remove Now button.
Click Remove Now Button
Step 4. Follow the guidelines on DroidKit to place your Android device into Recovery Mode.
Put Your Android Phone into Recovery Mode
Step 5. Now DroidKit will start to remove the Android screen lock. And then you will have access to your Android device without any password.
The Lock Screen Is Removed Successfully
Once you’ve successfully completed these steps, your Android screen will be readily accessible once more, allowing you to resume your day with a reassuring sigh of relief.
With this bonus tip in your digital toolkit, you can handle those unexpected moments when your Android screen lock throws you a curveball. Don’t let a forgotten password stand between you and your digital world. DroidKit is here to save the day!
A locked home screen layout can be frustrating, but with the guidance provided in this article, you can easily regain control of your Samsung or Android device’s customization options. Always remember to pinpoint the root cause of the problem and implement preventive measures to avert future lockouts. Moreover, in the event that you encounter a complete lockout of your Android device, turn to DroidKit as your ultimate solution for a trouble-free screen unlocking experience. Revel in the freedom to customize your home screen layout to your heart’s content!
