If you want to remove the lock on your Android screen that says “Locked by Find My Device,” then this article will be a very great help in guiding you. We’ll go over everything you need to know about Google find my device unlock feature and how to remove find my device lock.
With DroidKit downloaded on your computer, you can unlock a phone locked by Find My Device, i.e. a Google-locked phone. And, you can unlock any phone locked by any screen locks like pattern, PIN, etc.
I locked my phone with Google Find My Device, but it now refuses to unlock it. My phone has become stuck on the lock screen and not allowing me to unlock it. How am I going to get out of this? I also couldn’t find a way to unlock it in the find my device app.
Google Find My Device is a tool that may be used to track down the whereabouts of a lost or stolen phone. It allows you to lock your phone with your PIN, pattern, or password. However, if you’ve found your lost phone but locked by Find My Device forgot the password, how to unlock Google Find My Device?
With a thorough guide, this article will cover nearly everything you need to know about Google find my device unlock on the phone. If you’re interested, keep reading!
Usually, you can unlock your smartphone via Google Find My Device by the following steps:
Step 1: Go to Android Device Manager on your computer and Sign in using the Google account associated with your locked Android smartphone.
Step 2: To open the lock screen on your computer, tap the Lock button on your selected device.
Choose Lock Option from Google Find My
Step 3: Now, enter a temporary password, then press the Lock button once again.
Set a Password for your Google Locked Phone
Step 4: Finally, your phone is locked by the password that you set, and you can now unlock your Android device with the temporary password.
If you are locked by Google Find My Device and can’t unlock a Google-locked phone without the previous owner’s password or forgot your Google account, here, you can use an FRP bypass tool as the safest solution to remove Google account and bypass the FRP lock. Droidkit, as a specialized Android password unlocking tool, allows you to unlock all Samsung phones & tablets locked by Google Find My Device.
Now, DroidKit supports bypassing FRP on Samsung, Xiaomi, Redmi, and more. Besides, it can unlock Android phone’s screen locks that Google Find My Device unlocks, including Android PIN, Pattern, Fingerprint, and other types of passwords.
Step 1: Launch the DroidKit on your PC or Mac > Select FRP Bypass.
Choose FRP Bypass Mode
Step 2: Connect your locked phone to the computer > Press the Start button > Choose the brand of your Android phone.
Step 3: After pressing Start, DroidKit will prepare the configuration file for your device automatically. When the preparation is complete, tap on Start to Bypass.
Tap on Start to Bypass
Step 4: Then follow the instructions on the screen to put your device into Recovery Mode. Find out and select the matching system version of your device and click on Next.
Choose System Version
Step 5: Please follow the instructions to finish some settings on your phone, including wiping the cache partition. After that, your device will restart, and the FRP Lock is also bypassed successfully.
Click Reset
Now, the tool will start bypassing the FRP lock on your Samsung device. Once the bypass process is completed successfully, your Samsung device will restart.
FRP Bypass Complete
If you need more information about unlocking a phone, read the tips to unlock an Android phone with/without Google Account.
When a phone is referred to as a Google locked phone, it simply refers to the process of employing a smart lock on your Android handset. When you use the Google lock, your device is automatically locked even when it is not in your safe hands or nearby. Google FRP lock will be activated after a factory reset, i.e. you need to verify your Google account and password to finish the setup process. Furthermore, there is a good probability that you purchased a used phone that is locked by your Google account. The former owner may have forgotten her or his Google password or neglected to delete the account.
Google Account Verification on Samsung
If your phone or second-hand phone is locked by Find My Device same as the above situations, keep reading and get some tips to avoid the Google verification screen or bypass Google lock on your phone.
You may accidentally enable Find My Device or the function may be enabled by default and running in the background, but you do not want to use it. Here’s how to disable Google Find My Device on your smartphone:
Google Find My Device is included in the standard OS and several other Android phones, and it is generally enabled by default. When you add a Google Account on your phone, Find My Device will be turned on automatically. It allows you to locate remotely, lock, or delete your Android devices, such as smartphones, smartwatches, and tablets.
Use Google Find My Device
Find my Device is primarily dependent on two activated features: Find My Device location services and the functionality itself. To use Google Find, your phone must:
When you use Find My Device each time, an alert will appear on the device you want to track. If you haven’t used this option and are seeing this message, it’s always a good idea to update your Google Account password and enable two-step verification.
Step 1: To begin, open a new browser tab and navigate to google.com/android/find, where you must log in to your account.
Step 2: Find My Device will attempt to unlock your smartphone or tablet. If location services are enabled, the location will be displayed automatically. As a result, assuming everything is in order, you should see a pin drop at the device’s location on the map.
Step 3: Remember that you can do three things once Find My Device is up and running for you.
What Can you Do with Google Find My Device
Besides, you can find and lock your lost phone from another phone, or ring your lost phone with your Wear OS watch once Google Find My Device is installed.
If your Samsung phone isn’t recognizing your PIN, pattern, password, fingerprint, or face unlock, restarting the device or entering Safe Mode can assist. You may be requested to use an alternative method, such as your password, at times. The Find My Mobile site can also help you in unlocking your device. To do so:
Step 1: To begin, go to the Find My Mobile website and sign in with the same Samsung account you used to lock your handset. Select your device from the list using the menu on the left side of the screen.
Unlock Samsung with Samsung Find My Mobile
Step 2: Find My Mobile may take a few seconds to find your device. To be located, the device must be turned on.
Step 3: Finally, when your device has been traced, tap Unlock, and then again hit on the Unlock button. To proceed further, enter your Samsung account password and then click Next. This will reset your device and change the Lock screen security type to swipe only.
Select Unlock Option
Find My Device is one of Android’s most useful features. You can find your smartphone online if you ever forget or misplace it. Furthermore, if your Android device is locked, utilizing Google Find My Device unlock is an excellent technique. And, DroidKit can unlock any phone password, pattern, PIN, etc. What’s more, you can unlock your locked Samsung phone and tablet/Xiaomi/Redmi with DroidKit’s FRP bypass tool. Free download and try it now!
