How to Hard Reset Samsung Phone [2025 Guide]
Samsung phone is frozen? Don’t worry! You can fix many Samsung phone problems by hard resetting it without losing data.
This article will show you how to hard reset a Samsung phone in detail.
Author Avatar Joy Taylor Last Updated: Mar. 12, 2025
A question for you! What’s the universal method to solve any persistent issues or clean your Samsung device before selling? I know you can answer it. It’s to hard reset Samsung devices! A hard reset is a process that returns your phone to its original settings. Just like it was when you first unboxed it.
In this short article, we’ll show you a step-by-step guide to hard resetting a Samsung phone, with a bonus tip at the end. Now, what are we waiting for? Let’s get started!
When to Hard Reset Your Samsung Phone
A hard reset is usually appropriate in the following situations:
  • Frozen or unresponsive device: When your Samsung phone becomes frozen or unresponsive, attempting a hard reset can force the device to restart.
  • Fixing severe software issues: If your phone is experiencing severe software issues, such as frequent crashes, bugs, or other unusual behavior, and regular restarts or software tweaks don’t fix the problem, a hard reset may be a way to fix it.
  • Forgot password or pattern lock: If you forgot the password, PIN, or pattern lock that unlocks your phone and can’t regain access by other means, you may need to perform a hard reset to regain access to your device.
Note: A hard reset is often used to force restart a device, especially if it becomes frozen or unresponsive. This involves holding down a specific button combination on the device to force the device to shut down and then restart it. This does not erase the data on the device.
To perform a hard reset on most Samsung phones, follow these steps:
1. Simultaneously press and hold the Power and Volume Down buttons: Press and hold both the Power button (usually located on the right or top edge of the device) and the Volume Down button (usually located on the left edge of the device) at the same time.
2. Continue holding the buttons: Keep holding both buttons down for about 10-20 seconds. You may need to hold them longer depending on the device model.
3. Release the buttons when the phone restarts: After holding the buttons for the required time, your phone should restart automatically. Once you see the Samsung logo appear on the screen, you can release the buttons.
4. Wait for the phone to restart: Allow your phone to complete the restart process. It may take a few moments for the device to fully reboot.
Performing a hard reset does not delete any data from your device; it simply forces the device to restart. If you need to delete all your data and return your device to factory settings, you need to perform a factory reset.
Notes on Hard Reset Samsung Phone
Here are a few more things to consider when performing a hard reset on a Samsung phone:
  • Battery level: Before initiating a hard reset, make sure your phone has enough battery. It is generally recommended that the battery has at least 50% remaining to avoid any interruptions during the reset process.
  • Physical damage: If your phone has physical damage, such as a cracked screen or water damage, be careful when performing a hard reset. In some cases, physical damage can interfere with the functioning of the device, so it is best to resolve any physical issues before attempting a hard reset.
  • External storage: If your Samsung phone has an external microSD card inserted, a hard reset will generally not affect the data stored on the card. However, it is best to remove the microSD card before initiating the reset to prevent any potential problems.
Bonus Tip:Use DroidKit to fix Samsung System Problems
If hard reset doesn’t solve your phone problem, you can try system repair. DroidKit is a one-stop software developed for Android users that can solve any Android problem. For example: the phone is stuck and can’t restart, the phone is unresponsive, black screen, etc.
How to fix Samsung phone system problems:
Step 1. Free install DroidKit and open it on your computer > Connect your Android phone to the computer > Click the Fix System Issues mode right in the middle.
Click System Fix Function
Step 2. Once DroidKit detected your device, click the Start button to continue.
Start to Repair Android System
Step 3. DroidKit will automatically match the PDA code of your Android phone > Click  Download Now to get the firmware package, which is used for repairing the Android system errors.
PDA Code Matched
PDA Code Matched
Step 4. When it finishes downloading the firmware package, you will see the following interface, where you should click on the Fix Now button to initiate the fixing process.
Firmware Downloaded and Click Fix Now
Step 5. The device system will start to get repaired. Wait for a few minutes, your Android phone will get back to normal condition.
Completing the Repair Process
In this article, we look at the steps on how to perform a hard reset on a Samsung phone and what to look out for. A hard reset is a way to force restart a device, often used to fix issues like a frozen or unresponsive device. A hard reset does not usually delete data.
