This article explores how to factory reset the Samsung S21 without a password. Discover five practical ways with stepwise instructions. Whether prepping it for sale or needing a fresh start, this guide can help you quickly regain control of your device.
So, you’re about to resell your phone. But there’s a problem—you’ve forgotten the passcode. Now, you’re locked out of your S21 and unable to reset it. Sounds frustrating, right? But don’t worry! There are easy ways to factory reset your phone without a password. These methods can help you clear data and unlock your phone, ensuring your S21 is ready for use again.
This article offers a complete guide on how to factory reset the Samsung S21 without a password. By the end, you’ll have all the knowledge you need to reset your S21 with ease. Let’s get started!
Here are some scenarios where a factory reset is the ideal way to restore your device to its normal state.
Ready to get your S21 back in action? This section offers five easy ways to reset your device without the passcode. Whether you’re seeking manual ways or a specialized tool, we have you covered.
Do you want to reset your Galaxy S21 without the hassle of lengthy technical steps? DroidKit is just what you need! It offers a one-click solution to reset your phone without needing a password. You can unlock your phone instantly, whether locked with a PIN, pattern, or fingerprint.
Now, let’s see how to factory reset the Samsung S21 without a password using it.
Step 1. Download DroidKit on your PC. Install it and connect your S21 to the PC using a USB cable.
Step 2. Launch DroidKit and select the “Screen Unlocker” tool from the main interface.
Step 3. Click “Start” from the new window. Then, select “Device connected” to verify a stable connection.
Step 4. DroidKit will prepare the configuration profile for your S21. Once complete, click the “Remove Now” button.
Step 5. Select the type of buttons your device has. Follow the on-screen steps to put your phone into recovery mode and reset it.
Step 6. DroidKit will start removing the screen lock. Once done, your S21 will restart. You will see the following screen in DroidKit.
That’s how to factory reset the Samsung S21 without a password using DroidKit. Now, let’s explore more solutions for it!
You can use the recovery mode to reset your S21 without a password. This involves using your device buttons.
Here’s how it works.
Step 1. Link your phone to a PC using a USB-C cable. Then, long-press the power and volume down buttons to turn off your device.
Step 2. Once the phone turns off, release the buttons. Then press and hold the volume up and power button.
Step 3. Once the phone turns on, let go of the power button. Hold the volume up button until you see the Android Recovery screen.
Step 4. Head to “Wipe data/factory reset” using the volume down key. Then select it with the power button.
Step 5. Select “Factory data reset” from the next screen to start the process.
Step 6. Once your phone resets, select “Reboot system now.” Wait for your phone to restart. Then, complete the setup.
If you can’t enter recovery mode, don’t worry. Our next solution can help!
Google’s handy Find My Mobile service offers a quick solution to factory reset the Samsung S21 without a password. You can use a PC or a different Android phone to do this.
So, how do we go about it?
Step 1. Go to the Google Find My Device website.
Step 2. Log in with the Google ID linked to your S21. Then, select your device from the right panel.
Step 3. Click the “Factory reset device” option from the right to start the process.
Step 4. Use the on-screen guidelines to reset your device without a passcode.
Let’s move forward now and explore another easy solution!
Samsung has its own alternative to Google’s Find My Device. SmartThings Find lets you wipe your phone’s data to reset it.
Step 1. Go to the SmartThings Find website. Sign in with your Samsung account ID and password.
Step 2. Select your S21 from the left and click “Erase data” near the top right.
Step 3. Enter the code sent to your S21 and click “Verify.”
Step 4. Click “Erase data > Erase” to begin the factory reset process. Follow the instructions on your screen to complete it.
If the above methods do not work, you can put your device in download mode and reset it with a firmware flashing tool. This requires access to a PC and downloading the Odin software.
Here’s how to factory reset the Samsung S21 without a password using this method.
Step 1. Download and install Odin. Then, download the appropriate firmware for your Samsung S21 from SamMobile.
Step 2. Link your device to the PC via USB cable. Boot your Samsung S21 into Download Mode. To do this,
Step 3. Launch the Odin Tool. Then, click the BL, AP, CP, and CSC buttons to add the relevant firmware files.
Step 4. Click “Start” to begin. Once complete, your Samsung S21 will be factory reset without the password.
Q 1. What buttons should I press to factory reset a Samsung?
Press and hold the volume down and the power button to turn off your phone. Long-press the volume up and side button until the phone switches on. Then, release the side button. Keep pressing the volume up key until the recovery mode screen appears. Press the volume key to navigate and the power button to choose “Wipe data/factory reset.”
Q 2. How do I factory reset my locked Samsung?
DroidKit offers the perfect solution to factory reset a locked Samsung device. It lets you remove the screen lock and reset your device. You can remove any type of lock. These can be PIN, pattern, password, fingerprint, and face recognition.
Q 3. How can I factory reset a stuck Samsung phone?
Hold Volume Down + Power for 10 seconds to force restart an unresponsive Samsung device. Then press Volume Up + Power keys to factory reset it.
Q 4. How do I reset my Samsung phone directly?
You can use your phone’s settings app to reset your device directly. Open “Settings” and select “General management > Reset.” Then, choose “factory data reset.”
Q 5. What is a full factory reset?
A full factory reset erases all your phone’s data, apps, and settings. It restores your device to its original state as if it were brand new. You can perform it to fix software issues or to remove the screen lock.
That’s how to factory reset the Samsung S21 without a password! We have shared five easy methods, including DroidKit, Recovery Mode, Find My Device and SmartThings Find.
If your phone is locked because of a forgotten passcode, DroidKit offers the easiest solution. You can reset and unlock your device in a few clicks. Try it for an effortless way to factory reset your phone without a password and regain access quickly!
