Samsung Phone Not Accepting Correct Password [7 Fixes]
You may experience trouble in unlocking your Samsung phone, when you forgot the password. And some users also face the Samsung phone not accepting correct password or Samsung password not working. Don’t worry. In this article, you’ll read about several effective ways to fix these issues and unlock Samsung phone with ease.
Author Avatar Roger Smith Last Updated: Aug. 14, 2024
DroidKit – Fix Samsung Not Accepting Correct Password
What if my Samsung phone is not accepting my password? Don’t panic. Free download DroidKit to 1-click unlock Samsung phone, whether you forgot Samsung phone password or Samsung password not working. It can unlock all screen locks, like numeric passcode, Touch/Face ID, PIN, pattern, etc. All Samsung and other Android devices are supported.
Just like other Android smartphones, Samsung also offers an array of security options. You can conveniently lock your Samsung phones using PINs, patterns, passwords, etc., to protect your data. However, these security options may cause serious trouble, especially when users forgot password on Samsung phone or Samsung password not working.
If you’re also facing the Samsung phone not accepting correct password problem, this detailed article will work for you. No matter whether Samsung not accepting passwords, or you forgot a Samsung pattern, password, etc., you can get into your phone or tablet, or reset the password. Now, let’s begin!
Why Is Samsung Phone Not Accepting Correct Password?
Why is my Samsung saying incorrect password? It is possible that you have clicked on the wrong key in a hurry. Or, the Android OS just does not recognize your password suddenly due to a system error. When you encounter Samsung phone password not working issue, the first thing to do is retyping your password carefully. But note that too many password attempts may lock your phone forever.
However, if the issue is still present, how to unlock Samsung phone? Then, you need to try the methods below to fix Samsung phone not accepting correct password, and unlock Samsung phone forgot password.
1-Click Unlock Samsung Phone Not Accepting Correct Password/PIN/Pattern
What to do if I forgot my lock screen password Samsung or Samsung phone won’t accept my password? Android screen unlocker will help you unlock your Samsung easily. DroidKit is a one-stop Android solution that helps you unlock any Android screen locks like passcode, PIN, pattern, etc. No matter if you forgot the password, Samsung galaxy password not working, Samsung phone won’t accept your password, or enter the wrong password too many times, you can get into your phone with DroidKit. And here is how DroidKit can help you to unlock Samsung.
  • Unlock any password on your Samsung, including a numeric password, PIN code, pattern, fingerprint, face recognition, etc.
  • Get into a locked phone without root. Unlock your device with 1 click. No skills are needed.
  • Unlock in minutes. You don’t need to wait hours or days to get access to your phone.
  • Supports all Samsung phones and tablets, and any other Android devices, like Huawei, Xiaomi, LG, etc.
  • What’s more, you can fix system issues if they are the cause of Samsung password not working. You can also Bypass FRP on Samsung, recover your lost data, flash your Samsung device, and more.
Now you can free download DroidKit. Below is how to unlock Samsung phone forgot password or won’t accept password.
Steps to Fix Samsung Phone Not Accepting Correct Password:
Step 1. Choose Screen Unlocker
Launch DroidKit on your computer and choose Screen Unlocker.
Choose Unlock Screen Function
Step 2. Connect Samsung and Start
Connect your Samsung with the computer and Start. Note: All content on your device will be erased after the screen lock gets removed successfully.
Connect your Locked Phone
Step 3. Prepare the Configuration File
Wait for the configuration file prepared automatically. Tap on Remove Now.
Click Remove Now Button
Click the Remove Now Button
Step 4. Remove Screen Password on Samsung
DroidKit will identify your Samsung brand. Just follow Samsung’s on-screen instructions to remove the screen password.
Confirm Locked Device Brand and Continue
Step 5. Samsung Password Removed Successfully
You will get the Screen Lock Removal Completed page when the screen lock has been removed successfully. Your phone will reboot and you can get into it.
Lock Screen Removal Completed
How to Fix Samsung Phone Not Accepting Correct Password/PIN/Pattern
How to unlock a Samsung phone when you forgot the password, or Samsung phone won’t accept correct password? Don’t worry, in addition to the above method, here are some other fixes to help you solve Samsung password not working problem.
Fix 1. Reboot Your Samsung Phone
When Samsung phone not accept correct password, the first thing you should do is reboot your Samsung phone. This can solve the system errors and help you fix this issue. Here are the steps.
  1. Press and hold the Power button until the Restart option appears.
  2. Click the Restart button.
  3. Your Samsung phone will restart. Then, enter your password again.
Fix 2. Boot the device into Safe Mode
You might have installed a third-party lock screen application to keep your device secured. If yes, then consider booting your device into safe mode to fix Samsung password not working. Here’s what you need to follow:
Step 1: Go to the Power menu from the lock screen. Press and hold the Power Off button.
Step 2: Click on the Ok option when a prompt appears on your screen asking if you want to boot in safe mode.
Use Android Safe Mode
Step 3: Once the procedure is finished, the lock screen activated by the third-party application will be disabled temporarily. Uninstall the third-party lock screen application or reset the data.
Step 4: Reboot your Samsung device again and come out of safe mode.
Fix 3. Use Android Device Manage
Android Device Manager, also used as Google Find My Device, which is similar to Samsung Find My Mobile. ADM can be used to unlock Samsung phone forgot password or password not working. Follow these instructions to fix Samsung phone not accepting correct password by using Android Device Manager:
Step 1: On your PC or another Android mobile, open the Find My Device website.
Step 2: Sign in to the Google account that is linked with your locked Samsung device and select the device you want to unlock.
Step 3: Tap on the Lock option.
Step 4: Then, enter a temporary password in the following screen and click on the “Lock” option once more. Mentioning a recovery message is optional.
Step 5: If the process is successful, you’ll see Ring, Lock, and Erase buttons on the screen
Step 6: Now, you’ll get the password field on your device to enter the new password, and your device will be unlocked.
Step 7: Once done, open the lock screen settings on your Samsung device and disable the temporary password.
Fix 4. Use Google Account to Unlock Samsung Phone
You can use the information of your Google account to Solve the Samsung password not working problem and unlock your Samsung device. However, this method will work only if your device is running on Android 4.4 or a lower operating system. Check out the steps below to learn how to unlock Samsung phone forgot password using Google account.
Step 1: Enter the incorrect password five times and select the Forgot Password option on the screen.
Step 2: Now, enter your backup PIN or Google account login credentials to unlock your Samsung device.
Enter the Details
Enter the Details
Fix 5. Bypass Samsung Lock Screen with ADB
Next on the list of methods to fix the issue of Samsung phone not accept my password is using the ADB directory. But, this method will work when you’ve enabled USB debugging on your Samsung device, and your computer is allowed to connect through ADB. If you meet these two prerequisites, you can easily bypass the Samsung password. Here’s what you need to do to fix Samsung phone not accepting correct password.
Step 1: Connect your Samsung device to the computer or laptop via a cable and open the command prompt in the AND directory.
Step 2: Type the ADB shell rm /data/system/gesture.key command and press the Enter key. Once done, restart your phone. The lock will be deactivated. Ensure to set a new password or pin before rebooting again.
Enter the Command and Restart
Further Reading: Here is a tip about Samsung unlocking How to Unlock Samsung Phone Forgot Password without Losing Data >
Fix 6. Remote Unlock Samsung with Find My Mobile
If you are locked out of your Samsung mobile or tablet, then you can consider unlocking via Find My Mobile. All the Samsung devices are pre-loaded with this feature. You can use this feature to reset your password and unlock the phone, lock your device when lost, find or wipe it remotely in case it has been stolen or lost.
To fix the Samsung phone won’t accept password via Find my Mobile, make sure that remote control and remote unlock settings are enabled on your device. And here is how to unlock Samsung phone forgot password.
Step 1: On a laptop or computer, go to the Find My Mobile website.
Step 2: Sign in to your Samsung account using the correct information.
Find My Mobile
Find My Mobile
Step 3: From the options provided, click on the Unlock option.
Select Unlock Option
Step 4: Tap on the Unlock button again.
Read the Unlocking Notes and Tap on Unlock Button
Step 5: A window will open up, asking you to enter your Samsung account password. Here enter your password and tap on the Next button.
Enter Samsung Account Password
That’s it. After unlocking the device remotely, you will receive a notification on your Samsung device to inform you that your unlock method has been reset. Thus, you’ll be able to access your device by just swiping the screen.
Fix 7. Perform a Factory Reset
If all the above-listed methods fail to fix Samsung phone not accepting correct password, then factory resetting the Samsung device is the best option for you. However, this method will end up erasing all the important files and data stored on the device.
Thus, be sure to have a backup of your data before you perform a factory reset. Remember that according to your phone and tablet’s model, the process may differ. But on most devices, you’ll be able to follow the below-listed steps. Here are the instructions that you are required to use:
Step 1: Ensure that your Samsung device is switched off. If not, wait for its battery to drain. Then, press and hold the Power and Volume Down keys together to open the recovery menu.
Step 2: After the menu appears, use the Volume Up and Volume Down buttons to select the Wipe data/factory reset option. Press the Power button to select it.
Step 3: Your device will process the factory reset. Afterward, press the Power button again to select the Reboot system Now option.
Why Won’t My Samsung Account Let Me Log in?
Samsung account allows us to back up, restore, and sync phone data between multiple devices. And, Samsung Pay will use a Samsung account to enjoy services. What’s more, as we mentioned above, a Samsung account can be used to unlock a device via Find My Mobile.
Therefore, when the Samsung account password not working or the Samsung account won’t let me log in, we need to fix that immediately. Usually, this issue happens because firmware update error, a temporary system error, two-step verification isn’t working, etc. Here’s what to do:
  1. First, restart your Samsung.
  2. Try to update AndroidOS.
  3. Make sure the date and time on your phone are the same as the actual date and time.
  4. You can also reset your Samsung account password: Go to Settings app > Tap on Samsung account and enter your email or phone number > Forgot password > Click the link that sent to your email and reset password > Enter a new password and confirm to reset.
  5. Or, you need to delete a Samsung account without a password.
  6. Contact Samsung Support for further assistance, if two-step verification isn’t working.
With all the methods mentioned above, fixing the Samsung phone not accepting correct password issue will become a hassle-free task for you. We highly recommend you download DroidKit to unlock your Samsung phone. Because it can unlock any screen lock in a simple click and a few minutes. And it has no limitations on Samsung models. So why not try DroidKit for free first?
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
