5 Tricks to Factory Reset Samsung Tablet Without Password
Did you ever encounter a situation where your Samsung tablet got stuck and looking for ways of how to reset it. If that’s the case, don’t fret. This guide entails the best fixes of how to reset a Samsung tablet. Keep scrolling and get acquainted with everything that you need to know!!!
Author Avatar Joy Taylor Last Updated: Aug. 14, 2024
If you get stuck or a black screen appears, and the touch stops reacting, or, you’d like to sell your old Android phone, you are probably searching for a way to do a Samsung tab reset. But, before we go into how to do it? Let us look at why this is necessary.
Not only that, but the main thing we need before resetting Samsung tablet is the backup of data. As well as if you forget to backup Samsung tablet before reset, there is no chance to recover these valuable data. Well, you can find the answers to all these questions in the following articles.
If you are having issues with your Samsung tablet, you have 4 options to reset Samsung Galaxy tablet.
Method 1. How to Factory Reset Samsung Tablet Without Password
To factory reset Samsung tablet without password, follow the steps below.
  1. Turn off your Samsung tablet and wait 10 seconds for it to shut down totally.
  2. Now, long-press the Volume Up + Volume Down + Home Button together and wait until you see the Recovery Mode screen.
  3. To navigate the recovery menu, use the volume controls and then select the wipe data/factory reset option by clicking the Power button.
  4. Select the Yes — erase all user data option by pressing the Power button.
  5. Wait for the reset process to finish. After you’ve finished, click the Reboot system now button. Done! You used the hard reset option to reset the device successfully.
Wipe Data and Factory Reset your Device
You may also like: How to bypass FPR on Samsung after factory reset
Method 2. How to Reset Samsung Tablet via Settings
The easiest and most convenient step to reset Samsung tablet is definitely to do it through the settings. However, it should be noted that this method will erase all the data on the device. If you want to sell it as a used phone, then don’t worry about it. But if you are using the phone for your own use, please remember to make a backup of the data beforehand!
Let’s see how to reset your Samsung Galaxy tablet via Settings.
  1. Navigate to the Settings option on your Tab. Either from the notification bar or from the menu, select Settings.
  2. Now, go to General Management and select the Reset option from the menu. Before resetting the device, you must keep a backup copy of the device data.
  3. Finally, hit on the Factory data reset button, and again click on Reset, and in the end, tap on Delete all.
Factory Data Reset Samsung Tablet
Depending on the Android version, the reset option may differ for each Samsung model. Some reset options are found in the back and reset menu.
Making a factory restore on a Samsung tab would wipe all data kept in internal storage, removing the SD card and data from internet storage such as photographs, videos, and contact details using apps or a data cord before the hard reset.
Method 3. Soft Reset Samsung Tablet
A soft reset is a safe technique to restart your tablet if it is not responding or has been stuck, and the touch is not working. The method tab will reboot without deleting any data, and the hang issue will be resolved. To reset the Samsung tab, follow the steps below.
  1. Hold down the Power and Volume Down keys for 15 seconds until the screen goes black.
  2. The tab will normally open after rebooting, but if you experience regular problems, make a backup and try the hard reset method.
    Reset a Samsung Tablet via Buttons
Method 4. Factory Reset Samsung Tablet via Find My Mobile Feature
It is important for your locked device to be connected to the internet (through Wi-Fi or cellular data) in order for Samsung to find my device utility to recognize it. This approach cannot be used if the device is not connected to the internet.
If you have signed in to your Samsung Account on your device and have forgotten the lock screen password, pin, or pattern, you can reset it using the Samsung Find my Mobile utility.
To reset Samsung tablet to factory settings:
Step 1: First, open the browser and search for Samsung Find My Mobile.
Step 2: Check that you are signed in with the same account that is associated with your locked device. If you are not signed in to any of your browser’s accounts, it will prompt you to do so. If it has already been completed, proceed to the next step.
Step 3: It will display a map on the right side and device information on the left. Click the Erase Device option from the left menu.
Step 4: Read the information about the erase option and then click Erase Device to confirm the activity.
Step 5: If the device is connected to the internet, it will be reset to factory settings, and the lock screen will be removed.
Erase Data on Samsung Remotely
Method 5. Reset Samsung Tablet Using Android Device Manager
The next method uses the Android device manager utility that has authority over your smartphone; you can erase and reset your Samsung tab remotely.
Step 1: First, open a web browser on your computer or other device and navigate to ADM.
Step 2: Sign in using the same account that you used to unlock your locked device. Google will make an attempt to locate your device. After it successfully finds you, it will present you with three options, one of which is Erase.
Step 3: Finally, tap on Erase, and you are done!
Also Read: How to Fix Samsung Tablet Frozen Issues >
How to Backup Samsung Tablet Before Resetting
As mentioned earlier, if you do not want to lose your precious data when resetting Samsung tablet, it is necessary to make a good data backup. It is mentioned in method 1 that you can backup from setting, but this backup process is not visible and you can’t know if the data you want is backed up successfully. Then, you can choose DroidKit to selectively backup your most important data, and you can easily view it after the backup is done.
DroidKit – Samsung Data Manager
  • All Samsung phones and tablets are supported.
  • Preview data and backup Samsung phone to PC with simple clicks.
  • Back up various data such as photos, videos, messages, contacts, etc.
  • Recover photos, texts, contacts, etc. if Samsung data is deleted or lost.
Now please take the following steps to back up Samsung phone to PC selectively.
Step 1. Launch the program once you’ve installed DroidKit on your computer > Choose the Data Manager mode.
Choose Data Manager
Choose Data Manager
Step 2. Connect your Samsung phone to the computer via a USB cable > Once DroidKit detects your Samsung phone, it will scan the data on your device and navigate to the following interface.
Choose Export Content
Step 3. Choose the Export Content mode and access the interface showing the specific data on your Samsung device. Now, you can preview and selectively backup Samsung phone to PC.
Transfer Photos to PC
How to Get Lost Data Back after Resetting Samsung Tablet
However, I believe there are many users who forget to back up their Samsung tablet before resetting it, or find out their data is erased after resetting. At this time, how to retrieve these deleted data is very important. Don’t worry, DroidKit can not only help Samsung users to backup their data, but also can recover deleted data.
  • Open DroidKit on your computer > Hit Quick Recovery from Device on the welcome page. Also, you can try Deep Recovery and Recovery from SD Card mode.
Choose Quick Recovery from Device from Recover Lost Data
Samsung Galaxy Tablet Hard Reset Not Working?
While the majority of Samsung’s tablets are stable and rarely create problems, there are instances when things go wrong, and these tablets begin to behave erratically. If you are one of these users and your Samsung Galaxy tablet freezes for no apparent cause, the problem must be explored and resolved as soon as possible.
Fortunately, if you face any of the issues and cannot use the hard reset function, just scroll down and get acquainted with how to reset your Samsung tab with other options available.
We’ve talked about how to reset a Samsung tablet. We hope this information has assisted you in resolving your issue. If you have any other questions or concerns, please leave them in the comments area. We will strive to respond to your questions as quickly as possible.
