The article explains different ways of factory resetting Samsung J7 Android phones. The different methods include factory resetting the phone using Samsung find my phone, using a google account, putting Samsung in recovery mode, and using DroidKit. All in all, each method is effective. Please read on!
Factory Reset Samsung J7 without Password
It is essential to factory reset your Samsung J7 every once in a while. It sorts out many issues that are making your system sluggish and slow. The next important thing is to understand how to do it and what tools to use. Also, some important steps should be kept in mind to ensure that no data is lost.
The well-researched article will guide you through multiple ways of factory resetting your data. You can follow them and execute the process quite easily. Most crucially, the article will guide you on how to use DroidKit to factory reset your Samsung J7 or any Android, for that matter.
Let us begin with the information one should have before resetting one’s Samsung J7.
Tip: A Factory Data Reset will reset all personal data and settings. Confirm you’ve backed up your Android Samsung. Or, you need to search for ways to recover data after a factory reset.
Resetting to factory defaults is wiping all data and settings from a device and restoring it to its original configuration. This option addresses software bugs erase personal data and prepares a device for resale.
When doing a factory reset on a Samsung J7, it is crucial to note that all data, including contacts, messages, images, and applications, will be permanently wiped. Consequently, it is essential to back up all essential data before continuing.
In addition to that, keep in mind the things given below.
Before doing a factory reset on your Samsung J7, removing the SIM and memory cards from the phone is essential. You might lose important data, contacts, or files saved on those cards if you don’t remove them.
FRP is a security feature that prevents anyone from resetting your device without your permission. Before doing a factory reset, you need to turn off this feature; otherwise, you won’t be able to reset the phone.
You must know the password for your Samsung J7 to perform a factory reset. You need to remember the password to be able to reset the phone, and you might lose all your data.
Performing a factory reset can take some time, and if your phone’s battery is low, it might turn off during the process. This can result in data loss or other issues. Therefore, ensuring your phone is fully charged before a factory reset is important.
The next segment of the article will explain a few ways to perform Samsung J7 factory reset without password.
How to unlock Samsung galaxy J7 without password? If you wanna factory reset your Samsung J7 phone, is there an easy, safe, and fast way to help you? The answer is YES! The most recommended method here is using a professional Android phone unlocker to solve your problem. Here let’s meet DroidKit – Android Phone Toolkit, which is exactly what you are looking for.
DroidKit is a mobile toolkit that facilitates Android device management, backup, restoration, and reset. It provides diverse tools for users with varying levels of expertise, enabling them to perform tasks such as screen unlocking, data recovery, and system repair.
Free get DroidKit and follow this step-by-step guide to learn how to factory reset Samsung J7:
How to perform Samsung J7 factory reset without password with DroidKit.
Step 1. Download the newest edition of DroidKit on your computer and launch it. Choose the Screen Unlocker option.
Choose Screen Unlocker
Step 2. Connect your phone to your computer and select Start. Wait for the configuration file to load, then click Remove Now button. Choose your phone’s brand and proceed.
Click Remove Now Button
Step 3. Follow the prompts on the screen to factory reset your Samsung.
Finish Settings on Samsung
Step 4. Once the unlocking process is complete, your phone’s lock screen will be removed, and your phone is reset to factory resetting.
Lock Screen Removal Completed
If you are experiencing issues with your Samsung J7 smartphone, a factory reset may be the solution to restore it to its original settings. By utilizing Samsung’s Find My Mobile remote management service, it’s possible to perform a factory reset without having to access the device’s buttons physically.
The following chunk will guide you through resetting your Samsung J7 using Find My Mobile. It will allow you to resolve any issues and restore your phone to a fully operational state.
Steps to factory reset Samsung J7 via Find My Mobile.
1: Make sure your Samsung J7 is connected to the internet. Go to https://smartthingsfind.samsung.com/login.
Open the link
2: Sign in using the same Google account associated with your Samsung J7. Once you’re signed in, you should see your Samsung J7 listed on the screen. Click on it.
3: You should see several options, including “Play Sound,” “Lock,” and “Erase Device.” Click on “Erase Device.” Click on “Erase.”
Tap on the Erase Device Button
4: The factory reset process will begin. Once done, your Samsung J7 will restart. You’ll be prompted to set it up like a new device.
Resetting your Samsung J7 via Google Account is a straightforward process that can help resolve various software-related issues. This method lets you reset your device’s password or pattern lock, erase data, and restore factory settings using your Google Account.
If you’ve added a Google account to your phone, the Find My Device feature will be automatically enabled, allowing you to erase all of your phone’s content remotely.
Steps to factory Reset Samsung J7 via Google Account
To factory reset your Samsung phone using the Android Device Manager, follow these steps:
Tap on the Erase Device Option
Following these steps, you can quickly and securely factory reset your Samsung phone using the Android Device Manager.
Recovery Mode on Samsung J7 allows you to troubleshoot and perform various system-related functions, including a factory reset. This method involves accessing a hidden menu on your device to initiate the reset process. It enables you to restore your phone to its default settings and resolve issues like freezing, crashing, and other software problems.
Steps to Factory reset Samsung J7 via Recovery Mode.
The following steps will help you to understand how to perform a factory reset via recovery mode.
Step 1. Briefly hold down the Power key. Press the “Power off” button once it appears on the screen.
Put Tour Phone in Recovery Mode
Step 2. Hold the Volume Up, Home, and Power buttons for a few seconds to enter the recovery mode.
Enter the Recovery Mode
Step 3. Navigate here using the Volume buttons and select options using the Power key. Select the option “Wipe data/factory reset.”
Step 4. Ensure ”Reboot system now “is highlighted when the Android Recovery screen appears again, then hit the Power/Lock button.
Tap on the Reboot System Now Option
Your phone is now at factory default settings. You have successfully factory reset your mobile.
Now, let us move to the next step. The following step will explain how DroidKit can solve your problem of a locked phone even after a factory reset.
If you have performed a factory reset and your phone is still locked, FRP is probably to blame (factory reset protection). Why? A factory reset can be used to reset screen locks. FRP lock will be activated by factory reset, indicating that your phone is Google-locked. There are some ways that you can try to bypass FRP. DroidKit is a reliable tool for bypassing Samsung FRP lock, regardless of the model or tablet. It offers tailored bypass solutions for each device and Android OS version, making it easy to regain access to your device. The tool supports Android 6 to 13.
Here are the steps to bypass Google lock on your phone using DroidKit:
Step 1. Launch the DroidKit tool on your computer.>Select FRP Bypass. Connect your phone to computer. > Click on the Start button.
Choose FRP Bypass Mode
Wait for DroidKit to prepare a configuration file for your device and continue.
Step 2. Put your device into recovery mode. Note the number displayed on your device. > Select the right system version> Tap on Next.
Choose System Version
Step 3. Follow the instructions displayed on the screen to complete the corresponding settings. Once the bypassing process is complete, your device will restart.
FRP Bypass Complete
That’s all about how to factory reset Samsung J7. You should have no trouble resetting your phone without a password using any of the methods listed above. Factory reset is a complicated process. But luckily, with DroidKit, you can easily solve your problem by yourself. What’s more, it has a variety of other functions to manage your Android device. Simply download it and give it a shot.
