How to Unlock my Motorola Phone with/without Factory Reset
Can’t access your Motorola because you forgot the screen password? Don’t want to lose data to unlock your device? Read this post to learn how to unlock motorola phone password without factory reset.
Author Avatar Joy Taylor Last Updated: Feb. 23, 2024
DroidKit – Unlock Motorola Phone Forgot Password
How to get into a locked Motorola phone? Free download DroidKit to remove any Android phone’s lock screen when forgotten password. No matter if you forgot the numeric password, PIN code, etc. on your Android Motorola, you can unlock it with simple clicks.
Everyone wants to protect their phone data from peaky eyes and usually chooses a complex screen lock. While this is justified from a security standpoint, it can lead to situations where access is denied because the owner forgets his own password. Sometimes factory resetting is an effective solution, but completely deleting phone data is unavoidable. No one wants to needlessly lose all their images, contacts, and documents, so this should be considered an option of last resort.
Here in this post, you can learn how to unlock motorola phone password without factory reset to initiate and safely gain access to the device. Besides, you can also get some information about Motorola default PIN code.
Also Read: How to Wipe Android Phone Before Selling >
How to Unlock Motorola Phone Password without Factory Reset by ADM
A simple and convenient tool that can be used to accomplish this task is Android Device Manager – ADM. Your Motorola phone, like any other active Android device, is linked to your Google account. The main point of this method is to leverage access to your Google account and password, to get around the original problem. You can unlock Motorola phone password without factory reset on a computer or another phone, but you need to provide a stable internet connection for the duration of the process.
Step 1: Type the address www.google.com/android/find in the web browser on any device.
Step 2: Sign in with your unique Google account username and password.
Step 3: Google will start to search for your device. If you have multiple devices registered on the same account, choose the one you want to unlock from the list.
Step 4: Three options will appear on the screen, click on one that allows you to change the password.
Choose Change the Screen-unlock Password
Step 5: Empty window will appear. Enter a temporary password, and click on the Lock again. If the process is successful, you will get a confirmation message.
Step 6: On your locked Motorola enter the previously used temporary password, and your device will be unlocked. You will be able to use your phone any without limitations and set up a new password for permanent use if you so decide.
Further Reading:
How to Unlock Motorola Phone Pattern without Losing Data
This method is very successful for Android 4.4 and similar OS versions typically found on older phones. You can easily unlock your screen and continue to use your device without any consequence for your content or earlier setups. Indeed, this is a great operating system feature that can be extremely helpful in case you forgot a password or pattern, etc. Follow the next steps and see how to unlock Motorola phone password without factory reset.
Step 1: After five to six unsuccessful attempts to log in with a password, on the bottom right corner of the screen of the phone you will see the question Forgot pattern? Click on the text.
Step 2: You will be offered two options as a way of unlocking the phone. Select Unlock with Google account details.
Step 3: Enter your Google account username and password when prompted. After taking this action, you will be able to use your device normally.
Tap Forgot Pattern Button
You probably don’t want to go through this process every time you need to unlock your phone, so don’t forget to set a new password that will be easier to remember.
How to Unlock Motorola Phone without Password in 1 Click
DroidKit – Android Phone Toolkit also allows you to get into a Motorola phone without a password in simple clicks. With DroidKit installed, you can remove any screen locks on your Motorola, including a numeric password, PIN code, pattern lock, fingerprint, etc. After unlocking, you can get full access to the phone and enjoy its functions. Besides, DroidKit allows you to unlock 20,000+ models of Android phones & tablets and makes the complicated unlocking process easy for everyone to follow.
As a complete Android solution, you can also use DroidKit to recover deleted data, extract data from Google account, bypass FRP lock after factory reset, etc. You can also read on to see what it can do for you to unlock Motorola phone.
DroidKit – Unlock Motorola without Password
  • Unlock any locks, including PIN, password, pattern, fingerprint ID, etc.
  • Unlock Motorola phone and other 20,000+ Android models.
  • Remove screen locks easily without root.
  • Thus fully access your locked device again in minutes.
Here is how to unlock Motorola phone without password:
Step 1. Get the latest version of DroidKit. Launch the software and click Unlock Screen.
Choose Screen Unlocker
Step 2. Connect your phone and Start. (You can preview what DroidKit can do for you, and notice that this function will erase data on your device.)
Connect your Locked Phone
Note: all content on your device will be erased after the screen lock gets removed successfully.
Step 3. Click on the Remove Now button until you see the configuration file is prepared.
Click Remove Now Button
Step 4. Choose your Motorola brand and follow the on-screen instructions to remove the screen password. Later, it will start removing the lock screen. Once the process is finished, you will get the Screen Lock Removal Completed page.
Lock Screen Removal Completed
Unlock Motorola Phone Forgot Password with Factory Reset
If you already tried to unlock your Motorola with the above-described methods and failed time after time, or your Android OS is not matched, you might have no other course of action than to activate Factory Reset. This method should be considered only if you have no other possibilities, because your content, messages, and all device setups will be permanently deleted. It’s better to make sure you already backed up your phone earlier, or you need to try some methods to recover data after a factory reset.
Before you start with Factory Reset, be sure to check the status of your battery power. If it is under 20%, there won’t be sufficient power to complete it. So it’s mandatory to recharge the battery first.
Once you’ve taken care of this, you can start with the actual steps of how to unlock Motorola phone.
Step 1: Turn off your phone.
Step 2: Press Home, Power, and Volume Up keys on the side of your device, all at the same time. With that combination, you will send your phone into Recovery Mode.
Step 3: Use Volume Up and Down keys navigate through the menu and select the Power/Home option.
Step 4: Select the Data/Factory reset option and click on that button.
Step 5: Confirm your final decision to Factory Reset your Motorola phone.
Wipe Data to Unlock Phone
It may take some time for your device to complete the required operations, so be patient. When everything is done, you can access the phone, but unfortunately, the entirety of your content will be lost.
What Is the Master Code to Unlock a Motorola Phone?
You can try “1234” to enter the default PIN on your Motorola phone. If it’s not working for you, you can try the above methods to unlock with or without factory reset. Besides, the default Android PIN is also “1234” for Sprint and T-Mobile Android device; “1111” for AT&T and Verizon. When your Android phone is locked, you can first try the default code one or two times.
How to Network Unlock Motorola Phone?
Except for the above methods that you can unlock a Motorola phone, you can also contact your phone carrier. And, when your phone is network locked, try to insert another SIM card into your phone, with different network carrier.
While it’s certainly recommended to remember your password or even write it down if necessary, it’s good to know methods to unlock Motorola phone forgot password. In this article, you can even learn about how to unlock Motorola phone password without factory reset. If you want the easiest and fastest method, DroidKit must be your top choice. Just free download DroidKit to try it now.
