Factory Reset Protection (FRP) is a security feature introduced with Android 5.1 to prevent unauthorized access after a factory reset. If you’ve forgotten the Google account linked to your Samsung Galaxy Note 5, FRP can lock you out after a reset. Thus in this post we will discuss how to bypass FRP on Samsung Note 5.
FRP protects your device by requiring Google account credentials after a reset to prevent unauthorized access. If you forget your account details or buy a second-hand device with FRP enabled, bypassing it may be necessary.
DroidKit is a versatile Android tool designed to fix various issues, especially for Samsung devices. It offers several useful features, including Samsung J4 FRP bypass. Besides that, it helps with data recovery, system repairs, and device content management.
With its wide range of functions, DroidKit tackles common problems Android users face. Whether you’re trying to regain control of your device or recover important data, DroidKit is a reliable solution.
Key Features of DroidKit
Steps to Factory Reset S21 Without Password via DroidKit
Step 1. Download DroidKit on your PC. Install it and connect your Note 5 to the PC using a USB cable.
Step 2. Launch DroidKit and select the “FRP Bypass” tool from the main interface.
Step 3. Choose your brand and click “Start” from the new window.
Step 4. DroidKit will prepare the configuration profile. Once complete, click the “Start to Bypass” button.
Step 5: After clicking the start to bypass button, select the OS of your device. Then, click the “Next” button and proceed.
Step 6: Now, navigate to the “Enter your current password interface” and follow the on-screen instructions to enter factory mode. Once you have done so, click the “Reset” button.
Step 7: After clicking the reset button, DroidKit will start the Samsung J4 FRP bypass process. Once completed, you will see the below interface.
– After the reset, select your language and connect to Wi-Fi.
– In the Google account field, long-press the “@” symbol on the Gboard keyboard.
– Select the settings icon.
– In Gboard settings, tap Help & Feedback.
– Search for “Use Google Keyboard.”
– Highlight text in the help article and tap Web Search.
– Type “Settings” and open the app.
– In Backup & Reset, perform a factory reset to disable FRP.
– After the reset, complete the setup without Google account prompts.
– On another device, download the APK from a trusted site and save it to a USB drive or SD card.
– Power on your Galaxy Note 5 and connect to Wi-Fi.
– Use an OTG cable to connect the USB drive or SD card, and install the APK.
– In Settings, perform another factory reset. The FRP lock will now be removed.
FRP can lock you out of your Samsung Galaxy Note 5, but several methods, including using Gboard, APKs, or DroidKit, can help you regain access. Notably, DroidKit is professional Android toolkit that can deal with all kinds of issues to help you out of dilemmas. Try it now!
