Samsung Factory Reset without Password [4 Ways]
Want to factory reset Samsung but the screen password is unavailable? Lighten up! This quick guide can help you out with easy ways to Samsung factory reset without password. Read on to learn how to reset Samsung phone when locked.
Author Avatar Joy Taylor Last Updated: Dec. 25, 2024
DroidKit – Samsung Factory Reset without Password
How to reset a Samsung phone that is locked without password? Free get DroidKit! It will help you. It can reset your phone without a password, PIN, pattern, Touch/Face ID, etc. in simple clicks and minutes. No root is required. Supports all Samsung phones & tablets.
Factory resetting a phone helps you clear data & settings, fix system glitches, reset a locked phone, etc. So, there are multiple reasons why you want to factory reset Samsung: Get a second-hand phone and wipe off all the previous data, have troubles with apps crashing, Samsung frozen screen, or other system issues, and need to make a fresh start.
Performing a factory reset on an Android phone is always easy, but what if you were locked out of the phone by a screen password, PIN, or pattern? How to factory reset Samsung phone that is locked? Don’t worry. This article will show you how to reset Samsung phone when locked easily and quickly.
A Factory Data Reset will reset all personal data and settings. Confirm you’ve backed up your Android Samsung. Or, you need to search for ways to recover data after a factory reset.
1. How to Factory Reset Samsung with Buttons
Using Android Recovery mode is the first easy way you can adopt to factory reset locked Samsung. A strong Wi-Fi network or mobile data is preferred, or recovery mode may not work normally. It required no skills, and all you need to do is press the buttons. Here is how to reset a Samsung phone that is locked without home button. To factory reset Samsung:
Steps to Samsung Factory Reset without Password:
  • Turn off your Samsung phone.
  • Press and hold the Volume Up, Power, and Home buttons simultaneously.
  • Select the Wipe Data/Factory Reset option.
  • Select YES to delete all user data.
If you can’t switch your phone off in Step 1, leave the battery to run down and charge it back up first.
If the recovery screen doesn’t display, try to keep pressing and holding the Home and Volume Up buttons until the recovery screen appears.
2. Samsung Factory Reset without Password When Locked in 1 Click [Easy & Fast]
If you cannot turn off your device, you may not be able to perform a wipe data/factory reset. Then how to reset a Samsung phone that is locked and won’t turn off? No worries. You can use DroidKit, which is a powerful Android screen unlocker. No matter whether your Samsung phone is locked by a numeric password/PIN/pattern/fingerprint, or Samsung won’t accept your password, you can reset your Samsung and remove the lock screen without password.
What you need to do is simply connect your phone to the computer and click the buttons. First, check how can DroidKit help you:
Key Features:
  • DroidKit enables you to unlock any type of screen lock, including a password, PIN, pattern, fingerprint, face ID, etc.
  • It works perfectly on Samsung phones & tablets, and any other Android models like Motorola, Sony, etc.
  • Requires no skills, technical knowledge, and no root on the device. You can perform by yourself and on your computer.
  • What’s more, as a complete Android solution, DroidKit also helps you to unlock Samsung FRP without Google Account, flash and fix your Samsung device, recover lost data, etc.
So don’t hesitate. Just free download DroidKit and let’s see how to reset Samsung phone when locked in 1 click.
How to Factory Reset Samsung without Password:
Step 1. Free download DroidKit on your computer. Launch it and tap on Screen Unlocker.
Choose Screen Unlocker
Step 2. Connect your locked Samsung and click the Start button.
Connect Your Android Phone
Step 3. After the connection, DroidKit will prepare the configuration file for you. Once finished, tap on Remove Now button to continue. Then, select the device brand you need to unlock and continue the process.
Step 4. Follow the on-screen instructions and continue. If your phone is locked without a home button, there is also a solution.
Finish Settings on Samsung
Step 5. Wait for the unlocking process to be completed, you will get the Screen Lock Removal Completed page. And, your phone is reset to factory resetting.
Lock Screen Removal Completed
3. Factory Reset Samsung Phone That is Locked with ADM
You can also use Android Device Manager (ADM) to solve how to reset Samsung phone. ADM is a security feature that allows you to locate, change the lock screen and remotely erase the Android device. If you have enabled Android Device Manager with your Google account on the locked phone before, then you can factory reset it breezily. Check the steps below to see how to reset Samsung phone when locked via ADM.
Step 1. Log in to Android Device Manager with the Google Account used on the locked phone before.
Step 2. On the Android Device Manager page select your device > Tap Lock > Enter a temporary password > Click on Lock again.
Step 3. Enter the temporary password again > Go back to the Lock Screen Settings > Disable the temporary password.
Step 4. Choose the Erase option to restore to factory settings.
4. How to Reset Samsung Phone When Locked via Find My Mobile
The above methods generally suit all Android models, including Samsung phones. But you may not know that Samsung also offers a official tool to help you factory reset Samsung, and that is Samsung Find My Mobile. Just read on and check how to reset a locked Samsung phone using this tool.
Step 1. Go to Samsung Find My Mobile and sign in with your Samsung account.
Step 2. Then you can view your Samsung phone information. Tap on Erase Data.
Erase Data on Samsung Remotely
Tip: Samsung Phone Locked after Factory Reset?
If you factory reset your phone but it’s still locked, it is probably locked by FRP (factory reset protection). Why? Screen locks can be reset by factory reset. FRP lock will be activated by factory reset, which means your phone is a Google-locked phone. There are some ways that you can try to bypass FRP, and DroidKit also allows you to remove FRP. You can download it and bypass a Samsung phone (the latest Android 15 supported) locked by a Google account.
Choose FRP Bypass Mode
That’s all about how to reset Samsung phone when locked. With all the methods above, you should have no problem resetting your phone without a password. By the way, DroidKit can be a good helper for you to remove any screen locks and reset your device, and you can explore more functions from it. Just download DroidKit to factory reset Samsung now.
