Bought a second-hand Google Pixel 5 and found it is locked without a screen password? No worry, this article will introduce some efficient ways to unlock Google Pixel 5 without password.
The Google Pixel 5, renowned for its seamless integration of hardware and software, has garnered praise for its camera capabilities, clean Android experience, and overall performance. However, there are times when users find themselves locked out of their Pixel 5, unable to know the password or pattern. This situation can be frustrating, but fortunately, there are several methods to unlock the Google Pixel 5 without a password. Let’s explore 4 effective ways to regain access to your Google Pixel 5 and also touch on how to unlock your Google Pixel 5 to use it with another carrier.
You may also like: How to transfer files from Google Pixel to computer
Yes, it is possible to unlock a Google Pixel 5 without a password. Various methods leverage Google’s services or third-party tools designed to bypass the lock screen. These methods include using your Google account, specialized software like DroidKit, Google’s Find My Device service, and factory resetting the device in recovery mode. Each method comes with its steps and considerations, making it important to choose the one that best fits your situation.
Using your Google account to unlock your Pixel 5 is a straightforward method, provided you have access to the internet and remember your Google credentials.
Enter Google Account and Password to Unlock
This method is convenient and preserves your data, making it an ideal first attempt at unlocking your device.
Google’s Find My Device service can also be used to unlock your Pixel 5, especially if it is lost or stolen.
While effective, this method will result in data loss, so ensure you have backups of any important information.
The above 2 methods require the Google account information to unlock Google Pixel 5. But you may have either the screen password or the Google account information. How can you unlock Google Pixel 5 without passcode and Google account? Here you can use DroidKit Android unlocker to unlock your Google Pixel 5 without any password.
Why choose DroidKit Android unlocker:
How to unlock Google Pixel 5 using DroidKit:
Step 1. Download and install DroidKit on your Windows or Mac computer.
Step 2. Run DroidKit and choose the Unlock Screen option. Then use a USB cable to connect your Google Pixel 5 to your computer.
Choose Screen Unlocker
Step 3. Choose Google Pixel from the brand page. Then follow the instructions to unlock Google Pixel 5.
After the process is complete, your Google Pixel 5 will be unlocked without the password. You can set up it to use again.
Lock Screen Removal Completed
If you don’t want to use a third-party tool for Google Pixel 5 unlock, you can consider factory resetting it in recovery mode. Performing a factory reset in recovery mode is another way to unlock your Google Pixel 5 without a password, though it also results in data loss.
Enter Fastmode in Google Pixel
Factory Reset Google Pixel in Recovery Mode
Reboot System in Google Pixel Recovery Mode
This method is reliable but should be used as a last resort due to the complete data wipe.
Unlocking your Google Pixel 5 to use it with another carrier can be a straightforward process, often handled by the carrier itself. Here are the steps:
Unlocking your Pixel 5 allows you to use it with any compatible carrier, giving you the flexibility to choose a plan that best suits your needs.
Unlocking your Google Pixel 5 without a password is achievable through several methods, whether by using your Google account, third-party tools like DroidKit, Google’s Find My Device service or a factory reset in recovery mode. Additionally, unlocking your Pixel 5 for use with another carrier broadens your device’s versatility. Understanding these techniques ensures you can regain access to your phone or switch carriers without unnecessary hassle.
