Learn how to factory reset your Samsung A12 without a password using various methods. This article details four methods to help you factory reset your Samsung phone if you forget the password.
With a host of powerful features, including a massive 5000mAh battery and a high-definition display, the Samsung A12 is relied upon for everyday work and play. However, for security reasons, the phone comes with a factory reset feature to restore the system in the event of a forgotten password or software glitch, ensuring that the device is back up and running again.
But according to a recent study by Kaspersky, 34% of smartphone users forget their device’s password at least once a year. This common problem can leave you unable to use your phone, access important data, or even make calls.
Whether you’ve forgotten your pattern, PIN, or password, or are facing ongoing software glitches, a factory reset can often fix these issues. How do I factory reset my Samsung A12 without a password? This article will provide you with detailed steps and recommendations for the best tools to help you easily get your device back in working order.
Resetting your Samsung A12 to factory settings is an important step and proper preparation should be done to avoid data loss and ensure that the reset process goes smoothly. Here is a detailed guide on what you should do before proceeding:
1. Back up your data
Before performing a factory reset, it is important to back up all important data to prevent loss. DroidKit is a professional Android data backup tool that can easily back up your phone data for you.
2. Delete Google account
To avoid being locked out due to Factory Reset Protection (FRP), delete your Google account from your device:
Related recommendation: How to bypass FRP
3. Delete Samsung account
Similarly, delete your Samsung account to prevent any account-related issues after the reset:
4. Write down important information
Write down important information, such as:
5. Ensure sufficient power
Make sure your device has at least 50% charge or is connected to a charger to prevent it from shutting down during the reset process.
Forgetting your Samsung A12’s password isn’t an unsolvable problem. You can regain access to your device, even without a password, by performing a factory reset. While a factory reset will erase all the data on your phone, it’s often the most effective solution when you’re locked out.
In this part, we’ll explore step-by-step methods to factory reset your Samsung A12 without a password.
You can reset through the settings menu: Go to Settings > General management > Reset > Factory reset.
These methods are applicable to various models of Samsung Galaxy A12, including SM-A125F/DSN, SM-A125F/DS, SM-A125F, SM-A125M1.
Factory Reset Samsung A12 Without Password Through Settings
If the built-in settings fail to factory reset your Samsung A12, you can also use Google Find My Device to factory reset Samsung A12.
Steps to factory reset Samsung A12 using Google Find My Device
1. Visit Google Find My Device website
2. Sign in to your Google account
3. Select the “Erase device” option
Select “Erase Device” after Google Find My Device locates the Android phone
4. Wait for the device to be restored to factory settings
The device will begin to restore factory settings: This process will erase all data, and after restarting, the device will enter the initial setup interface.
Samsung’s “Find My Mobile” is a service that allows users to remotely manage their Samsung devices. With this feature, you can do the following:
Find My Mobile
Before performing a factory reset using Samsung Find My Mobile, make sure:
To perform a factory reset using Samsung Find My Mobile:
1. Go to the Samsung Find My Mobile website: Visit [Samsung Find My Mobile].
2. Enter your Samsung account information: Sign in with the Samsung account and password associated with your Samsung A12. If two-step verification is enabled, you may need to enter a verification code.
3. Select your device: On the Find My Mobile page, you will see a list of devices associated with your account. Select your Samsung A12.
4. Select the Unlock and Wipe Data options
Erase Data on Samsung Remotely
5. Complete the restore
You can restore the Samsung A12 to factory settings by following the above steps. But please note that if the device requires you to enter the previously bound Samsung account information to complete the activation after the reset, this is because of the device protection function settings. Make sure you know and remember your Samsung account credentials.
DroidKit, as a powerful Android device management software, provides users with a safe and convenient way to factory reset Samsung A12 without password. (DroidKit will unlock your phone by resetting it. So you can use this tool to factory reset your Android phone without a password.)
Unlike the built-in recovery mode, DroidKit can bypass the lock screen password while retaining the user’s important data. This method is not only suitable for the case of forgotten passwords, but also solves the dilemma when the device is locked or encounters serious system problems.
The software has many valuable features, such as:
Next, let’s learn in detail how to use DroidKit to easily Factory reset your Samsung Galaxy A12 without worrying about the restrictions of passwords.
Step 1. Download DroidKit on your PC > Launch it and choose Screen Unlocker mode.
Choose Screen Unlocker
Step 2. Connect your phone and click Start. After the configuration file is prepared, tap on Remove Now.
Click Remove Now Button
Step 3. Select the device brand (Samsung) you need and tap on Next to unlock and continue the process.
Step 4. Follow the onscreen guide that appears to enter recovery mode on the Samsung A12 phone.
Finish Settings on Samsung
Step 5. DroidKit will automatically reset your device. Wait for the process to complete and you will see the “Screen Lock Removal Completed” page. And, your phone will be reset to factory settings.
Lock Screen Removal Completed
1. What is the unlock code for Samsung factory reset?
Type *2767*3855# to reset your device to the original factory setting, and it will reboot.
2. What is the Samsung master reset code?
Code | Function |
*#1111# | Display software version |
*#1234# | Display firmware version |
*#2222# | Display hardware version |
*2767*3855# | Reset: delete all data and reset all settings |
*#0*# | Test/service mode, e.g. Galaxy S3 mini |
*#*#4636’*’* | Test/service mode, e.g. Galaxy S2 |
In this article, we discuss in detail how to factory reset Samsung A12 without password. We introduce several methods to solve the common problem of “How to factory reset Samsung A12 without password”. In most cases, you can use “Find My Phone” or “Find My Device” to complete it. However, when you need to save existing phone data or forget your account information, using tools such as DroidKit will better meet your needs.
Whether you have forgotten your password, your device is locked, or you plan to sell or give away your phone, it is important to know how to factory reset without password. We hope that the methods provided in this article can help you reset Samsung A12 smoothly.
