Can’t access your Samsung device after a reset? It’s probably because of FRP Samsung. Luckily, FRP bypass Samsung is not so difficult. And here are 4 proven ways to bypass FRP Samsung easily.
DroidKit provides the easiest way to bypass Samsung Google account on computer. The updated unlock algorithm improves the success rate for Samsung FRP bypass. Support all Samsung models running Android 6 to 15. Download it now and enjoy seamless FRP bypass on Samsung.
As the mobile phone technology develops, there are better security protections on Android phones. Common security features on Samsung include the screen password, pattern, fingerprint, and more. Here we’d like to introduce the factory reset protection on Samsung, which is enabled and triggered in some certain conditions. Let’s get started!
Like any other Android device, Samsung FRP is a robust security system compatible with smartphones with Android version 5.1 or later. This feature keeps your device safe from unauthorized access as it requires you to sign in using the Google account associated with the device. FRP on Samsung is beneficial in cases where your device is stolen or lost. The FRP lock does not allow access to a device without signing in to the Google account synced to it. Therefore, even if someone factory resets it, they won’t be able to get in.
You may also like: How to lock Samsung when it is lost
Yes, fortunately. While FRP Samsung is foolproof to some extent, there are still several methods and tools that can help us bypass Samsung FRP. For instance, you can use Google Account Manager to remove FRP lock Samsung. Or, you could use a third-party tool to bypass FRP Samsung, like DroidKit or Odin.
Other ways include using an APK or using your SIM to receive a password reset link via text. All these methods are easy, except for using Odin, as it requires a bit of technical knowledge to use it. And in the next part, we will discuss in detail about the methods to FRP bypass Samsung. Let’s read on.
As we have mentioned earlier, Samsung FRP bypass can be difficult on the device itself. The possible way is to use Samsung FRP bypass tools or process complicated settings. Check the following methods and choose your preferred one to try.
The first method to FRP bypass Samsung is by using a professional Android unlocking tool like DroidKit. It is a complete Android device toolkit that helps bypass FRP lock on Samsung safely and securely. The success rate of FRP bypass in DroidKit is higher than most other tools on the market. Besides, DroidKit comes in handy for Android screen unlock, Android data recovery, fixing underlying system errors, and more. Below are some key features of DroidKit in Samsung FRP bypass.
DroidKit supports all Samsung devices with Android 6 to 15, like Samsung S series, A series, F series, etc. Just download DroidKit and follow the steps to bypass FRP on Samsung.
Step 1. Launch DroidKit on your PC/Mac, and click the FRP Bypass option from the interface.
Choose FRP Bypass Mode
Step 2. Connect your Samsung device to your PC using a USB cable and click Start. Then you need to choose the device brand.
Step 3. DroidKit will prepare a configuration file for your device; therefore, don’t unplug your phone during the process. After that, click on Start to Bypass.
Click Start to Bypass
Step 4. Select your Android system version from the given options and click Next.
Choose System Version
Step 5. Continue following the on-screen instructions on the DroidKit interface to complete some settings on your device.
Complete Corresponding Settings
Step 6. Once you complete the steps on the screen, it will bypass the FRP lock on your device, and then you can access your phone easily.
FRP Bypass Complete
How to bypass FRP lock on Samsung free? Then, Samsung FRP SIM PIN method is for you. Using this Samsung FRP bypass code is by far one of the easiest ways to bypass FRP Samsung. This method uses your SIM to receive a link or code from Google to reset the password. Therefore, you’ll have to put your SIM into another device to receive the text from Google. Here’s what to do to complete FRP bypass Samsung in this way.
Step 1. Once you reset your Samsung phone, it will ask you to enter your Google credentials. Tap on “Forgot Password” at this point.
Tap on Forgot Password
Step 2. Take out your SIM from the locked Samsung phone and put it in any other device. Select the option to reset the password using your phone number. You will receive the link to reset your password via text.
Step 3. Once you set up a new password, you can use it to access your locked Samsung phone.
Odin FRP bypass is another way to bypass Google account on Samsung after factory reset. It is a Windows-based software by Samsung. The main purpose of Odin is to root Samsung phones and install firmware updates and kernels on Android devices. However, it upgrades your device with custom features and helps bypass FRP lock on Samsung.
This process is a bit technical and requires you to install several pre-requisite files on your PC, like:
Once you have all these files in place, follow these steps to FRP bypass Samsung using Odin:
Step 1. Download and install Odin on your Windows PC.
Step 2. Now put your Samsung device in Recovery Mode by long-pressing the volume down and power buttons. Release the power button, but continue holding the volume until you see the Recovery Mode screen pop up.
Step 3. Connect your device to your PC using a USB cable, and launch Odin.
Step 4. Odin will display a list of .zip files that you need to continue with the FRP bypass Samsung process.
Step 5. Select AP, CP, and CSS tabs, and browse through the downloaded files on your PC to import them. These files are included in the Samsung FRP files you downloaded earlier.
Click AP/CP/CSC Options
Step 6. Once the files are imported, click “Start” to initialize the FRY bypassing process.
Step 7. The process will take a few minutes to complete, after which you will see a “PASS” message. This means the FRP Samsung has been successfully removed.
A PASS Message Pops up
This process can be quite tricky and challenging for most people; therefore, here’s another easy way to bypass the Samsung FRP lock.
How to remove FRP lock on Samsung, if you don’t have access to a PC? Don’t worry. You can still bypass FRP Samsung using your locked device. For this method, we will use an FRP Bypass APK. Following are the steps to download and use FRP Bypass APK for FRP bypass Samsung:
Step 1. Connect your Samsung device to a Wi-Fi network.
Step 2. Tap the arrow next to the Wi-Fi network and click “Manage Network Settings.”
Tap Manage Network Settings
Step 3. Tap on “Static IP > IP Address.”
Step 4. Type anything in the space for the IP address and long-press it until you see the “Web Search” option.
Step 5. Search for “FRP Bypass APK” and download and install it.
Step 6. Launch FRP Bypass APK, and go to “Settings > Try.”
Step 7. Go to “Fingerprints, Face, and Password > Screen Lock > Pattern” and set a new pattern for your device.
Step 8. Return to the main page and enter your new lock screen pattern.
Step 9. Tap on “Skip” to bypass the FRP lock.
And that’s how you can bypass FRP Samsung in a few simple steps.
With the above methods, you may successfully bypass FRP lock on Samsung. To prevent you from getting stuck on Google account verification again, you can disable the FRP lock on your device. However, it should be noted that this method is only applicable to Android 5.1 and below systems. If your system version meets the requirements, then you can follow the steps below to disable the FRP lock.
Step 1. Find and select the Apps application on your Samsung device.
Step 2. Click on Settings and then select the Accounts option.
Step 3. Here you will see the Google option. Click on it and then tap on your name.
Step 4. You need to click on the More option on the top-right.
Step 5. Choose Remove Account and confirm again. Then the Google account and FRP lock will be removed from your device.
Click Remove Account
Being locked out of your phone is just like getting locked out of your house; you can’t enter without the key! If you ever factory reset your Samsung phone and can’t remember your Google account credentials, these 4 ways will help you with FRP bypass Samsung. And if you want to bypass FRP Samsung immediately and easily, just try DroidKit for free first. Let us know in the comments if you have ever faced such a situation and what worked best.
