How to Bypass Gmail 2 Step Verification in 2024
Gmail 2-Step Verification is a great way to add extra protection to your device. But, what if you need to bypass Gmail 2-Step Verification?
Author Avatar Joy Taylor Last Updated: Apr. 08, 2024
Read in: Read This Article in
한국어
Mailboxes have become an essential tool for most people to receive bills, communicate about business, and perform something involving personal information. Gmail, also known as Google Mail, is one of the most used email companies with nearly 2 billion vibrant customers worldwide. Due to this enormous user base, Google has introduced a 2-step Verification feature to maintain the security of each account’s mailbox.
However, we have noticed that users frequently face error alerts while using this feature due to verification failures in Gmail or for other reasons. In this article, we will explain some information about 2-Step Verification and provide detailed methods on how to bypass gmail 2fa.
What Is Gmail 2 Step Verification?
Gmail 2-Step Verification, also known as two-factor authentication (2FA), is an additional layer of security designed to protect your Gmail account from unauthorized access. It adds an extra step to the login process, requiring you to provide two pieces of evidence to verify your identity.
How to Turn Off 2 Step Verification in Gmail Account?
Can I turn off Gmail 2-step verification? Of course you can! It’s just that the procedures are very time-consuming, so I’d recommend going for the simplest technique to bypass Gmail 2-step verification straight, but you may still attempt it if you want. Here’s how to disable two-step verification in Gmail.
  • Go to the Gmail website (https://www.gmail.com/) in a web browser.
  • Enter your email address and password to access your Gmail account.
  • After signing in, click on your profile image or initials in the upper-right corner of the screen. There will be a dropdown menu.
  • From the dropdown menu, select “Manage your Google Account.” This will bring you to the Google Account settings page.
  • Click the “Security” tab on the left-hand side of the Google Account settings screen.
  • Scroll down to “Signing in to Google” and select “2-Step Verification.” For security reasons, you may need to verify your password again.
  • You’ll be asked to enter your phone number and verify it before you can turn off 2-Step Verification. Follow the on-screen instructions to complete this process.
  • After you’ve verified your phone number, you’ll be able to turn off 2-Step Verification. Select the “Turn off” option.
  • After reading the information carefully be certain you understand the implications. Click “Turn off” to turn off 2-Step Verification for your Gmail account.
You’ve undoubtedly logged in to your email account from your mobile at least once. So, how to bypass Gmail 2-Step Verification? Don’t worry, you can try the following two methods to bypass Gmail 2-Step Verification.
1. How to Bypass Gmail 2-step Verification without Passcode 1-Click
Due to the technical difficulty of bypassing authentication locks, we first recommend that you use a third-party tool that offers high security and ease of operation.
DroidKit – Android Phone Toolkit is a complete Android solution that provides you with a way to securely bypass the 2-Step Verification. No external tools such as OTG cable or flash drive are needed. By installing DroidKit on your computer, you can get a professional tool to bypass 2-Step Verification and regain full access to your device. After G-account verification is bypassed, you can get the previous G-account removed completely from your device, and log in to another Account of yours to enjoy all Google services again. Please take a look at its features first.
DroidKit Full Version
With DroidKit, you can remove Google lock on your phone immediately. No need to send your device out to a technician and wait for days before getting it back. It supports all Samsung, Xiaomi, Redmi, POCO, and Oppo phones and tablets that are running Android OS 6-13. The tool is available for both Windows and Mac.
Key Features:
  • Bypass Google account verification and get out of Verify your account.
  • Remove the previous Google account and log in to another account.
  • No complicated operations and no need to root your device.
  • No data leakage. Your privacy is 100% safe with the protection of SSL-256 encryption.
  • With DroidKit, you can also unlock your Android device, and recover your lost but important data like photos, contacts, messages, WhatsApp data, etc.
Free get DroidKit and follow the detailed steps to bypass 2 step verification gmail are as below:
Step 1. Download and install DroidKit on your computer > Choose the FRP Bypass code.
Choose FRP Bypass Mode
Step 2. Connect your device to the computer, press the Start button > Choose your device’s brand > Then, a configuration file will be prepared for your device. Later, tap on Start to Bypass to proceed.
Tap on Start to Bypass
Step 3. Select your device’s Android system version. Then, hit the Next button. Set up your phone according to the on-screen instructions.
Complete Corresponding Settings
Step 4. After that, the device will be rebooted and the Gmail 2 Step Verification will be successfully bypassed.
FRP Bypass Complete
FRP Bypass Complete
2. How to Bypass Gmail 2-Step Verification via Reset Password
Another way to be able to bypass Google 2fa is to reset your password. This is because when you change your password, Gmail will let you sign in to your account with a brand new password, which eliminates the need to go through 2-Step Verification. Please follow the steps listed below:
Step 1. Go to the Gmail login page and click Reset Password
Step 2. Enter your email address and choose a way to get the code.
  • If you want to get the code for your smartphone number, select your cell phone number
  • If you want to get the code for your email address, select your email address
Step 3. Enter the new password in the specific area and reset your password
FAQs on Gmail 2-Step Verification
1. How many digits are in the Gmail 2-Step verification code?
Google’s verification codes are 6 digits. They are delivered to your phone via phone call or SMS message.
2. Why did I receive a Google verification code that I didn’t ask for?
If you receive a Google verification code, it means that someone is trying to log into your account. It may be that someone accidentally entered the wrong information and logged into your account, but it could also mean that someone is intentionally trying to access your account.
3. Why does Google ask for verification every time I sign in?
  • You didn’t check the box to ask every 30 days option, and the system defaults to requiring you to enter your password every time you sign in.
  • You may not have cookies enabled. Then you most likely need to enable cookies in your browser.
  • Your browser is set to automatically clear your cache when you log out. Please reset this option.
We’ve provided you with detailed information about Gmail 2 Step Verification, and we believe you already have a preliminary understanding of 2-Step Verification.
When you encounter verification failure or cannot receive the verification code and want to bypass the 2-Step Verification, please choose the tool we recommend for you – DroidKit, which is easy to operate and can protect your data security. Free get DroidKit and bypass your Google verification now!
