Best 12 FRP Bypass Tools to Bypass Google Account on Android
This post lists 12 popular FRP bypass tools, including their main features, pros and cons. You can compare them and choose your preferred one to bypass FRP on Android device.
Author Avatar Joy Taylor Last Updated: Mar. 13, 2025
Undoubtedly the integration of Google FRP on Android devices has improved users’ data privacy exponentially.  You no longer have to worry when you lose or misplace your Android phone. However, some users may fail to verify the Google account after factory resetting their Android devices. In this case, an FRP bypass tool is necessary for a quick and easy solution. Among various FRP bypass tools, which is the best one to bypass the Google account on Android? Don’t worry, this article will walk you through 12 paid and free FRP bypass tools. Keep reading and choose the best one to solve your problem.
    What Is Factory Reset Protection (FRP)?
    Factory Reset Protection is an advanced security feature introduced by Google to all Android OS, including Samsung, to help prevent unauthorized users from accessing the corresponding device after a factory reset. The feature works by requesting the password/passcode to the Google account used in setting up the device. Provision of the correct password gives you full control of the device. But failure to do so renders the device useless as you cannot access it.
    Can the FRP Lock Be Bypassed?
    Yes, you can use the logged Google account information to remove FRP or use an FRP bypass tool to bypass the verification without password. Generally, the FRP bypass tool is necessary when you can’t provide the Google account information. Take it easy, several FRP bypass software or apps are efficient to bypass FRP on Android devices. Most of the tools are used on the computers, making it convenient to solve the FRP problems. The following 12 tools include both desktop programs and mobile apks, you can choose the suitable one according to your status.
    Top 1. DroidKit – Easiest FRP Bypass Tool 2025
    The first recommended FRP bypass tool for PC is DroidKit, a professional Android FRP bypass tool trusted by millions of users. It supports bypassing FRP on most Android brands, such as Samsung, Xiaomi, Redmi, and more. It works on both Windows and Mac computers, providing the easiest steps to bypass FRP on Android phones and tablets.
    DroidKit is more than an FRP bypass tool, it offers a one-stop solution for multiple Android issues, including Android screen unlock, data recovery, system fix, and system reinstall. It is an all-in-one Android device manager.
    What makes DroidKit outstanding?
    • It only takes a few minutes to bypass FRP lock, saving much time and energy for you.
    • Simple operation and clear instructions, so that you can even complete FRP removal at home by yourself.
    • Support Android 6 and later system versions, and customize bypass solutions according to the system to ensure the highest success rate.
    • Adopt advanced encryption technology to ensure that your privacy is 100% safe and will never be disclosed to anyone else.
    Now you can download DroidKit and follow the steps to bypass FRP on your Android device.
    Step 1. Launch DroidKit on your computer. A screen showing all the services offered by the software will pop up. Select FRP Bypass.
    Choose FRP Bypass Mode
    Choose FRP Bypass
    Step 2. Connect your Samsung device to the computer via USB, and click the Start icon. Then select the device brand. Here we choose Samsung.
    Click on Start
    Step 3. Next, DroidKit will commence the preparation of a configuration file for your device. When the preparation is over, click Start to Bypass. Then follow the on-screen guide to enter recovery mode.
    Click Start to Bypass
    Tap on Start to Bypass
    Step 4. After completing the aforementioned step, DroidKit will scan your device and recommend a firmware package to bypass FRP. Kindly select your Android version and click Next.
    Choose System Version
    Select System Version and Click Next
    Step 5. Wait for the firmware to download, then follow the instructions on the screen to complete the corresponding settings.
    Click Reset
    Complete Corresponding Settings
    Step 6. After that, it will start to bypass FRP lock automatically. You will see the interface below when it is completed.
    FRP Bypass Complete
    FRP Bypass Complete
    Top 2. Samsung FRP Helper V0.2
    When you are looking for FRP bypass tools, you may ask: Is there a free FRP bypass tool? Yes, of course! Samsung FRP Helper V0.2 is a free FRP tool for Samsung devices. It supports Android 7.0 and earlier versions. And you can learn more about this FRP tool before you use it to bypass FRP on Samsung free.
    Pros:
    • Samsung FRP Helper V0.2 is a freemium tool to wipe FRP lock screens on Samsung devices running on Android Nougat and earlier versions.
    • No registration is needed to use the tool.
    Cons:
    • It’s limited to Android 7 and older OS.
    • End-users of Samsung FRP Helper V0.2 are required to activate ADB mode on their devices prior to the FRP bypass process.
    Top 3. GSM Flasher Tool
    GSM Flasher Tool is a good choice for those who are looking to bypass Google account verification for free. This FRP tool deactivates the Google synchronization mode on Android smartphones to wipe FRP lock, and give you full control. And it is not only for Samsung devices but an FRP bypass tool to Android, so you can use it to unlock all your Android devices.
    Besides FRP bypass, GSM Flasher Tool removes pattern locks on Android devices. It’s one of the most versatile FRP bypass tools on our list. This tool is pretty easy to install and use.
    GSM Flasher Tool
    GSM Flasher Tool
    Pros:
    • It removes Google FRP from Android phones without delay.
    • GSM Flasher Tool has no subscription plans, thus, it’s free to use.
    Cons:
    • GSM Flasher Tool bypasses FRP lock on selected Android versions, 4.0 or lower.
    Top 4. UnlockUnit Intelligent Assistant
    In addition, there are other Android FRP bypass tools. UnlockUnit Intelligent Assistant is a smart FRP bypass tool worth using. As one of the best FRP bypass tools for Android, it works by providing you with a unique Google FRP unlock code which you enter on your Android device to bypass FRP Lock Screens. It’s one of the universal bypass FRP tools on this list as it connects and unlocks other mobile brands, such as Apple, Motorola, Huawei, and more. And below we also list the pros and cons of this FRP tool.
    Unlockunit Intelligent Assistant
    Pros:
    • UnlockUnit Intelligent Assistant is available in Windows and Mac versions.
    • Uses Smart AI to remove FRP lock on Android devices.
    Cons:
    • UnlockUnit Intelligent Assistant often requires that you put your device in ADB mode before FRP bypass operation.
    • It’s not suitable for Android phones running on the latest OS versions.
    Top 5. Pangu FRP Bypass
    Pangu FRP Bypass has always been considered as one of the best Android FRP bypass tools. It can facilitate the removal of Google FRP on Samsung devices without requesting a combination. It also works with other Android smartphones like Motorola, Lenovo, and several others. So if you are looking for an FRP tool for your Android device, you can download FRP bypass APK and try Pangu FRP unlocker first. Just read on to learn more features of this FRP bypass tool for Android.
    Pangu FRP Bypass
    Pangu FRP Bypass
    Pros:
    • Pangu is the best FRP bypass solution for most Android devices.
    • Suitable for removing FRP lock on over five (5) Android brands, including Lenovo, HTC, Motorola, and more.
    Cons:
    • Pangu has a complex Google FRP bypass interface which is quite difficult for novices to navigate.
    • Prior to the FRP bypass, end-users are often required to download the bootloader for the corresponding Samsung device.
    • The Pangu FRP Bypass tool requires an internet connection for operation.
    You May Like: You can bypass FRP lock on Huawei by reading Full Guide on Huawei FRP Bypass with/without PC >
    Top 6. King Tool
    Here is another Samsung FRP bypass tool designed to bail you out when your Samsung device enters Google FRP Lock Screen. King Tool wipes FRP lock on Samsung phones as quickly as possible without compromising the device.
    In addition to the FRP bypass tool, it also offer tools to fix Android system issues, such as IMEI repair, etc., on Samsung mobile devices, and tablets. King Tool is one of the best Samsung FRP bypass tools on this list with budget-friendly subscription pricing.
    King Tool
    King Tool
    Pros:
    • King Tool fixes and bypasses lock screens on Android operating systems, including Samsung.
    • It offers cheap pricing plans.
    Cons:
    • The user interface is quite technical, so users are required to have substantial knowledge of information technology to operate it.
    • King Tool often takes time to complete FRP bypass.
    Top 7. Easy FRP Samsung Tool
    Another free FRP bypass tool for PC you can count on to make FRP unlock Samsung, that is Easy FRP Samsung tool. It simplifies the Google FRP bypass process so you can gain full control of your device within the shortest possible time.
    This Windows-compatible software unlocks all Samsung devices with FRP issues, from Android 9 to the latest version. Easy FRP Samsung tool is lightweight, easy to operate, and reliable, and has been considered one of the top FRP bypass tools for Android. You can learn more about this FRP tool below.
    Pros:
    • As the name implies, Easy FRP Samsung Tool is simple to operate and works perfectly on Windows computer devices.
    • Bypasses FRP on Android devices with OS starting from 9.0 to the latest.
    Cons:
    • Requires technical knowledge for you to navigate.
    • You must update your Samsung Drivers to use the Easy FRP Samsung tool.
    Top 8. Octoplus FRP Tool
    Octoplus FRP Tool makes FRP bypass simpler and quicker on Android devices. It’s also one of the best FRP bypass tools for Android to erase FRP lock screens on many Android devices like Samsung, HTC, Sony, and more. This FRP bypass tool offers at least four (4) unlock options to bypass FRP lock on Android.
    Octoplus FRP Tool
    Octoplus FRP Tool
    Pros:
    • It’s capable of removing FRP lock on nearly all verified Android phones without complications.
    • Compatible with several Android products.
    Cons:
    • Octoplus FRP Tool is a subscription-based tool. Thus, unless you pay for the premium service, you cannot use it.
    • It offers costly subscription services, as users are charged $65 to bypass FRP lock screens.
    Top 9. Foneazy Unlockit
    Another best FRP bypass tool for PC we want to introduce is Foneazy Unlockit. With one click, this Samsung FRP tool lets you bypass FRP Lock on your Samsung device (with OS 7/8/9/10/11/12) with minimal effort. It erases the Google account synchronization feature on your Samsung phone as quickly as possible to give you full control after factory reset.
    Newbies in the tech industry find this FRP tool easy to operate. Thanks to the developers for simplifying the interface. It removes FRP screens without compromising your data. Foneazy Unlockit integrates perfectly with all computer systems.
    Foneazy Unlockit
    Foneazy Unlockit
    Pros:
    • With Foneazy Unlockit, you can manipulate FRP Lock Screens and regain total control of your Samsung device without stress.
    • Foneazy Unlockit performs all operations without data loss.
    Cons:
    • Foneazy Unlockit requires a subscription for you to deactivate or bypass FRP lock.
    • It doesn’t connect with Android devices running on OS version 6.0 and below.
    Top 10. FRP HyJacker
    Another FRP bypass tool worth investing in is the FRP HyJacker. This tool packs all the amazing features required to bypass FRP lock on all Samsung devices, including the latest. It bypasses factory reset security locks in download mode without requesting a combination ROM. Therefore, it is always mentioned when people look for a Samsung FRP bypass tool.
    Additionally, FRP HyJacker Tool fixes the soft brick error message (a complicated error that occurs when unlocking the Bootloader on Samsung devices). It’s the best fit for resetting Samsung devices to default mode.
    FRP Hyjacker Tool
    FRP Hyjacker Tool
    Pros:
    • This tool does more than just deactivate FRP locked screens, as it enables users to repair soft bricks.
    • FRP HyJacker Tool can be accessed on Windows computers.
    Cons:
    • It bypasses FRP lock at a remarkably low speed which can be frustrating to users.
    • Frequent bug attacks during operation.
    Top 11. UnlockJunky
    UnlockJunky is another tool to deactivate FRP lock on Android devices. Within 5-minutes, this cloud-based program removes FRP locks without compromising the device. Additionally, UnlockJunky unlocks Android devices with locked carriers. Just find more features of this FRP tool below.
    UnlockJunky
    UnlockJunky
    Pros:
    • UnlockJunky lets you unlock FRP lock screens on Android devices.
    • It also fixes Android system issues.
    Cons:
    • Requires an internet connection for you to bypass FRP lock on your Android device.
    Top 12. D&G Password Unlocker
    The last recommended FRP bypass tool is D&G Password Unlocker. It is an excellent tool programmed to assist you bypass FRP locks on Android operating systems. D&G Password Unlocker is well-organized with a comprehensive interface that makes FRP bypass simple and quick. Connecting this program with your Android phone to deactivate FRP requires Windows computers such as Windows 7/8/10/XP.
    Pros:
    • D&G Password Unlocker offers free FRP bypass services.
    • It’s designed with a clean UI, so amateurs can navigate without challenges.
    Cons:
    • This tool is only available in the Windows version. Thus, you cannot bypass FRP lock on your Android if you use Mac.
    • D&G Password Unlocker often requires enough storage space for installation because of the large file size.
    All FRP tools above can help you unlock Google FRP lock on your Samsung or other Android devices successfully. Just pick one you like to bypass FRP now.
    With the FRP bypass guide above, bypassing Samsung/Android FRP lock shouldn’t be a challenge anymore. Each FRP tool introduced has been tested and confirmed by experts. Just select the one that suits you and wipe Google FRP today. And if you need a comprehensive toolkit to bypass Google FRP on Samsung, Xiaomi, Redmi, or OPPO, DroidKit is the best option you’ve got on the list. Because it has the easiest operation and the highest success rate. So why not get DroidKit for free and have a try?
