How to Bypass Google Account Verification on ZTE
Bypassing Google account verification in ZTE phones may become a challenging task. But if you have the right tool in hand, the process becomes quick and easy. In this article, you will read about some effective ways of how to bypass Google account on zte and delete a Google account after factory reset.
Author Avatar Roger Smith Last Updated: Sep. 11, 2023
With the Android Lollipop 5.1 update, Google came up with a new security feature for mobiles. To enhance the security of your ZTE phone, you may use the FRP (Factory Reset Protection) feature, which is an in-built data protection feature. It is designed to render protection to the private data stored on the device in an unfortunate event like mobile getting stolen or lost.
Although this feature is extremely useful, it can still cause some serious issues. If you forgot to delete a Google account before performing a reset in your ZTE phone, or before giving it to trade, the FRP lock will be activated to enter Google verify page. Moreover, if you have not taken any notes of your Google ID and password, then, you may search for ways on how to remove a Google account from your ZTE phone.
In the coming parts of the article, you’ll learn about how to unlock a google locked ZTE phone. So, let’s begin!
Further Reading: How to Unlock Android Tablet without Google Account >
How to Delete a Google Account on ZTE after Factory Reset
Since working on a computer can make things a bit complicated, you can bypass Google account on ZTE even without a computer. Follow these below-listed instructions:
Step 1: Reset your ZTE phone and turn it on. Select your preferred language and click on the Start button.
Step 2: Connect your device to a strong Wi-Fi network and proceed to configure your device.
Step 3: Now, go to the Verify Account screen by skipping a few steps.
Step 4: Click on the Email Address as it will activate the keyboard. Then, click on the menu key and choose the Settings option.
Step 5: Within the SwiftKey, select the Languages option and minimize the menu.
Bypass ZTE Google Account with Swiftkey
Step 6: Select the No, Thanks option when asked to sign in with a Google account.
Step 7: Go to the Google search bar and type Settings, and choose it.
Step 8: Now, select the Backup and Reset option. Once done, click on the Factory Data Reset option to reset your ZTE phone again.
Step 9: Switch on your device once again.
Now you won’t see the FRP lock screen again.
How Do I Remove a Google Account from My ZTE Phone?
If you no longer want to use the factory reset protection in your ZTE phone, then you can consider removing your Google account. With this, you will be able to deactivate the FRP feature of the operating system of your ZTE phone. Moreover, you won’t require your Google ID and password to continue using your device. You’d better to remove your Google account before a factory reset or selling your old phone. Now, let’s check out what needs to be done to delete the Google account:
Step 1: Click on the Settings icon in the phone menu or on the home screen.
Step 2: Look for the Accounts option in the menu and tap on it to open it.
Step 3: All the accounts linked to your ZTE device will appear here. Click on the Google account to delete it from the device.
Step 4: The data linked to your Google account will appear now. Tap on the Remove account option to continue.
Step 5: Hit the Remove account option in the confirmation message.
Once you remove the Google account from your ZTE mobile, all the data of the account will be deleted automatically.
How to Bypass PIN from ZTE
There are several ways to tighten the security of your ZTE phone, such as using a PIN to lock it. It keeps strangers away from accessing the data of your phone. However, if you forget it for any reason, you will be locked out of your device if you enter the wrong PIN multiple times. However, there is no need for you to panic in such a situation.
Wondering why? Simply because you can bypass PIN from your ZTE phone using DroidKit. It is a professional Android phone unlocker, which will make the task of screen unlocking effortless for you. Whether you have set a PIN, numeric password, pattern lock, fingerprint, etc. for your device’s security, you can unlock it immediately without facing any challenges.
With this advanced Android phone unlocker, you won’t need to root your ZTE phone. Thus, you’ll be able to use your device normally. Following are some top-notch features of DroidKit, have a look at them:
  • You can unlock ZTE phones without fingerprint ID, passwords, face recognition, etc.
  • Except for ZTE mobile, you can unlock more than 20000 models of Android phones and tablet.
  • Except for screen pins, DroidKit can also help Android users to bypass FRP lock, fix crashed system, recover lost data, etc.
  • It comes with an interactive interface which makes unlocking easy.
Steps to Use DroidKit to Bypass PIN from ZTE
Get the latest version of the DroidKit on your PC and pursue the following instructions:
Step 1: Install and launch Droidkit on your PC. On the following window, click on the Screen Unlocker mode.
Choose Unlock Screen Function
Step 2: Using a cable, connect your ZTE device to the PC and tap on the Start button to continue.
Connect your Locked Phone
Step 3: After the preparing process is completed, click on the Remove Now button.
Click Remove Now Button
Step 4: Now, confirm your device brand and follow the on-screen instructions to remove screen password.
Step 5: DroidKit will start removing the Android screen lock. After a few minutes, screen lock removal will be completed.
Lock Screen Is Removed and Your Android Phone Is Reset
That’s how you will be able to bypass PIN from ZTE within a few minutes with DroidKit.
That’s a wrap for how to bypass Google account on ZTE. You can use any of the fixes listed above to access your device. Also, to avoid any such situation in the future, make sure that you don’t forget the Google ID and password, else you would have to delete the Google account using the above-listed method.
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
