2025 Guide on Unlocking a Google-locked Phone
Wonder how to unlock a Google locked phone? Well, this guide will share you how to disable Google account verification and backs you up with efficient ways to bypass Google lock.
Author Avatar Joy Taylor Last Updated: Mar. 05, 2025
Read in: Read This Article in
DroidKit – Unlock Google-Locked Phone Without Credentials
Locked out of a Google account? Free download DroidKit to bypass the Google lock directly by yourself within minutes. No need to enter the previous Google account or a password. Supports multiple Android brands like Samsung, Xiaomi, Redmi, OPPO, and more.
You may buy a second-hand phone but with a Google verification page after wiping data, or accidentally trigger the FRP lock after factory reset a locked phone. You’re unable to access your phone or enjoy Google services without the original email and password. Fortunately, unlocking a Google-locked phone is not a mission impossible. Here we will offer you efficient ways to fix Google locked phones according to your specific conditions.
Can you unlock a phone that’s Google-locked?
A Google-locked phone means the Google account verification on the device has been activated after a factory reset, you can usually unlock it with the original Google account and password. Specifically, it is the Factory Reset Protection (FRP) lock for Android phones, a security feature designed to provide extra security for your device and information, including screen locks and data encryptions. Besides, the FRP lock can also be activated using Google Find My Device if your phone is lost.
When your phone is Google locked, you will get the verify screen that says This device was reset. To continue, sign in with a Google Account that was previously synced on this device. A Google-locked phone can be unlocked. You can unlock an Android phone with a Google account and password in a few clicks.
However, how to unlock Google-locked phone without passwords? There are ways to unlock your Android phone without a Google account or unlock it by removing the previously synced Google account. Let’s explore!
Unlock Google Locked Phone Without Google Account & Password
If you need to bypass Google’s smart lock without a password, we highly recommend that you use a professional FRP bypass tool to maximize the success rate. DroidKit FRP Bypass is a great attempt to bypass a Google account after resetting, no matter which model your Android phone or tablet is. Compatible with both Windows and Mac, DroidKit contains regular updates and supports more than 10 Android brands, including Samsung, Xiaomi, OPPO, etc. There’s a customized bypassing solution for each device model and Android OS, ensuring you can regain access to your device breezily. Android 6 – 15 are supported. Its ease of use and user-friendly interface make it a better choice for users with less technical skills.
What Can You Get after Google Lock Removal:
  • Regain full access to your phone immediately.
  • Remove the previous Google account from your device.
  • Log in to another Google account of yours to enjoy all Google services.
  • Privacy will be safe – the whole process is done by yourself and on your computer with the protection of SSL-256 encryption.
  • All content on your device will be erased after the Google account is removed successfully.
Steps to Unlock Google Locked Phone:
Step 1. Free download and launch the tool on your computer > Choose FRP Bypass.
Choose FRP Bypass Mode
Step 2. Connect your Google-locked phone > Tap on the Start button > Choose the brand of your Android phone.
Step 3. Choose your device’s brand. Wait for DroidKit to prepare a configuration file for your device and continue.
Click Start to Bypass
Step 4. Follow the on-screen instructions to complete the corresponding settings > Tap on Reset.
Click Reset
Click Reset
Step 5. After that, DroidKit will start bypassing Google lock. After the bypass process completes, your device will be restarted.
FRP Bypass Complete
FRP Bypass Complete
Further Reading: How to Bypass FRP on Samsung >
How to Unlock Google Locked Phone with Google Account
If you have no problem accessing the Google account and password, just follow the tutorial below to get your phone unlocked without one penny. If the account or the password is unavailable, things get a little complicated. No worries, you can bypass Google verification with the FRP bypass tool in Part 2 and find the Google account and password in Part 4. Keep reading and pick up a way that works best for you.
You can remove Google account lock for free as below:
Unlock Android Phone with Google Account for Android OS 9.0(pie):
  1. Launch the Settings app on your device and then select Accounts and Backup.
  2. In Accounts, find your Google account and then tap Remove Account to disable the FRP.
Unlock Android Phone with Google Account for Android OS 6.0:
  1. From Settings select Accounts > Tap Google.
  2. Choose the Google account that you want to remove > Tap More in the top right corner > hit the Remove Account option.
Unlock Google Locked Phone by Google Account Recovery
If you don’t have the original Google password, then try to change it to a new one. The first choice in the bucket is to send a text message or get a call to the phone associated with the account to verify your identity. If not available, try other means such as recovery email or answers to secret questions. Please make sure you have access to the verification address or other detailed information related to the account, or it won’t work for you.
Method 1. Find the Password via Recovery Email
If the recovery email associated with the account is available, action the following to prove ownership:
  1. Go to the Google Account Recovery page and choose the Forget email option.
  2. On the next page, Enter the recovery email address associated with the Google account, then tap send for a one-time code to that address.
  3. Log in to your recovery email and check for the verification code. After inputting the six-digit code, you will be popped out to change a new password.
Recover Google Account Password by Sending Recovery Email
Method 2. Find the Password by Offering Answers to Secret Questions
When you fail to verify ownership via recovery email, hit the “Try a different question” option on the bottom to answer secret questions. If you correctly select the “Year” and “Month” when the original account was created, you get a chance to set up a new password.
Recover Google Account Password by Answering Questions
FAQs about Google Locked Phone
Q1: How to Remove Google Account from Phone after Factory Reset?
If you remember the previous Google account and password, you can follow the steps below to remove the previous Google account after the factory reset:
  • On the setup screen after resetting the phone, connect to Wi-Fi.
  • When prompted, enter the Google account email and password that was previously synced to the phone.
  • Follow the on-screen instructions to complete the setup.
  • Once inside the phone, you can remove the account via: Settings > Accounts > Google > Select the account > Remove Account.
However, if you don’t have the previous Google account credentials, don’t worry, DroidKit FRP bypass tool can help you bypass Google account verification to regain access to your Android.
Q2: How to Remove Google Smart Lock on a Phone?
  • You can follow the steps to turn off Google Smart Lock on Android:
  • On your Android device, open “Settings” then go to “Security and Privacy”.
  • Select the “More Security Settings” option.
  • In the next screen, choose the “Trust agents” option.
  • Toggle the slider to turn off the “Extend Unlock” option.
That’s all about how to unlock a Google-locked phone with a Google account or not. Considering the convenience and high success rate, DroidKit can be your silver bullet to bypass Google verification and remove Google lock on any Samsung phone and tablet/Xiaomi/Redmi phone. With only a few clicks, this DroidKit can help you free your Google-locked phone to all functions. Free download DroidKit and try it now!
