How to Change Android 12 Lock Screen Clock? [New!]
If you’ve upgraded to Android 12 and are taken aback by the huge lock screen clock, you’re not alone! Here are 6 ways to change the Android 12 lock screen clock.
Author Avatar Joy Taylor Last Updated: Jan. 19, 2024
I just installed the Android 12 update, and I don’t like the large clock on my lock screen. Does anyone know how to change the clock theme to only the lock screen?”
Android 12 is by far the most popular version of Android and has plenty of new and improved features that make it one stellar OS! However, just like every time an OS is released, it has one feature that has raised eyebrows: The lock screen clock! It’s HUGE!
While many people had nothing to say about the new lock screen clock, some users found it too big and said it covered too much screen. Therefore, if you want to get the old smaller lock screen clock back, here are the top 5 ways to change the Android 12 lock screen clock.
If you wanna know how to unlock Android screen locks, you can also read:
How to Remove Screen Lock PIN on Android?
How to Remove Screen Lock if Forgot Password?
How to Change Android 12 Lock Screen Clock (Full 5 Ways)
While there is no official way to change the Android 12 lock screen, there are a few tricks you can use to resolve the “Android 12 lock screen clock is too large” issue on your Android phone. Let’s go over each of these methods one by one.
Way 1. Change Android 12 Lock Screen Clock by Keep Unread Notifications
If you don’t want to risk meddling with your Android device’s settings, one way to make the lock screen clock smaller is by keeping unread notifications.
The lock screen clock only takes up so much space when there are no notifications; as soon as you get a notification, it moves back to the top-left corner. So, leave those notifications unread, and the clock will remain smaller!
Way 2. How to Change Android 12 Lock Screen Clock Turn On Android’s Screen Saver
Another way to change the Android 12 lock screen clock is by enabling Android’s screen saver. The screen saver has a dollop-shaped analog clock that is more pleasing to the eyes than the lock screen clock.
To turn on the Android screen saver:
  • Launch the Clock app, and click on the 3 dots in the upper-right corner.
  • Click on “Screensaver” and turn the toggle on for it.
Turn On Android Screen Saver
If you want to change the way the screensaver clock looks like:
  • Go to “Settings > Display > Screensaver” and change it to analog, digital, or night mode.
Way 3. Change Your Wallpaper
Changing the lock screen wallpaper can also help remove the lock screen clock. To change the wallpaper:
  • Go to “Settings > Display > Screensaver.”
Change Your Lock Screen Wallpaper
  • Turn the toggle on for “Screensaver” and select an album to display photos when the screen turns off.
Now instead of the massive lock screen clock, you’ll see changing wallpapers!
Way 4. Switch off AOD
Another method to stop seeing the lock screen clock is switching off the Always-on Display (AOD) option. This won’t change the lock screen clock, but as it will turn the display off, the lock screen clock won’t be displayed all the time. However, you will see it only when you press the power button.
  • Go to “Settings > Display > Lock Screen.”
Go to Lock Screen from Settings
  • Now turn the toggle off for “Always Show Time and Info.”
Turn off Always Show Time and Info
Way 5. Disable the Double-Line Clock in Settings
Initially, there was no option to turn off the Android 12 lock screen clock. However, to everyone’s relief, when Google released the new update, it included an option to turn off the clock.
Here’s how:
  • Turn the toggle off for “Double-line Clock.”
Turn off Double-Line Clock from Settings
How to Change Lock Screen Clock Android 12 on Samsung
This section is for Samsung users who want to install the Android 12 lock screen clock on their devices. Users can change the font and style of the lock screen clock directly in Settings.
  • Steps to change clock on Android 12 lock screen on Samsung:
  • Turn on your Samsung device and select “Settings.”
  • Once in Settings, scroll down to find the “Lock Screen” option.
  • Select the “Clock Style” option.
  • After that, you will see various options on the screen, then select your preferred clock style and color.
  • When you’ve finished your selections, click the “Done” button.
Now, wasn’t that easy? With 6 simple methods, you can change the Android 12 lock screen clock.
However, what if you forget your Android device’s password, PIN, or pattern? How will you unlock the screen?
Let us show you!
Bonus Tip: How To Unlock Locked Screen On Android?
If you ever get locked out of your Android 12 device, you can always use a third-party screen unlocking tool, like DroidKit-Android Phone Toolkit to unlock it. It is capable of unlocking the screen of your Android phone without entering a password. You can thus have full access to your locked device again in a few minutes. Now, let’s check what it can do for you.
  • DroidKit supports unlocking 20,000+ models of Android devices.
  • Remove screen locks of any kind like PIN, pattern, password, fingerprint ID, or face recognition in just a few minutes without root. Save your precious time.
  • No technical knowledge is required. Everyone can handle it.
  • What’s more, it can recover lost data, extract data, fix Android system problems as well
Download and install the latest version of DroidKit on your Windows PC or Mac NOW!
Here are the steps to use DroidKit to unlock the locked screen on Android 12:
Step 1. Download DroidKit and run it on your PC. Then select “Screen Unlocker.”
Choose Screen Unlocker
Step 2. Connect your Android smartphone to your PC, and click “Start.
Connect your Locked Phone
Step 3. DroidKit will detect your device and prepare a device configuration file for it. Then it will ask you to remove the screen lock. Click “Remove Now” to continue.
Select the “Remove Now” Button
Step 4. Follow the on-screen instructions to put your phone in Recovery Mode for the screen unlocking process.
Put Your Android Phone into Recovery Mode
Step 5. Once in recovery mode, DroidKit will start the lock screen removal process. This might take a few minutes; therefore, be patient and don’t unplug your device.
Lock Screen Removal Completed
Once the screen lock is removed, your phone will restart. You can now access it without a password, PIN, or pattern.
The Screen Unlocker option in DroidKit might erase your device; therefore, back it up before starting the process.
Android 12 and its big lock screen clock issue was quite hyped as Google received a lot of negative feedback regarding it. Luckily, users found several ways to remove or hide it before the update, which came with an option to disable it.
This article discusses 6 ways to change the Android 12 lock screen clock. What are your thoughts on the Android 12 lock screen clock? Do you like the new feature, or want to get rid of it? Let us know in the comments! What’s more, DroidKit offers a quick and reliable way to unlock various Android screen locks. Why not download DroidKit now and give it a try!
